Question about LG Dishwashers
Lg dishwasher 3850DD3006A smells like an electrical short when running
  • LG Master
  • 43,501 Answers
Check your heating element..
Dishwasherlg dishwasher 3850DD3006A smells like an - 2_bing.gif Problems The Heating Element not Working
http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not
Dishwasher2_bing.gif Maintenance
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Asker's Testimonial " expanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Posted on Aug 05, 2010
LG Stainless. P/no 3850DD3006A Model number tag is missing, what model is this? Also, error code E1, what does this mean? Thanks!
The E1 error or fault code indicates that when the drain pump is running it is not experiencing the back pressure it expects. This is usually an indication that there is a water leak in the drain system. Check all hoses and connections. Check under the dishwasher for any major leak. If all checks out, be certain there is a proper loop in the drain hose to prevent siphoning. Finally, if the problem persists, the drain pump itself might be defective.
Nov 06, 2015 | LG Dishwashers
Lg p/no 3850dd3006a leaks at door
Every dishwasher door has a door seal. If the dishwasher is leaking water, it might be that the door seal is defective or worn out. Try closing the dishwasher door on a sheet of paper and see if the door seal is making good contact all the way around the door. If not, replace the door seal. If the door seal is good or has been replaced and there is still a leak check the door hinges. If the hinges are bent the door will not close properly and the hinges will need to be replaced
Jun 19, 2014 | LG Dishwashers
The Vent on the front of my Kenmore Elite Dishwasher is giving off a very strong smelling odour when the dishwasher is going through the entire cycle. The inside of it is fine, no smell. It smells up my...
There is a product sold at home depot that is called AFFRESH made for cleaning smells of stagnant water and other smells as well. They make two different kinds of this product one is for a dishwasher and comes in a yellow bag the other is for front load washers but can also be used on top load washers as well in a green bag. Basicly you use a tablet and run the dishwasher on its hottest setting. Unfortunatley I am unable to smell the smell that your smelling if it were a burnt wire smell then I would ask that you turn off the electrical breaker to the dishwasher whereas I have seen on LG units a couple years ago a type of black goey insulation that LG used to use as a form of insulation on the wires in between the the two panels for the door. Unfortunatley this type of insulation ended up corroding the wires and eventually makeing them short against the door of the unit. Also at least once per year you should also clean out the chopper area in your dishwasher this is the part of the dishwasher that shreds up any large debris or food particles in a dishwasher. It would really depend on if it smells like a stagnant water smell, a old food type smell, or an electrical type of smell. I very much reccommend using the AFFRESH though as even the toughest smells of mold or stagnant water can be alleviated with this product. Using two tablets usually remedies the smell. If you have any further questions message me back and please remember after our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future Thanks
Rick
p.s if you need a schematic showing the location of your chopper message me back the model number to your machine and I will locate your schematic
Aug 11, 2011 | Kenmore Dishwashers
LG dishwasher mode# 3850dd3006a is not draining water.
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat.
Hope this helps... Please post back for any further assistance.
Daniel
May 07, 2011 | LG Dishwashers
Dishwasher makes a buzzing noise and then shuts itself off.
MINE IS A 3850DD3006A AND IS 4 YEARS OLD. I HAVE CHANGE THE MOTOR TWICE FOR THE SAME PROBLEM, IT GIVES CODE LE. THE MOTOR RING SPLITS AND WON'T LET THE MOTOR SPIN EASILY.
WHAT A PEACE OF JUNK!!
Nov 25, 2010 | LG LDF6810ST Stainless Steel Built-in...
Cant take out the motor
MINE IS A 3850DD3006A AND THE MOTOR IS HELD IN BY THE PROPRLLER IN THE TOP. AND UNDER NEATH THE MOTOR BY SCREWS.
Nov 25, 2010 | LG 24 in. LDS 5811ST Stainless Steel...
My LG dishwasher (LDF7810WW) makes a whining noise when the motor starts up. It continues on and off when it is running. Is the motor bad?
MINE IS A LG 3850DD3006A AND YES THE GARBAGE DISPOSER GETS STRAWS AND JUNK IN IT. OR THE SCREEN ON THE TOP IS COVERED WITH MACARONI AND CHEESE. OR TWICE IN 4 YEARS THE MOTOR RING SPLIT AND THE MOTOR STARTED TO GRIND THAT RING TILL IT STOPPED ALLTOGETHER.
I ADMIT THE STRAWS ARE THE USERS FALT!
Apr 24, 2010 | LG 24 in. LDF 7811 Stainless Steel...
LG Dishwasher (3850DD3006A) is leaking along left
Contact LG @ 1800 243-0000 this is a known issue and they may help you out.
The drying vent needs to be updated if this is a couple years old amoung other items such as the wire harness and inner door liner..
Jan 07, 2010 | LG 24 in. LDS 5811ST Stainless Steel...
Whirlpool 24" built-in GU1200XTLBO dishwasher electrical smell
This may be the smell of Varnish used in motor winding. When we turn on the machine it gets heated a little bit resulting in a burning electrical smell.
Mar 11, 2009 | Whirlpool GU1200XTLS Stainless Steel...
Dishwashers Logo
471 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
