Question about HP Computers & Internet
My HP 3 Button Optical mouse Model Number-MS-056OU does not work properly. LED does not glow when mouse in interfaced to Laptop. Pls assist.
yooperbud
  • 8637 Answers
SOURCE: MS Optical Mouse 4000 problem; computer mouse pad no longer functional
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
Hope this helps. Bud
Posted on Jan 19, 2009
yooperbud
  • 8637 Answers
SOURCE: IBM Optical Mouse doesn't work
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Posted on Jan 20, 2009
yooperbud
  • 8637 Answers
SOURCE: MS wireless notebook optical mouse 4000
Posted on Jan 28, 2009
CosmaP
  • 409 Answers
SOURCE: HP Wireless optical mouse stopped working
You will need to "pair" it with the receiver.  Look on the receiver and you will find a button.  press it then press the button on the mouse.
Then wiggle the mouse around.  You should see the pointer move.
Posted on May 18, 2009
romsky79
  • 822 Answers
SOURCE: IBM Optical Scroll Mouse doesn't work (Device Driver Problem)
connect your mouse. then restart your laptop do not remove mouse while restarting laptop. if not work after restart there is a problem in your mouse IC.
Posted on Jun 02, 2009
How do I setup a wireless mouse on a desktop
To setup a wireless mouse regardless of its type, do the following:
1. Insert the USB transmitter (this could look like a mini plug or a stick) and wait for windows to complete installation.
2. Once this is successful, turn on the mouse by holding down the power button. Or insert the disc that came with the mouse and run the installer. The installer will install the device drivers and setup your mouse's configuration panel which will reside in your system tray.
Make sure that the mouse has batteries and that it is switched on for it to work. It will glow red when it is switched on.
Jul 06, 2011 | Gigabyte Wireless Optical USB Mouse GMW7C
I have hp mini 210 laptop. I connect usb dongle of optical mouse to laptop. It installed automatically & successfully. It showing in device manager (Human interface device) but still optical mouse is...
Welcome to FixYa!
Here's a quick checklist to resolve your wireless mouse connection.
Solution 1.
1. If the underside of the mouse has an on/off switch, make sure to set the switch to the "On" position.
2. Make sure that the battery of the wireless mouse is placed correctly and is not drained.
3. After checking the first two steps, the optical lens on the underside of your wireless mouse should be flashing once in a while. If not, there is something wrong with the battery, the wireless mouse switch, or the wireless mouse itself is defective.
4. Connect the USB dongle in the USB port and let it install automatically.
Solution 2.
5. Connect the USB dongle in another USB port and let it install automatically.
Solution 3.
6. Restart the computer with the wireless mouse turned on and the USB dongle inserted in the computer.
Solution 4.
7. Download and install the drivers from here http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?cc=us&lc=en&dlc=en&softwareitem=ob-47909-1
I hope that this will help.
Thank you for using FixYa and keep me posted!
Jas247
Mar 15, 2011 | HP Wireless Optical Mouse
How do i get mu souris wireless mouse to work?
if your OS is Vista or Windows 7, you dont need to installed its driver.... all you gonna do is placed a new battery to the wireless mouse, plug the USB of its interface, start the PC, wait until it was properly detected and installed by System....... then pressed the "connect button" located at the bottom of your wireless mouse and at the interface module, and Presto!!!........... Goodluck!!!
Feb 27, 2011 | HP Wireless Optical Mouse
My Kensington wireless keyboard (Ci70) just stopped working. I have no idea why. The mouse works just fine. XP Pro SP 3. Have rebooted. Unplugged the USB interface device. Plugged back in. Rebooted....
Replace batteries in keyboard and re-sync the devices
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>- --> Synching Mouse or Keyboard with Wireless Optical Desktop trnsp.gif Question My mouse or keyboard doesn't work with my Wireless Optical Desktop (Model Number: 64373). What's wrong and how do I fix this problem? trnsp.gif Answer Your mouse or keyboard has lost its sychronization with the Wireless Optical Desktop, which can occur after changing the batteries, for example.
To synchronize your wireless device with its receiver:
  1. Move the device within three (3) feet of the receiver.
  2. Press the button on the receiver.
    If the receiver has an LED, the light blinks.
  3. Within ten (10) seconds, press the button on the underside of your wireless device.
    If the receiver has an LED, the light glows solidly when synchronization is successful.
Early production units of some wireless devices may require repeating the above instructions two or three times.
Timing, distance, and objects impeding the wireless signal may influence your success. While usually unnecessary, some customers have reported better results by:
  • Holding the wireless device very close, within three (3) inches of the receiver.
  • Entirely ignoring the receiver's light.
  • Simultaneously holding the buttons on both the receiver and the device for from ten (10) to twenty (20) seconds.
Dec 12, 2009 | Kensington Computers & Internet
I just got a hp optical wireless mouse and reciever,product no. is gm323aa,I checked the batteries,changed usb ports,pushed button on reciever alone and at the same time as the button on the...
make sure u installed your mouse properly...
also make sure that your usb point is correct....
make sure that the mouse u purchased is working....
Oct 04, 2009 | HP GM323AA Mouse
Optical Mouse Model AM-3055U will not work on this computer
My same model Argos mouse was auto-detected as a "USB compliant mouse" and it failed to work. Went into device Manager and manually re-installed driver as a "HID compliant mouse" from local drivers and it works!!
Yrs, Mad-****.
Jun 27, 2009 | Toshiba LCD Display for Satellite Pro...
Jun 02, 2009 | IBM Optical Travel Mouse 2224P0480
May 18, 2009 | HP Wireless Optical Mouse
Mouse inop. had a microsoft wired mouse installed prev.. could that be the problem?
Larry, delete the old mouse from device manager. and restart the computer. plug in your minimouse,dont let it automatically install, and run the drivers
keep me posted.
Nov 15, 2007 | Belkin F8E874 Mini Wireless Optical Mouse
Nov 11, 2007 | IBM Optical Travel Mouse 2224P0480
Open Questions:
HP Probook 6560b BIOS doesn't recognize working WD SATA HDD. I have verified that it works in another computer and two other SATA HDD's work in my Probook. I have a WD Black 500GB SATA HDD (model #WD5000BPKX) that was the Kubuntu OS drive in my old HP Probook 6550b and works flawlessly when I test it in my husband's HP DV2000, but the BIOS on my current HP Probook 6560b does not recognize it. Running a HD test within the BIOS returns no drive installed, however booting from Ubuntu 16.04 and 18.04 Live USB sticks shows the HDD in the OS's file manager and partition manager, and another (Seagate) SATA HDD works flawlessly in this laptop. I have restored the BIOS to defaults and the version showing within the BIOS - F08 - is newer than the one shown for Linux on HP's driver site. Are you aware of any incompatibility with this particular model of HDD? I have VirtualBox but no Windows computer, if it is advised to update the BIOS to the current F67 revision shown for Windows computers on the HP support site. EDIT: Solved. I had no access to a Windows computer, but figured for whatever reason the BIOS in a computer that shipped with a 500GB SATA HDD wasn't recognizing a 500GB SATA HDD. So I installed the original Windows Vista Basic on the older 320GB HDD, downloaded the current HP BIOS update for that OS (on my husband's Ubuntu computer, since of course Windows didn't recognize all of my hardware), copied it to the 320GB HDD, and installed it without a hitch. The Probook 6560b is now running under a fresh install of Kubuntu 18.04 on the 500GB SATA HDD that wasn't recongnized prior to that update. Maybe not the simplest way to resolve it, but at least it's fixed. Hope this helps someone else with an older laptop not recognizing their SATA HDD. :)
Aug 18, 2018 | HP Computers & Internet
Computers & Internet Logo
570 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
