Question about Sony Playstation 3 (PS3) Console
Playstation 3 internet connection
The playstation will shut off my router when i try to go online to play a game
  • 66 Answers
Try Disconnecting the router or get a new rotuer i suggest the Wireless - G its a very quick router it has boradband and wireless and it has a Speed Booster. its better than the other 1s but its a 2007 model probably a better 1 out there but i suggest this 1 for about 10 - 20 bucks the brand is Linksys the model is WRT54GS.
Your Welcome
I tried my best.
Rate my Solution.
Posted on Apr 29, 2008
Error code for sony 3 807
"Hey, here is a list and a reason of some of the error codes you may encounter whilst connecting your PS3 online, also the required ports need to be opened in order to play online.
Playstation Network Required Ports
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Playstation 3 Error Code List
0710102 - DNS Error; No DSN server available.
8001050B - Will not play demo hard drive games, when blue-ray disc is inserted - Cause unknown
80010510 - Will not play hard drive games - Cause unknown
8002b241 - DVI has no audio.
80028EA5 - Unknown
80029023 - Exchanging Key Information exchange has timed out
80029024 - The attempt to obtain an IP address has timed out
80029564 - Downloaded Game will not install - Cause unknown
8002F997 - Can not update XMB firmware
8003051E - Game will not Save
80031150 - System Settings Fail to Save - Possible Blue Screen "Setting information is corrupted.Press the x button to repair and restore default"
80130203 - PS3 connects to internet but not to network - Typically means that the required ports are not open to connect to store but PS3 can connect to internet.
80710092 - "An error has occured. you've been signed out from the ps network" - (connection dropped?)
80710102 - PS3 Cannot connect to the router with current IP information - Try rebooting your router
80710541 - The connection to the server timed out.
80710B23 - PS3 Network is Down or PS3 Network is too busy to respond"
http://community.us.playstation.com/thread/2996553?start=0&tstart=0
Apr 17, 2011 | Sony Playstation 3 (PS3) Console
(ps3) How to change Nat type 3. I found a guide online it was to complicated.
Nat 3 means that your PS3 is having problems accessing the internet connection. The best way to resolve this is to not play online using wifi just connect your PS3 directly into your router via an Ethernet cable.If this doesn't work call your internet provider and they will be more than glad to fix your problem.
Mar 03, 2011 | Red Dead Redemption: Undead Nightmare -...
Hi! recently joined playstation network. completed sign in etc. can browse online too. but when i wish to play online it gets stuck 'connecting to matchmaking server' etc
can you go to network settings in your ps3 then test internet connection. If it says UPNP unavailable then you need to enable it in your router or upgrade router firmware if router shows UPNP as enabled.
Thanks.
Nov 05, 2010 | Activision Call of Duty 4 Modern Warfare...
I need to connect my play station 3 to the internet wirelessly
Your RCA DCM425 modem is just that, a modem. you need to buy and plug a wireless router into it. That will broadcast your internet connection for your playstation to find.
Sep 29, 2010 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
My Modern Warfare 2 Game Wont Let Me Play... Please Help!!!
It could be your router or network settings for your internet. Do you use Port forwarding? The Playstation site tells you all the ports you need to use. Also try putting your playstation in a DMZ.
Mar 09, 2010 | Activision Call of Duty 4 Modern Warfare...
My playstation 3 freezes when i try and play online call of duty
Upgrade to the newest firmware, since 3.0 had some freezing issues with some games, if your internet connection is slow it would also cause it to freeze up
Dec 24, 2009 | Sony Playstation 3 (PS3) Console
My call of duty MW2 game is working fine but when i try to play online it freezes? My xbox internet test is succesful but the game keeps freezing
Might just have something wrong with the connection itself, were is your Xbox located? If it is in a obstructed place far from the router this could affect it
Dec 24, 2009 | Activision Call of Duty 4 Modern Warfare...
Ps3 cod4 downloading game settings then i cant play
1-turn off game console..............2-disconnect router for 20 seconds then reconnect............3-turn on game console..............4-go to setting click on network setting.................5-go to internet connection and press X and disable the connection wait 10 seconds and renable the connection and cod4 should work fine on line.............................
my sign name on playstation is red4n2ec0kreaper look me up if you need more help
it worked for me and should work for you
Mar 01, 2009 | Sony Playstation 3 (PS3) Console
Playstation online problem
How are you hooked up to your Internet ? is it Via a WiFi Router ? if so, ensure that the router is compatible with the Playstation 3. Also, have you tried calling your internet service provider ? they are usually able to solve connection problems with regards to game consoles etc.
Hope this Helps !?
Oct 27, 2008 | Sony Playstation 3 (PS3) Console
PS3 Internet Connection/Upgrade System/Online Play
Do an internet connection test. Your NAT type should be either 1 or 2. If not then there are some restricted ports on your router.
I find that putting your PS3 in your router's DMZ (demilitarized zone), solves all connection problems.
Dec 11, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
