Question about Car Audio & Video
Can some one tell me if this amp profile california a400xl do tri mode and anybody have it user manual pls publish in the net. tq
5 Suggested Answers
redlycan
  • 52 Answers
SOURCE: Restoring Administrator Password
Have a look at this.
Posted on Sep 27, 2009
psychonyd
  • 5 Answers
SOURCE: The user profile service failed the log in.
first make a hardisk backup of your files and then you should format your system because it cant be rapaired by that. clean install of windows vista is the solution.
Posted on Nov 13, 2009
  • 51 Answers
In order to boot to safe mode press and hold f-8 while the computer is booting. Normally the issue that you are having will go away after a couple of start ups:-)
Posted on Jun 06, 2011
  • 4 Answers
SOURCE: Res. sir pls list of elecronics/computer hardware book publishers in india & web adr
I personally trust these books
http://www.tatamcgrawhill.com/
Posted on Oct 19, 2012
My Dell 1750 Inspiron laptop will power up, then my user profile appears, I enter the correct password and the screen says ''The User Profile service service failed to open the logon'' ''User profile...
It seems like the user profile is not working.
You can try to start computer with safe mode with command prompt (by pressing F8 while starting the computer) and then activate administrator profile (by typing : net user administrator /active:yes) in command prompt and after that you can create a new user profile.
Let me know if it will not work.
Oct 19, 2013 | Computers & Internet
User profile cannot be loaded
It's possible that your user profile is not corrupted, but that Windows is having trouble loading it (think a bad hard drive). You can boot into the Windows 7 Recovery Console from your Windows 7 DVD. Open the command prompt and start a chkdsk.
If your profile is actual corrupted, you can try a system restore. This will restore your profile back to an earlier date. Again, use the Windows 7 DVD to do this.
You may also be able to rename the user profile using the command prompt (eg
cd \Users
ren UserAccount UserAccount.old
And then try to log in, Windows might complain of a different problem but it should recreate a profile for you.
EDIT: Are you sure you are the only user? Unless you are the local administrator, there should also be an "Administrator" account.
share'improve this answer
answered Jan 6 '10 at 5:49
0623460a9ea717d56fd359f797f98d77?s=32&d=identicon&r=pg
ta.speot.is
11k1127
I forgot to mention that System Restore, for some reason was turned off. So no previous restore points have been created. I will try chkdsk, then try renaming and let you know how i go. Thanks - Ryan Jan 6 '10 at 6:04
Just quickly, do you know how to get from drive x to drive c for rename in cmd? Its defaulting to the dvd drive dir.- Ryan Jan 6 '10 at 6:33
Sorry I worked that out, silly question. okay, chkdsk returned no errors. And renaming the folder produced the same result. Any other ideas? - Ryan Jan 6 '10 at 6:42
also, there is no administrator account that I am aware of. There is no administrator folder in /Users, and I cannot view a list of users in Control Panel > User Accounts because safe mode does not allow it. Can you think of anything else that could solve this issue? - Ryan Jan 6 '10 at 11:36
As a last ditch effort, I would try booting into the recovery mode from the DVD and try to create a new user using "net user <username> <password>" and then "net localgroup Administrators <username> /add". You may want to also try this from "Safe Mode With Console". Otherwise get yourself and external hard drive and xcopy/robocopy C:\Users\YourProfile to the external drive plus whatever other data you have. You may also use a Linux LiveCD to accomplish this. Otherwise... best of luck and I'm sorry that I wasn't able to help further. - ta.speot.is Jan 6 '10 at 12:59
show 2 more comments
Sep 14, 2013 | Computers & Internet
User profile cannot loaded
User profile may have been corrupted. will need to create new account.
Hold F8 while starting to get to a menu, select 'safe mode with command prompt'. When the command prompt shows up, you'll create a new user account.
type in 'net user (newusername) (newpassword) / add' ; followed by 'net localgroup Administrator (yournew username) /add' ; to make the new account an administrator. Restart and try to log into the new account.
Sep 12, 2013 | HP Computers & Internet
I have a California Profile 600 watt amp, I have multimeter and have power all the way to my 10
Power from ignition is setup to turn power On,
Check if +12V is available on "REM" terminal.
Check the speaker wirings , if speaker is connected to the
speaker output of the amp securely.
Oct 21, 2012 | Profile - California: 2 Channel 600W...
How do i set the ringtone on the samsung monte gt-e2550
You can change your sound settings by following the instructions below,
To change your sound profile,
1. In Menu mode, select Settings ? Profiles.
2. Select a profile you want.
To edit a sound profile,
2. Scroll to a user profile and press
? Edit.
3. Customize the sound settings as desired.
Regards,
May 15, 2011 | Samsung Cell Phones
Looking for owners manual for a porsche carrera 993
check with bentley publishers. they carry alot of this stuff for euros. or if you wish try this phone number in california- walters porsche(951)688-3344 and ask for cliff. tell him corey told you to call.
Dec 07, 2009 | 1996 Porsche 911 Carrera
Hi,I need a manual or instructions on how to work a Nokia N95
Click Here For The User Manual. page 115 for Changing Language.
Sincerely,
Michael Scott
Jul 13, 2009 | Nokia N95 Cellular Phone
The computer won't log me on.
Make a backup copy of all your data, including passwords, emails, settings, etc
Find another windows xp computer whether its a friends or another computer you have and get a memory stick or external hard drive ( which you will need ) on the working computer go into
c:\documents and settings
make a copy of the default user folder and copy that over the one on your laptop and try again.
I rebooted my system in 'safe mode' (which allowed me to login as
administrator), moved my files to the public area, and then deleted my
profile (using the Users option in Control Panel).
When I rebooted again, in normal mode, I could login as administrator, and
then moved my files back and rebuilt my profile manually.
The only problem was my forgetting about e-mail messages, which I did not
backup and have been lost permanently. Ug!!!
http://cherrybyte.blogspot.com/2007/07/fixing-user-profiles-in-vista.html
May 24, 2009 | HP Compaq Presario V2000 Notebook
Car Audio & Video Logo
270 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
