Question about RIM BlackBerry Curve 8520 Smartphone
I turn on the phone to immediately find a pop up that says uncaught exception index 4>=4 then by its self it will go to w white screen that says app error 523 with a reset link beneath it. ive tried everything from hitting the reset button to just leaving it alone and it resets by itself. please help
I turn on the phone to immediately find a pop up that says uncaught exception index 6>=6 then by its self it will go to white screen that says app error 523 with a reset link beneath it
Posted on Aug 21, 2010
Dear friend Yudha, after holding the escape key, the mobile starts to load and I haven't control on any key that means neither menu nor option keys works and the mobile continues to load, then shows the same error above
Posted on Nov 30, 2011
1.Hold Escape Key While OS Booting2.Go to menu > options > Applications3.Delete ALL Third Party softwares 4.Turn off Your BB > Put out battery > put it again
Tadaa...Your BB will be cured
Tested and 100% working :D
Posted on Nov 10, 2011
4 Suggested Answers
SOURCE: I have a blackberry storm. When I woke up this
HI,
I suggest the following steps (insert plenty of reboots of your PC...not just restarts, but full power down reboots). Also, it is advised that you be logged into the PC on an account with full admin rights. Further, under Vista, use the "Run As Administrator" option for everything. If you have never installed the Desktop Software to your PC, then skip steps 1 and 2.
1) Remove your device OS update package from your PC (add/remove programs)
2) Cleanly uninstall the RIM DTM software:
  • KB02206 How to perform a clean uninstall of BlackBerry Desktop Software
3) Get a fresh download of the RIM DTM software:
  • Choose the version that is newest and (if applicable) compatible with your PIM (if you are synchornizing via USB):
  • KB12268 Applications supported by BlackBerry Desktop Manager for synchronization
4) Download (to your PC) a fresh copy of your device OS package from your carrier:
5) Install DTM to your PC
6) Install (also to your PC), the device OS package
OK...next, follow this KB (including the other links within the KB) for recovery from the 523 error:
  • KB11816 Error "523 app.error.Reset" appears on the BlackBerry smartphone
Good luck and let us know!
Posted on Jun 22, 2010
  • 17 Answers
SOURCE: how to fix blackberry 8520 app error 523
just wipe it or reload with the new updated OS
Posted on Jul 05, 2010
esound
  • 425 Answers
SOURCE: my blackberry 8520 curve gives
Hi, application errors are usually Virus infected error, You can try and use this reset steps, but it does not work on all black berries.
How to Reset a Blackberry
There are three main types of Reset that apply to the Blackberry. These are listed in order below. Instructions for Blackberry Pearl are slightly different - see bottom section of the Tip.
1) Soft Reset - simply press the ALT+RIGHT SHIFT(CAP)+DELETE keys.
This reset stops all applications that are running on the Blackberry and will help if you are having problems connecting the device to computer. This reset will not erase any information from your device.
2) Double Soft Reset - this reset is almost equivalent to a full hard reset. First perform a Soft Reset as outlined in Step 1.
As soon as the screen is no longer black - repeat the steps once again exactly as before.
This takes you to another screen showing an hour glass. Allow the device to reset. This helps if the device has suffered a more serious error. Be aware you may loose some information from your device. A backup is advised prior to proceeding if at all possible.
3) Hard Reset - this is the full blown reset and will fully reset the device to help resolve critical errors with software or hardware. Again back up important information before proceeding if possible.
Note: For RIM models 850, 857, 950, or 957, you must insert the end of a paperclip or similar blunt object into a small recessed hole on the back of the unit and depress the switch inside. The device will reboot and be hard reset.
Other Models: With the device turned on - remove the battery for 30 seconds or more. Now replace the battery. The device will reboot and be hard reset.
Blackberry Pearl: To reset to factory defaults enter 'Options' from the main menu. Scroll to Security Options and press the trackball. Choose 'General Settings'.
Press the left soft key, then scroll to "Wipe Handheld" with the trackball and press the trackball. To initiate the factory reset, your phones security code may be required in order for the process to complete. Your phone will now be restored to its original settings on leaving the factory.
A hard reset can be achieved with the Pearl in the same way as outlined at Step 3 by removing the battery.
Be aware that resets such as these may erase data, such as contacts, ring tones, pictures, text messages and stored Internet files and emails. Make sure to back up important information beforehand if at all possible. You can obtain software to back up the device to your computer directly from Blackberry right here.
Feel free to pass on your comment..
Thanks for using fixya...
Posted on Jan 10, 2011
When i turn on mybb curve it shows uncaught exception: index 11>=11 how should i fix it
tHE OPNLY WAY TO FIX THIS IS TO DO A BACK UP AND THEN RELAOD THE SOFTWARE VIA THE BLACKBERRY DESKTOP SOFTWARE ..WHICH YOU CAN DOWNLOAD FROM THE BLACKBERRY WEBSITE , WHICH IS LOACTED UNDER SOFTWARE
Feb 19, 2013 | RIM BlackBerry Curve 8520 Smartphone
On My Blackberry There Is A Message That Appeared And It Says Uncaught Exception: Index 3 >= 3 And It Won't Let Me Hit Ok. How Can I Fix This?
Uncaught exceptions are normally to an error with an application. It can be from something you downloaded or the phone software itself. If you installed something recently uninstall it and see if the message comes back. If not, do a back up of the phone with desktop manager. reinstall the OS you can get a copy from blackberry's website and slowly reinstall the third party apps and see if it comes back.
Jul 06, 2011 | Cell Phones
My unlocked orage UK purchased used in india, blackberry 8520 giving the following problems. When boot it gives: Uncaught Exception Index 11>=11 then Security check 100% OK after that white...
i have got a second hand blackberry on the 02-uk network but for some reason i cant text or make and recieve calls why is this? and how do i solve it?
Jan 18, 2011 | RIM BlackBerry Curve 8520 Smartphone
After a battery pull this message appears: Uncaught exception: Index 3>=3
Try using the re-set button. It is under or near the battery. You might need a paper clip to fit in the re-set hole. If not see your provider.
Dec 15, 2010 | RIM BlackBerry? Tour 9630 Smartphone
Uncaught exception 11>=11 bb
my phone went dead last night went i was in bed and when ive woke up this mornin ive put it on charge and the screen was white and said app error 523 reset so i reset it and it says uncaught exception:11 >11 and then went i press ok it just goes straight back to app error 523 .... and i need my phone :( how can i fix it without sending it off and paying for it?
Nov 30, 2010 | RIM BlackBerry Storm 9530 Smartphone
When i put on my phone this appear on the screen.uncaught exception index 8 is = or > 8 then later i have a white screen showing application erro 523 reset
did you ever get this fixed, mine is doing the exact same thing and just keeps rebooting. I can not do anything with it.
Jul 13, 2010 | RIM BlackBerry Curve 8520 Smartphone
How to fix blackberry 8520 app error 523
May 09, 2010 | RIM BlackBerry Curve 8520 Smartphone
Blackberry bold says uncaught exception: index 4+4
Reload the OS of your BB Decice connecting to Desktop Manager.
Jul 07, 2009 | RIM BlackBerry Bold 9000 Smartphone
RIM BlackBerry Curve 8520 Smartphone Logo
1,456 people viewed this question
Top RIM Cell Phones Experts
Longtime User
ismael castillo
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
