Question about Honeywell Heating & Cooling
RTH221 honeywell thermostat install, hooked up blue wire from old thermo that hooked to C to o/b connection on new thermostat no work did I screw something up as old thermo will not work as well now. was not supposed to hook blue wire up I found out later on Internet. any easn fix, blown fuse??? etc. Thanks
  • Honeywell Master
  • 43,501 Answers
maybe a blown fuse if it has one... if not then you blew the transformer...
Check on the circuit board in the furnace or air handler for a fuse...
if there isn't one... then you will need to replace the 24v transformer... they blow very easily...
heatman101
Posted on Aug 05, 2010
I am installing honeywell rth221 to an old 2 wire system. How do I do this
You need to contact Honeywell customer support on this.
Nov 26, 2016 | Heating & Cooling
Blower runs continously....
Hi Kathi,
I think its thermostat or ,thermo sensor is out of order and if it is controlled by electronic circuit it can be faulty.
another thing sometimes output contact relay for motor is faulty it want turn off itself when the circuit energize the coil.
please call electrician who can handle.
regards,
nuwan.
Jan 10, 2014 | Honeywell Programmable Thermostat Heater
Installed the Honeywell RTH2300/RTH221 but the old thermostat was removed by someone else. Since the original wires were not labeled, I simply attached them to the new thermostat by following the letters...
This appears to be a thermostat installation that was made without regard to wire code. The Honeywell material I have suggests it may be necessary to check connections at the furnace end and work back to the thermostat. There may be compatibility problems between the number of wires in the old installation and terminal connections in the new thermostat. Honeywell may be able to help at 1-800-468-1502.
Oct 29, 2013 | Heating & Cooling
I am installing honywell thermostat rth111/rth221 old thermostat has two wires that are yellow and need to know where to hook up
First things first. What type of system? Heat only, boiler or furnace? Central cooling.
Do NOT take wires off the old thermostat yet, or mark the color wire, to the terminal letter. Most times W,Y,G,R, terminals and maybe even a C terminal.
Your new thermostat should have the same letters. Sometimes they mix up color wire with terminal letters...... example (yellow wire to w terminal)
Also turn off power to equipment it is controlling. It is not high volts but you can short out the transformer. Hook uo wire color to same letter terminal on old stat, to new stat. Thats it.
Nov 12, 2011 | Honeywell Programmable Thermostat Heater
My wife bought a Hunter programmable thermostat to replace an ancient round Honeywell. The Honeywell is simple with the color coded wires simply going to the srews marked those colors. There are 5 wires,...
Normally the common wire is black, but installers can use anything, so you need to make sure that blue came off a "B" labeled screw. The common would normally be labeled "C". You need a simple multi-meter to check, although I have to believe that the instructions with the new thermo would have to cover the hookup and should show some extra connections if truly universal, as it would have to accommodate heat pumps and dual stage systems. With the old thermo mounted on the wall as it was originally with no wires connected, check for continuity between R and each of the other screws. Set thermo for cooling and turn temp down to 60 and see if you get continuity R to Y, set fan to on and see if you get continuity R to G, set thermo to heat and see if you get continuity R to W. If you just have a single wire that runs to the contactor in your condensing unit, and one wire for the heat, then the red is power from the transformer in the furnace, green is for the fan on all the time during cooling, yellow for the AC contactor, and white to bring on the heating cycle, IF ALL are single stage (only one setting for heat, cool, or fan that is either on/off). Check for continuity between R and B on each possible setting. If you get no continuity or greater resistance than on the other screws (when checking R to B), set meter to VAC and see if you get 24 volts between red and blue wires - the wires coming out of the wall and not the thermo screws. If so then you have a simple single stage for both heat and cool system. If you tape off the blue wire so that it can't contact anything in the new thermo then hook up the other wires as you state and see if everything works as it should. The blue wire in that case is a common that is not needed in your new thermo as it has its own internal battery power and does not need the common to power it from the transformer. Some systems actually use 2 transformers and the common does not run to the thermo as the other leg of each circuit is terminated elsewhere, but another wire does. If so, you will not get the readings above and you may need to do some rewiring - this is very unlikely.
Apr 25, 2017 | Hunter Fan Company 7-day programmable...
I am trying to replace my honeywell T834C2499 with a programmable RTH221. I have hooked the wires as follows: G to G, W to W, Y to Y and R to Rh - leaving the jumper between Rh & rc. My problem is that...
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
May 31, 2010 | Honeywell Programmable Thermostat Heater
Wiring new RTH2310 DIY Honeywell
sounds like you've got bear wires touching at the new tstat
Sep 18, 2009 | Honeywell Focus 6300B 5-2 Days...
Where to hook up wires?
First, take the old thermostat off the wall.
there should be different colored wires coming out of the wall still connected to the old thermo.
on the new thermo, there might be a wire color chart in the instructions or on the inside of the new thermo.
You should be able to line up the colors and install them that way. let me know if you have any other problems
Jan 12, 2009 | Honeywell Programmable Thermostat Heater
Replacing thermostat
What is the blue hooked up to now?
Jun 07, 2008 | Honeywell Electronic Programmable...
Heating & Cooling Logo
576 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
