Question about Sony Cyber-shot DSC-H9 Digital Camera
Sony DSC-H9 error 61:00 (when lucky enough to get that far....
Lens doesn't retract, asking to cycle the power, gives error 61:00 and displays a very blurry image on the lcd... Camera is NEW...
  • 477 Answers
Camera need to be sent back to where you got it for replacement.
http://www.digitalcamrepair.com/self_diagnosis_page.htm
Posted on Apr 26, 2008
DSC-H9 flash doesn't work
You can buy a flash unit for your camera from E-Bay listed under camera parts for your make & model but this may not be the cause of your problem. you really need to have it checked before you start buying parts that you may not need.
Jan 25, 2013 | Sony Cyber-shot DSC-H9 Digital Camera
My Sony Cyber-shot DSC-H9 has a problem when i'am using it outdoor, sunlight .Can shoot a picture, but screen dosen't display the area being photographed.
you must read the owner manual, section troubleshooting for indicate what is wrong. and fix it. Otherwise you must to the repair shop for fix it.
Normally the LCD is faulty, and need replace it.
God bless you
Sep 22, 2012 | Sony Cyber-shot DSC-H9 Digital Camera
How do I repair the lcd screen for my DSC-H9 sony camera that is broken and only shows a black screen with cracks throgh the lcd area
You need a set of philips screw drivers size #0,#00 and #000. Buy parts camera with stuck out lens but good lcd from ebay. Then replace the lcd screen and the led back light assembly connected by flexible circuit and flip up connector.
May 20, 2010 | Sony Cyber-shot DSC-H9 Digital Camera
Dear Sir, I have SONY DSC W-55 series camera. Whenever I turn on the camera its lens tries to adjust and always displays a message for turning off and turn on again.
This is usually caused by impact damge to the lens barrel or sand/grit ingress.Quik turn on the camera let the lens try to adjust.Then remove the power with the lens extended as far as it will go. Hold the camera up and check if the front of the lens is exactly parallel with the camera housing. If it is skew you can try gently pulling on the inner barrel which(If your lucky) will pop back into the correct cam.
Mar 11, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
Turn the power off and on again message
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settigs 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa
Feb 15, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
When I turn on my Sony Cyber-shot DSC-W35 the screen is dark with the word "Access" on it, moments later it tells me to power it off adn on again, any ideas?
Its lens error in your DSC-W35 camera.
Lens mechanism is either stuck or not retract completely and system control sense this error. Please replace lens assembly to get it fixed because lens mechanism is not repairable.
Thanks.
Dec 20, 2009 | Sony Cyber-shot DSC-W35 Digital Camera
SONY DSC H9 image shakes
CCD Failure!
known problem contact sony for free repairs dont worry just call them they will do it even if u are out of warranty
see this for sample advisoy and problem detail
http://esupport.sony.com/US/perl/news-item.pl?news_id=161&mdl=DSCT1
Apr 20, 2009 | Sony Cyber-shot DSC-H9 Digital Camera
Digital Camera Fault
ACCESS error could happen when lens gets stuck but if it happens when lens moves back and forth without problem it usually means that where the lens assembly plugs into main system board connection is loose. These connections are held in place by a very small thin fragile plastic clip and a few drops could be enough to snap it but not do any other noticeable damage to camera. Camera would need to be opened to see if clip is broken or maybe cable just needs to me reinserted. Either way only open camera if no longer under warranty and you are somewhat handy
Mar 20, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Camera error
The problem is the internal focus lens is either stuck, or knocked out of alignment. The lens will need to be serviced, or replaced with a new (not cost effective), or good used lens assembly.
Aug 07, 2007 | Sony Cyber-Shot DSC-W1 Digital Camera
Sony Cyber-shot  DSC-H9 Digital Camera Logo
334 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
