Question about Electrolux Refrigerators
Electrolux fridge french door side by side fridge, water sometimes will not dispense if there is a power outage. No the water started poruing out today by itself somehow everytime I open the freezer door it opens a flapper inside the dispenser and what ever button is pressed is what comes out...cubes, water or crushed. If you flip the flapper back up it will stop. Help I am worried it is going to go off when I am not home. model no is: EW23CS65GS1
  • 2,272 Answers
Check the water dispenser solenoid valve.The valve lets the water and stops the water.But if valve is got stuck open then it will not stop the water and this is causing the problem.When you flip the flapper back the valve closes and water stops.That flapper is called actuator arm.Also check that arm if its cracked then that also has to be replaced.Other wise the solenoid valve has to be checked replaced,. You can get required parts from.www.repairclinic.com Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Aug 06, 2010
Why do I have warm water coming out of my new Fridgidaire french door style fridge
Check to see if the supply line coming into the unit from the rear is not near the compressor. The heat from the compressor will make the water hot.
Oct 17, 2012 | Electrolux EI26SS55GS Stainless Steel ...
Jenn air french door water dispenser broken
You have two sides to your 67006531 Dual Water Inlet Valve, so it is very possible the side that controls the water flow for the dispenser is defective. Replace the 67006531 Dual Water Control Valve and I believe your fridge water will work fine.
I will be here should you have more questions, Thanks Sea Breeze
May 20, 2012 | Jenn-Air JFC2070KRS Bottom Freezer French...
Ice maker not working
my icemaker has a wire overfill sensor which shuts off the icemaker if there is too much ice in the basket. If this wire gets pushed up it will stop making ice until level lowers OR manually lowered.
Feb 08, 2012 | Electrolux EW28BS71IS (278 cu ft) Bottom...
Electrolux EW28BS71IS French Door Fridge no water and no ice
First check that you have good water pressure to the water valve. If you do, then the problem is in your refrigerator. And the most likely fault is the solenoid controled water valve which is a one in two out valve. Follow the water line from you house input and the first place it connects is that valve.
Jan 10, 2012 | Electrolux Refrigerators
Electrolux side by side door refrigerator. White
This can be pulled out of the door and replaced with new tubing.You may need to remove the front dispenser panel in order to get the tubing out of the dispenser.
Once you do that then you can pull the remove the tubing and replace it with new line.
Jan 01, 2011 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Maytag side by side fridge...water dispenser problem
If the water is visible in the front, more than likely the hose has become disconnected from the door, if you look at the lower left hand corner you should see the hose come from underneath the machine and attach to the door via a plastic quick connect, it is just a push lock connection. You may have to pull of the toe kick and the left hand end cap depending on the model to see this.
Jun 15, 2009 | Maytag MFI2568AE Side by Side French Door...
No water from dispenser
Frig is set too low of temp Water is freezing in tubing chill coil
Jun 07, 2008 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Refrigerators Logo
52 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
