Question about RCA RS2005 CD Shelf System
RCA RS2005 reset problem
I turned on my shelf system today to listen to a cd and it tried to read and then posted....reset. How do I do this? I read a troubleshooting tip from a different model's manual(lost mine) and it told me to push the of/on button for min. of 10 seconds. still nothing. Can you help?
  • msscpa Oct 18, 2008
    cd rest
Doodad
  • 64 Answers
SOURCE: CD player won't play
Sounds like the reader (laser eye) is dirty. The reason why it says "read" is beacuse it is looking for a disc to play, it's not actually reading the disc, more like searching for data to read. Even if you have all five discs in it still won't play. It's like looking through a dirty windsheild, nowing that there is a road there but you can't see it. This is a very common problem and is easy to fix. Go to your local Walmart, or electronics store and purchase yourself a cleaning CD. It will look like a regular CD but with small brushes on one side and might come with some cleaning solution too. Shouldn't cost more than $20.
Posted on Jan 03, 2008
  • 319 Answers
SOURCE: RCA RS2640 Quit
Unit probably has defective component in standby circuit. Have serviced
Posted on May 08, 2008
  • 905 Answers
SOURCE: CD Player shelf will not open.
the door could be stuck or the cd laser mech. is stuck or the power circut for the motor that opens the door or the motor has become weak or ect..... there are many posibilitys but you need to listen for the motor sound or a click when you hit the button , if you do hear it then its stuck or the motor is to weak and needs to be replaced , or the circut isn't giving enough power to the motor
Posted on Oct 06, 2008
mrphoneguy
  • 7 Answers
SOURCE: lost remote
Amazon sells a remote for about $13.00
http://www.amazon.com/RCA-262535-REMOTE-CONTROL/dp/B001ICTKQO/ref=sr_1_18?ie=UTF8&s=miscellaneous&qid=1248891499&sr=8-18
Posted on Jul 29, 2009
  • 11800 Answers
SOURCE: Device: RCA RS1249 Shelf System I've
That is caused by the lens or the laser head: dust has settled on it and it's blocking the reflection of the laser to the sensor = no signal is detected so the player thinks that no disk is there.
Because this has happened so long time ago and nothing has been done to clean it i doubt the dust can still be cleaned - by now it has been probably baked in the plastic of the lens.
All you can still try to do now is to try a manual cleaning: dismantle the unit completely (take out the sides, take out the rear, lift the top and remove the transversal bar) and access the reading head - clean the lens with a can of compressed air from all parts and then wipe its face with a q-tip.
Posted on Feb 10, 2011
I have an older RCA audio system (cassette, tuner, and 3CD changer) Model RS2005/Rs2007 that quite working. The digital readout says "rESEt." Hoping to get the player going again. Thanks.
There are two methods to resets. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the device from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
http://schematicscom.blogspot.com/
http://electrotechnician.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs and other devices are given. Never forget to exit the service mode, after all adjustments have been done.
Dec 13, 2016 | RCA Televison & Video
What input cables do I need ti connect my iPad to listen to audio
If you meant that you wanted to play the Ipad on the audio system , you can use a EARPHONE TO RCA _ STEREO shielded cord to connect the ipad to the system. Connect RCA jacks to the AUX inout or any available input which can be switched to listen.
Oct 13, 2011 | Sony CMT-HP7 CD Shelf System
My RCA RS2650 will read some cd's but others it will not. I tried a cd cleaner, but it still doesn't read most of the cd's.
What type of CD's are being read and what type are not. It could be as simple as the type, because each CD has a special coding when created, and if your player does not recognize it, it will not play those CDs.
Nov 20, 2009 | RCA RS2650 Shelf System
Oct 03, 2008 | RCA RS2664 Shelf System
Cd wont play
can you help me with it .
Sep 05, 2008 | RCA RS2663 Shelf System
Not reading CD
The optical CD reading mechanism needs to be changed, take it to a repair center. These parts are not user-replaceable.
May 05, 2008 | RCA RS2056 Shelf System
Buzzzing
Have the same problem. Mine was sitting idol for a long time & when trying it today it just buzzes. Tried to plug headphones in & no sound to them either.
Apr 03, 2008 | RCA RS2640 CD Shelf System
Rca cd player
The loading mechanism is out of timing. This needs to be taken apart and reassembled. I'll try and locate the instructions for this tonight.
Dan
Mar 20, 2008 | RCA Lawton Turntable with Analog Radio/CD...
Jan 02, 2008 | RCA RS2656 Shelf System
RCA RS2005 CD Shelf System Logo
296 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
