Question about LG LSC26905TT Side by Side Refrigerator
I also have water freezing inside of freezer. water seems to continue to pour into ice tray after tray is full of water and over flows down the inside of freezer. my guess is that the water valve is not shuting off when its suppose to.seems to be a mtg.issue.freezer is only 5 yrs old.
    Problem Solver:
  • 15 Answers
I have the same frig and same issue... water overflows the tray. A few things cause it. 1. the tray is bent from the twisting so its lower on the side the water flows in. 2. The water flows out too hard/fast.. splashing all over. LG said to install a water pressure regulator (nice). You'll want to look at the water hose.. if there is ice inside its because your water valve is not shutting off (mine's been bad since I bought the frig). <br /> <br /> For the hose--its too long and overshoots the tray. LG designed a new ice tray and if you called about it during warranty they'd install the new one. Now--you're going to pay or you can try home remedies. Cut the tube shorter so it ends right at the ice tray. Turn down your water pressure on the frig feed (close the valve some). And cross your fingers.
Posted on Aug 22, 2010
  • 39 Answers
I would say if your refrigerator is level and this problem has just recently occured sounds like you do have a bad water valve.
Posted on Aug 05, 2010
I have a LG fridge model GR-P247STSL and the ice maker is not working. The plastic arm that determines whether the ice bucket needs replenishing is not coming down. Do you know why?
*Check your warranty. You should call vendor for service.
*** The following is for information only.**
* I've had this problem a lot with my old fridge. Water line works but no ice.
* Check if the "Ice Full" leaver is in the down (no ice) position. Some ice makers will lock the leaver (a stiff wire) in the full position to manually shut off ice maker. Make sure it swings up and down when ice tray is empty.
* Sometimes when the tray is left full of ice for a week or more then the tube feeding water will freeze up. Defrosting the freezer on a regular basis will help. A quick fix is to pour warm water in the ice maker section (where the ice is formed). This will help melt the clogged pipe and also make some ice while your waiting. You may have to do this several times. But at least you have ice.
* This (freezing up) may also be caused by the freezer set too cold. The temperature dial should be in the middle. But turning it colder and colder over time will cause ice to build up and prevent foods from freezing properly (thus turning the dial down colder.) Once your maxed out on the dial. You will find the freezer gets warm and things get covered in frost crystals.
* Transfer food to another refrigerator and perform a complete defrost by leaving it unplugged and the door open (freezer section).
* Frequently check and dump water at bottom of fridge. Clean the dust on coils while down there.
* A fan blowing into the freezer section helps. (Do NOT use a heated fan as it will warp the plastic and overpressure the refrigerate.)
* Once defrosted (+4 hours). Power up the freezer and set the temperature dial to mid point and the freezer diverter to middle or normal setting. Don't put the food back in yet. Wait till the freezer gets down to normal freeze temp (about 0 to 10F)
* Move freezer back in place (if you moved it to access plug) then slowly put back the food. Try not to cram stuff in. Leave space for air to flow freely around items.
* Final, Call for service anyway and have them perform yearly service. Check your warranty.
Aloha, ukeboy57
May 29, 2018 | LG Refrigerators
Are ice maker stopped working, so we need to reprogram it
*** The following is for information only.***
Aloha, ukeboy57
Mar 12, 2018 | Refrigerators
Maytag Performa fridge has stopped making ice -- I changed the water filter to make sure that wasn't the problem. The water in the door works fine and there is plenty of pressure in the water line but the...
First, I'm not a Maytag tech.
Check your warranty. You should call Maytag/Sears for service.
Aloha, ukeboy57
Feb 20, 2018 | Maytag MTB1504A Top Freezer Refrigerator
Water dripping from freezer into refrigerator area and frozen water in freezer
The defrost cycle is melting ice that will not go down the drain tube in the rear of the freezer. This can be a clogged tube due to debris, organic growths or ice blocking flow. What doesn't end up dripping into the fridge ends up freezing in the freezer compartment. Make sure the fridge is level or tilted back slightly.
Unplug the fridge from power. Remove the contents of the freezer and remove the ice maker, back wall plate and floor plate in the freezer section. Remove ice build up on the floor and tray in the freezer by thawing and soaking up water. Flush hot water (use a turkey baster to get at it) at the opening of the drain hose that is connected to the tray to thaw any ice.. once flowing to the evapraor tray under the fridge, mix up 1/2 oz of bleach and 4 oz of water and pour down the tube to kill any bacteria.
Reassemble and restock the freezer. Monitor the temperature of the fresh food (34 deg) and freezer (0 deg) compartments. If you notice the temperatures start to climb, there may be a problem with the defrost timer, terminator, etc. and may require a pro's help.
Mar 12, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Water continually flowing in freezer section
If the water do not stop then turn off the faucet. This could be caused by a bad ice maker.
Feb 11, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
Water leaking from freezer compartment and ice maker not working properly
I figured it out. When the water filter gets old and plugged up, not enough water flows into the cube trays. You can fix the ice problem by replacing or just removing the filter. (The filter really isn't necessary unless your water comes from a well or some other undesirable source.) The filters cost about $40 from Sears, but you can find them on ebay for under $30 including shipping.
Jan 27, 2009 | Refrigerators
JCD2389DES Water Leak Problem
We also had this problem with a Jenn Air side by side. I cleaned out the drain tube and melted the ice in the collector tray but we still had water coming out of the freezer door later on. My wife started looking for a new fridge because she was tired of cleaning up the pudles daily. I went online to another site and found this to be a common problem. It seems the defrost cycle is not long enough to let all the water drain out of the collector tray and it ends up frozen in place and the the tube gets blocked and the the water runs down the inside back of the freezer untill it fills the the bottom of the freezer. Then it freezes and the the next time the water flows out the front of the door on to the floor. There are kits available to solve this problem and they cost about $20. I looked at what was in the kit and made my own part. It is a 9 or 10" long piece of # 12 or #14 copper wire (house wiring ground wire).
Turn off fridge and take the shelves out of freezer and then take off the large grill on the back wall and melt the ice in the bottom area where the metal water collector tray is. Look under the fidge where the evaporator tray is and make sure water is in fact running down the tube. To make sure it is, empty out the evap tray and put it back in and pour water into the defrost collector tray to see if the water flows down to the evap tray. If it doesn't then blow it out. If it does then take the copper wire and shove all but 2" of it down the tube that drains the collector tray. The last 2" or 3" of wire needs to be bent 90 degrees so that it lays flat in the tray. It seems the cooper wire that is down inside the tube conducts enough warmth from outside the freezer to keep the tray from freezing up to soon after the defrost cycle and lets all the water drain out down to the evaporating tray which is under the fridge. We never had water in the evaporating tray before because it was never making it down the tube. It has been many months now since my fix with no water on the floor.
Jun 27, 2008 | Jenn-Air JCD2389G Side by Side...
Water leaking inside freezer ice maker
sounds like the line was frozen but the water fill indicator is faulty.
Jun 05, 2007 | Hotpoint HSS25GFP Side by Side...
No ice...different question
Are you able to see if you can push a Q-tip or something up the fill tube line to see if it's frozen up inside there. It happens on certain units. You may need to take the Ice Maker out (easy) to get to the fill tube.
Feb 27, 2007 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
LG LSC26905TT Side by Side Refrigerator Logo
127 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
