Question about Compaq Presario 5000 PC Desktop
Computer/modem I would like to get a ethernet port installed to my modem
  • 871 Answers
Ok tilly
how would you like the ethernet port installed on your pc? should i say that the modem is internally installed and that you have an externat port for the ethernet...
Posted on Apr 26, 2008
New modem installed and router won't work now
First step is to make sure if the modem is working. Connect your computer directly to modem with ethernet cable and see if you can log on to internet! if yes
next step connect modem to your router's WAN port with an ethernet cable and then connect your computer to one of the LAN ports of router with ethernet cable. Power down all devices and power up modem first wait until all lights are on and then router wait until all lights are on then your computer! 9 out of 10 times this works! try good luck!!
Sep 23, 2011 | Dynex 4-Port Ethernet Broadband Router...
Followed all the set up steps but my DSL light would not stay on
  • 1 Plug the Ethernet cable into the Internet port on your wall. If you do not have Internet ports installed in your home, connect a phone line adapter to a phone line jack. The adapter makes the phone line wider so Ethernet cables can connect to it. This does not block your phone from use.
  • 2 Plug the other end of the Ethernet cable into the Internet port on the back side of the Netgear DSL modem.
  • 3 Connect the Netgear DSL modem to a local power source. The power plug inserts into the modem via a small port on the rear of the modem.
  • 4 Insert a second Ethernet cable into one of the numbered ports on the back of the modem. Run the cable to your computer and plug it into the Ethernet port on the computer.
  • 5 Look on the back end of the DSL modem for an HTTP: address. Type this into your Internet browser's search bar. The Netgear DSL modem menu appears on the screen.
  • 6 Select how many computers are to use the modem, if you are using it with other DSL modems and set up a password (the default username and password is "admin"). Click "OK" to initiate the changes you made to the menu. You can now use your Netgear DSL modem to connect to the Internet.
  • Read more: How to Install a Netgear DSL Modem ' eHow.com http://www.ehow.com/how_5886784_install-netgear-dsl-modem.html#ixzz10lH4dl2y
    Sep 27, 2010 | NetGear DGN2000 Wireless Router
    I'm trying to hookup a usb modem broadband to a router for a desktop and laptop
    This wireless router does not have any USB connection on it. Types of connection available on this router are wireless and Ethernet. You can check on the modem if there is an Ethernet port on it.
    If your modem has an Ethernet port, I recommend that you test the Ethernet connection using one of your computers. We want to make sure that the Ethernet connection on the modem is enabled. If not, you may need to contact your ISP or the modem manufacturer to make sure that the Ethernet will work before you install the router.
    If your modem does not have have an Ethernet port on it. This is not the router that will do the work for you. And I personally does not seen any router yet with the USB port for the modem.
    Feb 10, 2010 | Linksys Wireless-G Broadband Router
    I had a lightning strike now my RZ26G wont connect to the internet. Verizon said to get a new ethernet card....i dont see one --- help how can i get back on the internet?
    The ethernet card is embedded in the motherboard on this model,If you have a vacant slot on the motherboard you can install a new one there.any brand should do.
    Good luck
    Oct 22, 2009 | Sony VAIO Digital Studio PCV-RZ26G PC...
    Can the modem's ethernet port connect to a video game console?
    Most modems that have both usb & ethernet connectors are either/or, not both. I recommend using
    the ethernet connection to your computer than the usb - the ethernet connection is faster & more
    reliable. It also frees up your usb port for other use. If you want both your computer & game console on
    the internet, then you need to buy a router which will allow you to share the modem.
    Jul 08, 2009 | Computers & Internet
    4100 Modem telling me to install ethernet adapter
    You do not state if the ethernet had been working before. If this is the first time to use the port on the computer, it often needs to be turned on in the BIOS of the mother board.
    Nov 26, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
    Network card
    Yuo need to install a driver for your network card. Go to the IBM WEB site to download a network driver for your particular model ThinkPad.
    Nov 12, 2008 | IBM ThinkPad A21m 2628 Notebook
    Install
    If the modem is already registered to your ISP then you can plug the modem to your computer using an Ethernet cable (CAT5) to your computer's ethernet port and to the modem's port as well.
    If you want to use the USB cable then you need to install the drivers for it. You may go to motorola website and type in the model number of your modem to get and download the drivers.
    Though, I suggest that you use the Ethernet connection instead.
    Aug 02, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
    Ethernet cable port does not worked only the usb port worked
    Have you tried changing the lan settings, or better still use the disc that came with modem and it will auto install modem and configure settings.
    Jul 27, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
    Setting up linksys adsl2 modem
    The ADSL, Ethernet, and USB ports are located at the back of a Linksys modem. These ports are where the phone cable and computer will be connected. The ADSL Line should be connected to the ADSL port and the computer either be connected to Ethernet or the USB port., If u r using a ethernet cable no need to run the setup cd just connect the ethernet cable and contact ur isp..
    do not worry about ur sagem modem, let it be inside.. just connect ethernet cables alone..
    To setup a Linksys ADSL Modem with usb cable you need to perform two steps:
    1. Connecting the Devices Together
    2. Installing the USB Driver
    Step 1:
    Connect the phone cable to the wall jack with ADSL service and then connect the other end to the ADSL port of the modem.
    Step 2:
    Make sure the power adapter is plugged to an available power outlet.
    Step 3:
    Connect the USB to the USB port on the back of the modem and then connect the other end top the USB port of the computer.
    Step 4:
    Power on the modem. After connecting the device together, install the USB driver. For instructions, follow the steps below.
    Step 1:
    Power on the computer.
    Step 2:
    When the Hardware Update Wizard window appears. Click Install the software automatically (Recommended).
    NOTE: Windows XP has pre-installed drivers for the ADSL2MUE and will automatically install the USB driver for the modem.
    Step 3:
    Click Finish.
    Nov 06, 2007 | Computers & Internet
    Compaq Presario 5000 PC Desktop Logo
    65 people viewed this question
    Top Compaq Computers & Internet Experts
    Alun Cox
    Lee Durbin
    Lee Durbin
    Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
