Question about Senco 1Y0013N FP35 1 1/4 Inch To 2 1/2 Inch 15 Gauge Finish Nailer
How to remove extra nails from senco 15 ga nailgun
4 Suggested Answers
  • 65 Answers
SOURCE: check seal for devibiss nail gun
hi if you cannot find a local suppliers address try asking your local car refinisher for a local supplier for his develbis spray gun,painters go through a lot of parts for there guns .this should steer you in the right direction if not google hope this helps ian
Posted on Mar 25, 2009
  • 31 Answers
SOURCE: SENCO COIL ROOFING GUN DOESNT ADVANCE NAILS
Clean the track and piston by removing nail tray (there are a couple of allen screws)and removing the gunk from the nail tape and if you have been shooting something glued that to. Remove head assembly and thoroughly clean and oil that also. that should fix you right up I have a couple of these guns and that is typical.
If that is no the problem rebuild the gun it is worth it as they are a great air gun
Hope this helped
Posted on Dec 30, 2009
  • 1388 Answers
SOURCE: I have seen many nails that supposedly fit the
Senco uses 33 degree paper tape clip head, however many generic brands will label their box 30-34 degree to fit several nailers. This practice causes jams in some guns and others work fine. The goal is to save money but could cost more in the long run if gun is damaged. You can use generic (other than 33) if you take a strip of nails and place them against the outside of the rails aligned with either the line of driver path of angle of the rails. This will give you a visual as to the alignment. Best result is when the complete nail is in line with the path of driver. Next best result is when the head is in the path of driver and point of nail is slightly away from path, worst is when point hits path and head is back. Good luck
Posted on Mar 27, 2011
OK, second shot at this: About 65% of the time my SFN30 Senco finish nail gun only shoots a nail every OTHER pull of the trigger. All the O-Rings are good and the driver blade is perfectly straight.
There are 4 main causes usually with this tool:
1) Check the seal in the bottom of the cylinder (under the bumper) #BF0070 (#12 on the breakdown) If this seal is missing or worn the piston will not always return fully.
2) The pusher spring #GD0253 in the magazine is not moving the nails forward
2) The driver is bent or the tip is worn / chipped
3) The check valve ring #LB0077 on the cylinder is not sealing properly
Let me know if this helps Senco SFN30 15 Ga Finish Nailer Parts
Feb 26, 2017 | Senco Air Tools & Compressors
My Senco finish nail gun only shoots a nail every OTHER pull of the trigger. It's a model SFN30 and does this about 65% of the time. It's clean and has really had very little use.
Your driver is not returning fully.
Most often this is caused by:
1) A bent driver blade - pull the driver out and inspect it, make sure it is straight.
2) A broken seal o-ring on the bottom end of the cylinder (#66)
Feb 16, 2017 | Senco Air Tools & Compressors
My senco sfn1 finish nail gun is leaking air
The SFN1 is a great nailgun, built for professionals, and is pretty much indestructible. It's air leak is most likely an O ring that is worn out. While it is theoretically possible to figure out which one it is, and replace it, the smart move is to have the gun rebuilt by an approved service tech. I usually pay about $60 to have my SFNs gone through. My oldest SFN1 is 18 years old, and it has only been rebuilt once.
Jan 25, 2014 | Senco Tools & Hardware - Others
How to load nails into the magazine
Hi. Here are pix that show u what to do. http://www.senco.com/pdf/manuals/us/brad_nailers_11_06.pdf
be sure u are using senco headless nails and be sure the gun is upside down and that you load the nail row head first so the points are pointing out. J.
Jul 12, 2010 | Senco FinishPro 35 FinishPro 15 SLS15 3...
SENCO COIL ROOFING GUN DOESNT ADVANCE NAILS EVERY THRID OR FOURTH NAIL DOESNT ADVANCE
Hope this helped
Dec 15, 2009 | Senco 1Y0013N FP35 1 1/4 Inch To 2 1/2...
602 framepro hanging up/rebuilt still hanging up
Here is a PDF file schematic that you download, for the Senco FramePro 602,
http://imgs.ebuild.com/xCat/ebuildWebB/15?ObjectID=7423&Variant=Original
Jul 12, 2009 | Senco FP620 Framepro 602 2" - 3 - 1/2"...
When the 2in 18 gauge nail enters the wood it turns in the wood and comes out the side of the wood,
That is actually the nail failing. If you try shooting any 2in. 18ga. nail into something hard like Maple or even red oak, the nail will bend. It will typically follow the grain. So Go to at least a 16 ga. nail for hardwoods.
Jun 28, 2009 | Senco Tools & Hardware - Others
Senco finish nailer not firing nails
firing pin called the driver is probably broken or needs new seals max air pressure 125 psi senco sells repair kits
May 13, 2009 | Tools & Hardware - Others
Senco 1Y0013N FP35 1 1/4 Inch To 2 1/2 Inch 15 Gauge Finish Nailer Logo
48 people viewed this question
Top Senco Air Tools & Compressors Experts
John Trevino
yoopertech
Mike
Are you a Senco Air Tool and Compressor Expert? Answer questions, earn points and help others
