Question about RCA HDLP50W151 50" Rear Projection HDTV
Were can I buy a "light engine" , part number 26589 for a hdlp 50w151 television ?
    Problem Solver:
  • 19 Answers
26589 This is the actual part, which they have none of...but on this page they say this part can replace that one fine: 261589DX
Posted on Aug 05, 2010
I have an 03 Buick Rendezvous. The automatic lights never turn off until the car is turned off, chimes when left turn signal is on and a/c won't turn on? How do I fix this?
DTC B2577
The body control module (BCM) controls the headlamp relay by grounding the control circuit of the headlamp.
Diagnostic Aids
• If the DTC B2577 is a history DTC, the fault may be intermittent. Refer to Testing for Intermittent Conditions and Poor Connections in Wiring Systems.
• An intermittent short to ground or an open in the following locations may cause an intermittent malfunction to occur:
- The low beam headlamp relay control circuit
- The headlamp relay control circuit
- The BCM
- The BCM
Step
Action
Yes
No
Schematic Reference: Headlights/Daytime Running Lights (DRL) Schematics
Connector End View Reference: Master Electrical Component List
Did you perform the Diagnostic System Check?
YES - Go to Step 2
NO - Go to Diagnostic System Check - Lighting Systems
Install a scan tool.
Turn ON the ignition, with the engine OFF.
With a scan tool, command the HDLP low beam relay ON and OFF.
Does the HDLP low-beam relay turn ON and OFF with each command?
YES - Go to Diagnostic Aids
NO - Go to Step 3
Turn OFF the ignition.
Disconnect the HDLP low beam relay.
Probe the coil side supply circuit of the HDLP Low-beam relay with a test lamp that is connected to a good ground.
Does the test lamp illuminate?
YES - Go to Step 4
NO - Go to Step 10
DTC B2578
DTC B2603
The body control module (BCM) controls the DRL relay by grounding the control circuit of the DRL relay coil.
DTC B2645
The body control module (BCM) uses the ambient light sensor signal in order to control the daytime running lamp system. The ambient light sensor is connected to the BCM through the signal circuit and the reference circuit of the ambient light sensor.
DTC B2647
DTC B2648
DTC B2665
The headlamp switch provides a direct ground input into the body control module (BCM) for the headlamp switch input when the switch is activated. This input is used by the BCM in order to control the headlamps when the headlamp switch is in the HEAD position.
DTC B3857
The body control module (BCM) monitors the high beam headlamp signal circuit by verifying the high beam input.
Rather then going at this blindly an just replacing parts take it to a qualified repair .
Apr 30, 2017 | Cars & Trucks
2003 yukon XL one headlight is not getting power, how do i troubleshoot?
If low and high beam both are failing to work check the ground for that side . If high or low one works and the other does not check the fuse for that beam as it has 4 fuses one for each side and low and high. The fuses are in the underhood fuse block . Marked as LO HDLP LT, HI HDLP LT, LO HDLP RT and HI HDLP RT . They are 10 amp fuses .
Feb 04, 2016 | 2003 GMC Yukon XL
How can the lights be disabled that stay on all the time ?
Have you tried replacing the headlamp power relay in the underhood fuse/relay box ?
Headlights Circuit Description
Voltage to the headlamp switch is available at all times from the HDLP SW fuse 7 through CKT 1940 (ORN). When the headlamp switch is turned to the HDLP position, the headlamp power relay coil is energized through CKT 352 (WHT). A signal is also sent to the body control module (BCM) that the headlamp switch is ON. When the headlamp switch is in the AUTO or PARK position, the ambient light sensor (located in the right speaker grill) senses either daylight or darkness and sends the signal to the BCM. When the Ambient Light Sensor detects a dark condition, the BCM produces a signal that will energize the headlamp power relay through CKT 352. The relay coil is grounded through terminal F7 connector 2 of the UBEC to CKT 350 (BLK) to G102. When the headlamp power relay is energized the relay supplies power to the LT HDLP and RT HDLP fuses. The RH low beam headlamp receives current through CKT 198 (DK BLU) from the RT HDLP fuse. The LH low beam headlamp receives current through CKT 712 (YEL/BLK) from the LT HDLP fuse. Both headlamp low beam bulbs are grounded by CKT 524 (PPL) through the UBEC to the multifunction switch (low position) contacts through CKT 10 (YEL) to the headlamp grounding relay in the body relay block through the normally closed contacts to CKT 1850 (BLK) to G200.
Dec 22, 2015 | 1998 Chevrolet S-10 Pickup
Low beams dont work and only one high beam works
Do you know how to do voltage drop testing ? Leave the blubs in there sockets turn the low beams on , measure voltage on the power side , LH low beam yellow with black stripe an for the RH low beam dark blue wire . If you have battery voltage there, power side is good . Then check ground side both are yellow wires , test with lights on . if you see 6 volts , 12 volts .anything more then .03 millivolts you have a ground side problem . The lights ground through the light switch .
Low Beam
Voltage to the headlamp switch is available at all times from the HDLP SW fuse 7 through CKT 1940 (ORN). When the headlamp switch is turned to the HDLP position, the headlamp power relay coil is energized through CKT 352 (WHT). A signal is also sent to the body control module (BCM) that the headlamp switch is ON. When the headlamp switch is in the AUTO or PARK position, the ambient light sensor (located in the right speaker grill) senses either daylight or darkness and sends the signal to the BCM. When the Ambient Light Sensor detects a dark condition, the BCM produces a signal that will energize the headlamp power relay through CKT 352. The relay coil is grounded through terminal F7 connector 2 of the underhood fuse block to CKT 350 (BLK) to G102. When the headlamp power relay is energized the relay supplies power to the LT HDLP and RT HDLP fuses. The RH low beam headlamp receives current through CKT 198 (DK BLU) from the RT HDLP fuse. The LH low beam headlamp receives current through CKT 712 (YEL/BLK) from the LT HDLP fuse. Both headlamp low beam bulbs are grounded by CKT 524 (PPL) through the underhood fuse block to the multifunction switch (low position) contacts through CKT 10 (YEL) to the headlamp grounding relay in the body relay block through the normally closed contacts to CKT 1850 (BLK) to G200.
Oct 14, 2015 | 1999 GMC Sonoma
Headlights will not come on 02 s10
Have you checked fuses ? The Instrument panel fuse block , Fuse Block - I/P
LH of the I/P, near the door jamb switch - LF , fuse # 7 HDLPSW 10amp.
In the underhood fuse / relay box - Headlamp power relay , RT HDLP fuse 15amp LTHDLP fuse 15amp.
Battery positive voltage to the headlamp switch is supplied by the HDLP SW fuse in the IP fuse block. When the headlamp switch is in the HDLP position, the headlamp power relay coil is energized. A voltage signal is also sent to the body control module (BCM) signaling that the headlamp switch is activated. The headlamp power relay coil is grounded at G102. When the headlamp power relay is energized, the relay supplies battery voltage to the LT HDLP and RT HDLP fuses. Both low beam headlamps are grounded by the multifunction headlamp dimmer switch in the low beam position through the normally closed headlamp grounding relay in the body relay block to G200.
High Beams-Except ZR2 Battery positive voltage to the headlamp switch is supplied by the HDLP SW fuse in the IP fuse block. When the headlamp switch is in the HDLP position, the headlamp power relay coil is energized. A voltage signal is also sent to the body control module (BCM) signaling that the headlamp switch is activated. When the headlamp switch is in the AUTO or PARK position and the ambient light sensor detects darkness, the BCM produces a voltage signal that will also energize the headlamp power relay. The headlamp power relay coil is grounded at G102. When the headlamp power relay is energized, the relay supplies battery voltage to the LT HDLP and RT HDLP fuses. The RH high beam headlamp receives current directly from the RT HDLP fuse. When the headlamp switch is in the HDLP position, the BCM removes the ground path to the headlamp grounding and DRL relay coils. This allows current to flow to the LH high beam headlamp through the normally closed contacts of the DRL relay. Both high beam headlamps are grounded by the multifunction headlamp dimmer switch in the high beam position through the normally closed contacts in the headlamp grounding relay to G200. A ground signal is also sent to the BCM in order to confirm high beam operation.
In the i
Mar 01, 2015 | Cars & Trucks
HDLP61W151 has dark spot in screen
If it happened gradually I would suspect the lamp--a photo posted here might help.
The other possible cause in a Optical light engine which might be very expensive to replace in this brand.
Typical light engine:
Dec 16, 2012 | Televison & Video
Screen is getting darker while brightness is adjusted to the max.
Your hdlp lamp is burning out. You need a new lamp. Look online for lamp by your model number. In instruction manual of tv it shows you how to change. Takes 20 minutes to change
May 10, 2010 | Sony KDF-E50A10 50 in. LCD HDTV
2002 Escalade, headlights don't work, all other lights do? No brights or dims, fuses all seem to be ok, what would be the next item to check? I have been told the headlight switch but not sure how I would...
Make sure the TBC fuse is good in the fuse box under the hood. There is also a Headlamp relay, and fuses marked LT HDLP, and RT HDLP, If the RT HDLP and LT HDLP fuses have power, the headlight switch is good. Be sure battery power is present on both sides on these 3 fuses. If you ground the PURPLE or YELLOW wires at the bulbs, they should light. If they do, the one thing that the high and low beams have in common is the hi-low beam switch and the ground for the switch. The ground ends up at the lower left corner of the dash, under the windshield. The relay is a common relay and you will be able to find another one in the fuse box to swap for testing purposes.
Nov 13, 2009 | 2002 Cadillac Escalade
02 grand cherokee intermittent blinkers
Ok, alright here is the parts price
ACDELCO Part # C6282A moreinfo.gif {#89057125}
Turn Signal Switch & HDLP & HDLP DIMR & FOG LP $68.89
Labor time is about 1.5 hours, here that is $150.00, so the price.
My parts price is from www.rockauto.com, lowest on the internet, note, the shop will mark up the price as much as 100%, buy the part yourself.
Dec 12, 2008 | 2002 Jeep Grand Cherokee
RCA HDLP 50W151 scenium color wheel
They make two different color wheels for the Rca DLP are you positive you got the right one. As usually its a straight forward install no adjusting needed. Post the chassis number off the back of your set and I will try to help you out with it.
Apr 07, 2008 | RCA HD61LPW42 61" Rear Projection HDTV
RCA HDLP50W151 50" Rear Projection HDTV Logo
73 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
