25TSC60101 MODEL # FOR MAGNAVOX 25 INCH,need to re program the remote, need instructions cfmpooo3 cav#1 REMOTE # ON BACK OF REMOTE OPENING... THANKS
trintek
  • 111 Answers
SOURCE: need the code for my remote
codes for magnavox tvs: 0054, 0030, 0179, 1254, 1454
the programming procedure is as follows:
1) turn on tv
2) on the remote, press "tv"
3) press and hold set until the led blinks twice, release set
4) enter the 4 digit code, light should blink twice
5) aim remote at the tv and press power, the tv should turn off
6) if it doesnt, repeat steps 2-5 with the next code on the list
hope this helps
Posted on Nov 17, 2007
  • 5 Answers
SOURCE: codefinder
Use one of the Philips codes
Posted on Mar 03, 2008
SOURCE: philips universal remote control cl034
hey i tried this and it worked. hold code search till the light stays lit(it may take a couple of secs ) then after its lit press tv and then keep pressing channel up or down till the channel on your tv changes when does press mute to save the code. also the power button will work to during code search , but i use channel because if you accidentally skip your code you can go back the other way. you might need to take out the batteries then re-insert to reset any previous codes. hope this works for you guys as well.
Posted on Jun 06, 2008
Agent Aaron
  • 265 Answers
SOURCE: programming channels
Hey abshee,
In order to program the channels for this TV, you'll want to press the "Menu" button on the TV itself. Once in the main menu, scroll down until you see an option called "Setup." From here, press the right arrow key to enter the submenu. Before going any further, you'll want to make sure that the tuning band is correctly set to "Air" or "Cable," which will depend on how you have your TV connected.
Once the proper input has been selected, you can then scroll down to "Auto Ch Search." If you press the right arrow key on this option, your TV will automatically search for all available channels.
If you'd like step-by-step instructions (with pictures of what you should see at any given step), I'd suggest checking out the link I've provided below to Insignia's online owner’s manual for this model:
http://www.insignia-products.com/skins/skin_1/Topics/Documents/NS-LCD22_press.pdf
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Posted on Jun 20, 2008
aprmaejun
  • 97 Answers
SOURCE: PROGRAMING MY MAGNAVOX UNIVERSAL REMOTE CONTROL
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Hi Lost instructions. Would like to obtain how to program my Philips Magnavox remote. Don't know if the #2 MP#20C103-1 or the 1-0010 are the model #s. Thanks
Turn TV on, press and hold CODE SEARCH button until light comes on, press TV, the light will blink and remain on, enter the code, the light will go off, press POWER untill TV goes off....hope this was helpful...
Apr 23, 2010 | Philips Magnavox Learning Universal Remote
How do you program a philips universal remote
NEED INSTRUCTIONS FRO PHILLIPS MAGNAVOX CFMP0018 CAV#4 REMOTE
Jan 23, 2010 | Philips Universal PH301S Remote Control
I need a code
Hi go to the below link to get a PDF of the Manual and Code Book for this remote and follow instructions.
MANUAL WITH CODES (PDF):
http://www.replacementremotes.com/store/productdetailp.cfm?productid=61355
CODES ONLY (PDF):
http://www.replacementremotes.com/store/productdetailp.cfm?productid=36735&reset=1
Apr 21, 2009 | Philips Magnavox Learning Universal Remote
Need a code for a VCR/DVD player for my universal remote
Magnavox VCR. The Phillips universal remote lists the following codes:0330, 0430, 0534, 0324, 0224, 0124, 0247, 0230, 0125, 0093, 0598, 0830. Doesn't seem they have much control of which code gets used on which model. Start in the middle and work both ways to the ends. Make sure to post back which one you find that works.
Jan 15, 2009 | Philips Magnavox Learning Universal Remote
General electric Universal remote control codes
i lost my code book for my ge remote control
Apr 11, 2008 | Broksonic CTVG-5463GVC 19" TV
Programing philip universal remote to my tv
You can find the instructions here. Just follow the step by step instructions to properly select model of your Phillips remote. http://www.urc.philips.com/
Apr 07, 2008 | Philips Magnavox Learning Universal Remote
Magnavox Remote Codes
Cual es la marca del control remoto.
Mar 20, 2008 | Televison & Video
Help
I have a philips universal control and I need the code for a memorex tv
Feb 14, 2008 | Philips Magnavox Learning Universal Remote
Need the instructions and Code to Program universal remote control PHILIPS (Magnavox) and Magnavox TV.
SETTING CODES
HOLD THE CODE SEARCH BUTTON DOWN UNTIL THE RED LIGHT STAYS LIT.
PRESS THE DEVICE BUTTON (ie TV)
CHANNEL UP BUTTON UNTIL THE CHANNEL CHANGES. (300 SHOULD BE MAXIMUM)
PRESS THE MUTE BUTTON TO SET THE CODE
Feb 03, 2008 | Philips Magnavox Learning Universal Remote
Need the code for my remote
1) turn on tv
hope this helps
Nov 17, 2007 | Televison & Video
Televison & Video Logo
62 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
