Question about Sony Playstation 3 (PS3) Console
My playstation will turn on, then turn off 10 seconds after i turn it on, then the red light flashes, i thought it was overheating, so i left it sitting for a while with no cords plugged in it. what is the problem with my playstation and how can i fix it?
    Novelist:
  • 105 Answers
Hi, you may try the recovery options: The PS3 stores a copy of firmware drivers on the hard-drive and will reload any corrupt files. To access the recovery menu, do this: Make sure the PS3 is turned off Press and hold the power button on the PS3 it will power on then power off. When it's off press and hold the power button again until you hear two consecutive beeps. When you hear the double beeps immediately take your finger off the power button (if your system turns off before you get a double beep just try again and hold the button, it should double beep the 2nd time you try) It will ask for the controller to be connected via the USB cable, Turn on the controller and you will have access to the menu. Be aware that you might lose all of your previously saved data.
This should work only if you didn't see a yellow led light, before the red blinking. If the recovery doesn't work and/or if you've seen the yellow light then you have to call sony technical support. Regards, Peter
Posted on Aug 05, 2010
The PS3 works fine but freezes in career mode of MLB 10 The Show. Is this also an over heating issue?
It doesn't sound like an overheating issue, more of either a disc read issue or firmware issue.
Please try my following tip for re-installing the firmware. If this does not fix it then try cleaning the laser lens.
Failing that, if it is an overheating problem usually it will tell you with an onscreen prompt or shut down with a flashing yellow light
Step 1.
Turn your Playstation 3 off into standby mode (red light on)
Step 2.
Press and hold the power button. The Playstation 3 will beep when you first press it, then beep again 5 seconds later and then beep once more and turn off back into standby mode (red light on). You must now release the power button.
Step 3.
Press and hold the power again. The Playstation 3 will beep when you first press it, beep again 5 seconds later then there will be 2 quick beeps together. When you hear these 2 quick beeps release the power button.
Step 4.
Your Playstation 3 will now start up with a screen asking you to connect a controller via USB. Connect your controller and then press the PS button.
Step 5.
A menu will now be displayed on screen. Select option 3 "Restore File System". This will then ask you to confirm that you wish to go ahead with the system restore. Accept whatever the Playstation 3 says
Hopefully this will cure the problem on its own.
Hope this helps
Jan 29, 2011 | Sony Playstation 3 (PS3) Console
When i turn my playstation on, after 5-10 seconds it shuts off by itself and the red light keeps flashing, what do i do?
If ur ps3 console wont start up....then the things to check are>>> 1.check ur power cable 2.check whether u have inserted the disc properly and precisely. 3.check the insertion of memory card... 4.check the video port.......
The PS3 red light problem occurs when your system refuses to boot up and has a small flashing red light on the power button. In most cases, the power button will turn from red to yellow and then back to a blinking red and the system will not boot up from there as it is supposed to.
There can be a variety of issues that cause the Playstation 3 red light problem, but in most cases it comes down to the system overheating. The more it overheats the more damage is created internally to the motherboard
and other functioning components. This can be caused simply by a flaw in the system or by obstructions to the fan vent such as a wall, floor, or excessive collection of dust...
click here to download repair guide
Dec 28, 2010 | Sony Playstation 3 (PS3) Console
When i turn my computer on for a second light goes green then red and stays flashing red and playstation wont come on.??
Base from the description of your problem it seems that your PS3 encounter a overheating issue that leads to a hardware failure, but we can still try to do a reset here and see if that corrects the problem.
You can perform a reset by holding down the Power button for about 10 seconds. The power light should turn red, then you can let go of the button.
Your PS3 has been reset, try to power on the unit normally to see if your problems persist.
If still same problem have your PS3 check from a service center or contact Sony for repair or replacement if its still under warranty.
Dec 06, 2010 | Sony Playstation 3 (PS3) Console
When you switch it on the red light turns to green for a second then amder then to flashing red then the station tuns off with the light flashing red
Yes this is the YLOD or red light if you prefer, it is caused by overheating and you will need to stop the heat build up to fix this. You can use a good guide or send it in and have it fixed.
Jun 16, 2010 | Sony Playstation 3 (PS3) Console
My playstation wont turn on. The red button shows but when I try to turn it on it goes green for about a second the turns yellow for a second then it turns off. At times it will just blink red. What does...
when the lights do this that means that the playstation is broken
on the internet it is called yellow light of death (ylod)
what i recomend you do is call sony even if your warnenty is run out they might replace it for free
fixing it your self is not easy and i do not recomend it
May 08, 2010 | Sony Playstation 3 (PS3) Console
My playstation has the light trun green yellow flashing red light
With your PS3 turned off, press and hold the Power button on the front of the PS3 for about 10 seconds (the system will beep as normal as it starts up but after 7-10 seconds it will beep again). The video settings should now be reverted. Doing this will also reset any theme settings. try this? seems to fix alot of issues.
Jan 22, 2010 | Sony PlayStation® 3 (80GB) Console
Playstation shutdown and the indicator light flashes red? when i touch the button it goes to solid red, when i touch it again to turn it on the light goes green momentarilt the goes to flashing red???
That is also known as the yellow light of death because of the momentary flash of amber color. The issue here is overheating, meaning that the processors have become unseated due to unit overheating and motherboard flex in hot conditions. You PS3 will need to have the motherboard "reflowed", which is a heating process that reseats your solder joints on the motherboard. A trained Sony repairman or Sony themselves can repair it, but it will cost ya. I do repairs of this type quite often. If you are savvy enough, and have the correct tools for the job, there are videos on youtube that explain how to repair the PS3. Good luck!
Nov 07, 2009 | Sony Playstation 3 (PS3) Console
PS3 shuts down after one second
hi , i hate to say this but you need to do this asap. Call the playstation support line and send it in. your ps3 is experience a corrupted hard drive. This will only get worse and will eventually shut down for good.
Jun 21, 2009 | Sony Playstation 3 (PS3) Console
VT440K orange power flashing red status light, overheated.
Make sure all the air filter caps are all the way in and nothing is broken from it. that was my cause..i had the same problem
Apr 17, 2009 | NEC (50019497) Projector Lamp for VT440,...
Sony Playstation 3 (PS3) Console Logo
134 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
