Question about RCA MM52110 52" Rear Projection HDTV-Ready Television
The tv won`t turn on. its it a fuse - RCA MM52110 52" Rear Projection HDTV-Ready Television
    Problem Solver:
  • 19 Answers
Do you mean is it a fuse? Because if the fuse is blown that means more than likely there is something else wrong with it...probably in your power supply. What I recommend is to plug it in and listen for power (high pitched buzz), if you cant hear that...it could be anywhere from a diode to the HOT. If you have an om meter, I suggest checking thos first. What happened before it went out? and are there any LEDs that turn on in the front?
Posted on Aug 05, 2010
TV won't turn on
it is maybe power supply is damage,please check the fuse of power supply,if it is fuse is damage,you can change it.if fuse is ok,you can change power supply boards.when you find which boards is defective,you can search by pcb number on www.wisiny.com
Jun 05, 2013 | Craig CLC501 15 in. TV
The TV won't turn on. It is plugged in, but won't turn on at all. Is it fused?
It has a fuse and if the power light comes on and blinks a specific code that would be a error code.
This set weighs close to two hundred pounds, follow the power cord inside the set as it goes almost directly to the fuse which should be a 6.3 amp fuse----careful if its bad, it is a slow blow and special, a Radio Shack or Generic one the same amperage and type will blow for no reason, if its bad don't keep feeding it fuses.
Dec 08, 2012 | Sony FD Trinitron WEGA KV-36FS120 36" TV
My Vizio Tv won't turn on
The power supply regulator board shouldbe ckecked for fault. Check the fuse. If it is found burned out, find the reson for that. Surely there will be a reson for blowing of the fuse, if it is blown up. Without rectfying it, inserting an other fuse in place, might make things more worse.
Apr 25, 2012 | Vizio VW42LF 42 in. LCD HDTV
My Sylvania 32" Tv Model #SRT2232S won't turn
Hello
There is a fuse inside the power supply bard of your sylvania TV. Check whether it has blown out. If bllown out, replace it with same type bothe in size and amperage. If the newly inserted fuse also blow up as soon as you switch on the set, make sure that the power supply section has some short circuit in it, and should be cheked well. OK.
Sep 28, 2011 | Sylvania SRT2232S 32" TV
I have a 32" CRT Sylvania Tv that won't turn
Hello
If the TV doesn't turn ON ata all, it is surely due to some fault with its power supply regulator section. You haven't given any otehr details of your tV, than it is only a 32 inch CRT Sylvanial Tv. No model number; so I only can provide you a solution in general.
Check the ON-OFF switch for its contact. Normally, TVs uses DPST type switches [Double Pole Single Throw]. If any one contact amoung them have any problem with its internal contacts, the set won't switch ON. If the switch is OK, come towards the power regulator section circuit board, and check whether the fuse has blown out or not. If it has blown out, replace it with same type and ampere rating. Never use higher ampere rating than specified. The ampere rating will be maiked either on the rims of the fuse, or at the printed circuit board, just under the fuse. After repalcing the fuse, switch ON the TV and see whether it works well or the replaced fuse blows up as soon as you switch ON the set. If the repalced switch burns out as soon as you switch ON the set, the power supply section has damaged [shorted components in it]; and should be replaced.
Normally for LCD TVs it will be good to replace the power supply as card basis. This power regulator card can be bought from most of the electronic spare part shops at your town, orby the authorised service center for Sylvania at your town. If you may have given its model number, I could send you the picture of the power card of your TV. OK.
Sep 28, 2011 | Sylvania 32 in. Diagonal LCD HDTV
Have a 42" Tv that won't power up. Power to
The electrolytic caps need change out on the power supply or you can purchase a new remote at www.partstore.com
Sep 14, 2011 | Westinghouse W4207 42 in. HD-Ready LCD TV
Daughter's TV was on during bad electrical storm. Screen went black and made high pitched sound. cable, internet and telephones all digital through Time Warner Cable. Now TV will not even turn on;...
Ur Main Fuses in the circuits breaker box must be to be restart it back.Turn off/on all the fuses on the main circuits breaker box to all the fuses in the box of the box to restart.All ur electical power outlets should work again.If not those power plug in outlets are shorted and dead must have to be replaced.
Aug 22, 2011 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Tv won"t turn on, previously it would ramdonl turn
Sound like a fuse inside. Look for a glass fuse about one inch long and with a steel cap at each end and it is about 1/2" round.
Oct 31, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA MM52110 52" Rear Projection HDTV-Ready Television Logo
95 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
