I am using lenovo laptop and the os is winxp. and when i click to shutdown some time it properly shut down and most of the times it never shut down. plz help me wht to do??
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 179 Answers
Mayb a bug
Posted on Aug 05, 2010
Why doesn't it shut down correctly?
Laptop not shutting down properly is usually because of a stalled process as with any regular PC or a power management issue. Usually making sure the OS is updated and downloading or reinstalling the latest "chipset" driver from the manufacturer. Unless for some reason you're stuck in a glitch of "update and then shutdown" and the message is nto displaying properly.
Jan 05, 2016 | Lenovo G460 Laptop Computer 06774CU Intel...
When I shut down the lenovo t6670 it doesn't seem to turn all the way off? it goes into kind of a sleep mode....how do you shut it all the way off?
Hi there fellow Windows-user. To completely shut it down you have to go click on the start button(1) then click on the shutdown button(2) and it should shut off
Hope this helps. Cheers!
Apr 01, 2011 | Lenovo TP SL410 T6670 224320DVDRW14W7P...
Sometimes when got shutdown my laptop the power button is still active
it happens when laptop doesnt shut downs properly.....all u need to do is just get the battery out and then in. when you start ur comp net time go to "power" settings and check and reset if its nt in default manner.....to go to power settings.....right click on desktop at hollow place then select properties then select screen sever then "power" and then check it.
Mar 20, 2011 | Lenovo IdeaPad Z360 Notebook
I have a lenovo laptop, 3000 G410. Recently it has a problem which it shut down by itself after I use it for 20 minutes. After the shut down, I turn it on and this time it work only 2 minutes and shut down...
This sounds like a overheating problem (a CPU thermal shutdown).
This is caused by a faulty fan or the heat-sink and fan is clogged with dust. Check the fan to see if it spins freely, if not replace the faulty fan. Check the fan/heatsink assembly and remove/vacuum the dust from these components.
Nov 08, 2009 | Lenovo 3000 Y410 Notebook
Laptop not goes shutdown
get a program called tweakui and tell it to shut down you computer faster.
Apr 21, 2009 | Computers & Internet
PC does not shut down, battery remains on
hi,
try to restore your computer to an earlier time.
you can do this by clicking on start menu,allprograms,accessories,systemtools,system restore,restore my computer to an earlier time,select a date before you had the problem,then go
let it restore that should do it.
Mar 04, 2009 | Lenovo 3000 Y410 Notebook
Laptop won't shut down normally!
You should go to the BIOS and load the default settings. Also, check your device manager to check if all hardware is installed and functioning properly (no conflicts, etc).
Oct 31, 2008 | Acer Aspire 5630 Notebook
Acer laptop aspire 4710z config my notebook have problem
There could be an issue with the user accounts logins. This could be corruption in the OS when you installed it or a clashing driver . I would recommend you reinstall the Operating System with the Disks and before you start installing the drivers try to shut down and see if it shuts down properly . If it does then you know the Operating system and hardware is all fine and can continue installing one driver at a time and shutdown and restarting, continue doing this until you see which driver is causing a confict with your system. I have had a problem similar to this but it was some windows updates pack that I had done one time and had to reinstall windows too and do one by one. Hope my answer gets you closer to a solution.
Aug 07, 2008 | Acer Aspire 5500 5570-2609 Laptop
Lenovo laptop shutdown suddenly after working for a while
Hi James, replace the fan or If it's still under warranty have it serviced. Suggest you stop turning it on until the fan is replaced. It could be the fan cooling the CPU. You don't want it to fry.
The shut down process is normal when over heating is detected by the system.
lenovo link. http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-63446
Mike
Mar 24, 2008 | Computers & Internet
Signing out problem
To turn off, hold down power button (may take "long" time--6-8seconds). It WILL shut down.
If recurring problem, check setup settings for Power switch and lid options--turn off, go into standby, etc.
Feb 29, 2008 | Lenovo 3000 C200 Notebook
Computers & Internet Logo
14 people viewed this question
Alun Cox
David Payne
David Payne
