Question about Philips Magnavox Learning Universal Remote
The picture has shifted to the left with a green bar on the right side
Try this
Using your TV remote, notice the "circle" of 4 arrows (up, right, down and left). Or something similar on your remote.
Point the remote at the TV, push the right arrow several times. The picture should(?) move to the right. Re-center as needed.
It worked on my Magnavox (aka Philips) flat panel. I had to move the picture and green bar to the left.
Who Knew!?
Posted on Nov 28, 2010
  • 146 Answers
Reset your cable or sat box....check connections....
Posted on Aug 05, 2010
Any advice on what board I should replace if the left half of the screen is no good, just showing white and black vertical bars? Right half is fine. Is the panel kaput?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 29, 2015 | Panasonic TH-37PH9UK 37" Plasma Display -...
First time driving a 1967 Triumph motorcycle coming up. Would like advice on where stuff is like clutch, brake, shifter and how to shift -- where the gears are. Thanks. Art asanfelici@verizon.net
Hi Art! First of all, congratulations on your 1967 Triumph... that's a beauty!!!
Basic things to know before riding a bike is it's parts.
Clutch is the lever you press on the left side of the handle bar.
Front disc brake is the lever on the right side of the handle bar.
Shifter is the one you're stepping on when shifting gears and is located on the left side of the engine if you're on it.
Now, you must first know if the gear is on Neutral by pushing the bike before starting the bike. If it's hard to push then the shifter is not in neutral. Press the shifter by your left foot until you are able to push the bike with ease.
Hop on the bike and start the engine. Most bikes have ignition starters but if your bike doesn't have one, then you have to turn keys to on position and use the kick starter. Rev the engine by pressing the throttle grip on the right side of the handle bar.
Engine is running and in idle position. Press the Clutch lever (left hand) and press the shifter once (left foot) DO NOT RELEASE THE CLUTCH YET!!!
Slowly press the throttle with your right hand until you hear or feel the engine purr...
Slowly release the clutch (left hand) until you fell the bike move forward.
If I am not mistaken, shifting the gears of the triumph is 1-down and 4 up...
Every time you shift gears, you need to press the clutch to release the gears.
Hope you'll have fun!!!
Ride safe my friend!!!
Don't forget your riding gears!!!
^_^
Jun 22, 2010 | 1993 Triumph Tiger
Picture shifted to left 1/3 and left portion shows on right side 32" sony trinitron (not flat screen)
Probably caused by a failure of certain bipolar electrolytic capacitor(s) in the area of the high voltage circuit.
May 20, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Bike gears
usually there are 2 levers on each handle bar, one lever lowers the gear while the other one raises the gear. usually the right handle bar has the shift for the gears on the rear wheel, while the left handle bar has the shift for the pedal gears
Oct 08, 2009 | Cycling
Green bar on left side and green pixalation
The Main bd has possibly failed along with P-Logic bd. Have a trained Samsung tech troubleshoot the set.
Jul 17, 2009 | Samsung HP-S4253 Television
Tv out of alignment
the picture shifted 2 inches to the right
Jun 28, 2009 | Panasonic Viera TH-42PX80U Plasma TV
Green translucient vertical bar on left side of screen
Cover green CRT lens with towel and see if red/blue video is normal......= bad CRT ?.............................T.
May 09, 2008 | Toshiba 57H82 57" Rear Projection...
Picture has shifted to the left
This is a known problem. Panasonic sells a jig to correct it. I had the same problem and bought the jig for about $25. It plugs into a special port in the back of the tv behind a little door. You can read all about it here: http://www.avsforum.com/avs-vb/showthread.php?t=534816
Aug 15, 2007 | Panasonic TH-42PD25U/P 42 in. Plasma EDTV
Philips Magnavox Learning Universal Remote Logo
137 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
