Sony Wega KV32FQ86U
My tv as mentioned above, keeps switching itself to standby??? Please help, missing top gear!!!
    President:
  • 2,712 Answers
From the symptoms you describe, it seems the high voltage flyback autotransformer has failed along with the horizontal amplifier (they are slaved to each other).
Well, the only way to solve this is to get a technician take a look at the set, I'm afraid. Repairs could cost upto $100 or more, depending upon the number of components that need to be replaced,
Since the set is new, it may be worth getting fixed up. If you decide to do so, call around, as shops have different rates and different expertise. Many shops are hurting for work because so many of the smaller sets are never repaired anymore; they are just thrown out and replaced since the cost of a new set is sometimes as low as the repair expense.
Hope that helps...Should you have any further questions, please feel free to post them here.
P.S. Before you assign a rating, please make sure that the issue is resolved or you are satisfied. If not, please post back as to what you did, and/or any other questions you may have, and I will try to assist you as best I can. Please do not assign an ‘Inappropriate’ or ‘Thanks for trying’ rating if your issue is not resolved after the first response itself, as sometimes a bit of to and fro dialogue may be necessary before we can find a fix or an answer to your query.
If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers,
IrishDruid
Posted on Apr 26, 2008
  • Swilin Sampson
    Swilin Sampson May 03, 2008
    Just wanted to inquire if your issue is resolved, or if there is anything
    further I can do to assist you…
    to, or resulted in a fix, please take a moment to close the ticket with a FixYa!
    rating under my solution.
    post them here.
    Cheers!
    IrishDruid
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    P.S. -You can rate this solution with one of
    four votes, if you feel your issue is resolved.
    • "FixYa!"
      - The solution provides great advice on how to solve the problem.
      (Positive Rating)
    • "Helpful"
      - The solution provides useful leads that helps solve the problem.
      (Positive Rating)
    • "Thanks
      for Trying
      " - The solution does not solve the problem but the
      effort is appreciated. (Negative Rating)
    • "Inappropriate"
      - The solution has absolutely nothing to do with the problem.
      (Negative
      Rating)
    If your issue is not still not resolved, do not
    assign a rating just yet. Please post back as to what steps you took, results,
    etc, and I will try to assist you further as best I can.
    IrishDruid
My sony wega kv-32fq86b, some times it will switch on and stay on, other times it will switch to standby and keep tha standby light flashing.
Hello
Standby light blinking is a fault indication in Sony sets. You just count the exact number of blinks at one time, after switching on and off the set by its front panel power control switch, NOT BY THE REMOTE CONTROL HANSET. Just inform me the exact number of blinks occur there, after counting it at least four times. It will help me to reach the faulty stage, of sometimes to the exact fault location also. OK.
Dec 20, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
My sony kdf-60wf655 keeps shutting off on its own.what is the problem and can i fix it myself
If tv turns back on itself after shut down then it is weak lamp problem, replace lamp in tv to fix its problem.
Buy Sony original lamp for good picture in tv and replace it as it is user level repair and lamp replacement procedure is mentioned in related user manual.
If standby light start blinking after shut down, let me know how many times it blinks after three second pause to provide you info about possible cause of problem.
Thanks.
Dec 06, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Standby red lamp on my KP-51W5510 blinks in an 8 blink pattern
Try this first HOLD DOWN THE RESET on the remote while pressing the power button on the TV.
If this does not restart it one of the IC chips has failed and it will require repair
please rate this help top keep our service online
Aug 17, 2009 | Sony Grand WEGA KDP-51WS655 51" Rear...
When switching the tv on onlypower/standby red light comes on not
How many blinks when its red ?
The blinking is a code from the microprocessor telling why it's not turning on.
Apr 12, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
SONY KV32F-Q86U BLINKING 16 TIMES
The problem, on the AE6B chassis at least, is usually an MCZ3001DB chip. There are three in the average Sony TV, one on the so-called A-Board and 2 on the D-Board. Usually the problem is caused by a faulty one on the D-Board near the two large switching FET's. In this case, replacing this will fix the problem.
Brian.
Nov 03, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Grand WEGA KDF-60XS955
I had the same problem and it costs 200.00 dollors for the lamp that bad
Aug 15, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
I have a sony trinitron wega KV32FQ86U a 32 inch t.v. I have been experiencing persistent intermittent problem. the t.v switches itself off and on again. The drive IC has been replaced twice and this...
When the set switches off and on, do you mean just the picture or does the entire set go off? If the whole set, the standby light should blink a code number, pause and blink the code again for ever. Can you post the count here please? Which IC was replaced? Provide the answers and I can give you some options.
Dan
Jun 12, 2008 | Televison & Video
Sony kv32fq86u tv
teh 2 blinks indicate an overcurent condition. The most common cause of this is a shorted horizontal output transistor. Look for a 3-legged part attached to a heat sink close by the flyback transformer (part with red wire coming out of the top). Replace that part. That may resolve the problem. That part will be marked C5438 or something similar. If the marking is as I stated than the actual part number is 2SC5438.
Please realize that other defective parts can cause similar problems. I have just listed the most common. Please keep us posted.
Dan
Apr 16, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV-36FS76U keeps turning itself off
Due to playstation or dvd nothing will happen. 5 red flashes means jungle ic failure shows this display. Technical person only sorted out the above problem.
May 07, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Televison & Video Logo
96 people viewed this question
Top Televison & Video Experts
