Question about RIM BlackBerry Pearl 8100
Took the battery out of my BlackBerry Pearl 8100 to reset it & now it won't turn on. Have flashing red light happening.
  • 1 more comment
  • petenfrankie Aug 05, 2010
    My BlackBerry Pearl is 8130. Removed the battery to reset my zoom, which I've done before
    Removed battery & replaced it to reset my phone. When I replaced the battery, I got a blinking red light & it wouldn't power up.
    Yes, reloaded the OS system. Thanks for steering me in the right direction!
    President:
  • 1,194 Answers
Thanks for using fixya.
Remove battery for at least for 5 minutes and then re-Insert battery and start the phone. It should work. You can try it multiple times.
If still not working , then hold down the red (power) button so the red LED light stays up,and then hold the green button. When the red LED light dissapears press the red power button (end call button) again, and it will do a hard reset.
If still the problem is there then download desktop manager 4.2 or 4.3 and also download the 4.5 OS and go to local disk C/program files/commom files/apploader and take off ur battery and connect it and install the OS.
Good luck and have a nice day.
Posted on Aug 05, 2010
  • 677 Answers
Hi, when a phone won't turn on and blinks red light, it 's either the battery cell
if too weak to power up the phone all application you downloaded on the phone has
VIRUS and has affected the phone memory.
First Charge the battery forlonger hours before using another battery to confirm
if the battery cell is the problem.
If not battery, in think you will have to flash the phone memory for it to come back to life.
You can use the link below to know about how to flash the phone.
(unlocktotalk.com/UnlockCodeInstructions.htm),
Also you can try and reset it again.
There are three main types of Reset that apply to the Blackberry. These are listed in order below. Instructions for Blackberry Pearl are slightly different - see bottom section of the Tip.
1) Soft Reset - simply press the ALT+RIGHT SHIFT(CAP)+DELETE keys.
This reset stops all applications that are running on the Blackberry and will help if you are having problems connecting the device to computer. This reset will not erase any information from your device.
2) Double Soft Reset - this reset is almost equivalent to a full hard reset. First perform a Soft Reset as outlined in Step 1.
As soon as the screen is no longer black - repeat the steps once again exactly as before.
This takes you to another screen showing an hour glass. Allow the device to reset. This helps if the device has suffered a more serious error. Be aware you may loose some information from your device. A backup is advised prior to proceeding if at all possible.
3) Hard Reset - this is the full blown reset and will fully reset the device to help resolve critical errors with software or hardware. Again back up important information before proceeding if possible.
Note: For RIM models 850, 857, 950, or 957, you must insert the end of a paperclip or similar blunt object into a small recessed hole on the back of the unit and depress the switch inside. The device will reboot and be hard reset.
Other Models: With the device turned on - remove the battery for 30 seconds or more. Now replace the battery. The device will reboot and be hard reset.
Blackberry Pearl: To reset to factory defaults enter 'Options' from the main menu. Scroll to Security Options and press the trackball. Choose 'General Settings'.
Press the left soft key, then scroll to "Wipe Handheld" with the trackball and press the trackball. To initiate the factory reset, your phones security code may be required in order for the process to complete. Your phone will now be restored to its original settings on leaving the factory.
A hard reset can be achieved with the Pearl in the same way as outlined at Step 3 by removing the battery.
Be aware that resets such as these may erase data, such as contacts, ring tones, pictures, text messages and stored Internet files and emails. Make sure to back up important information beforehand if at all possible. You can obtain software to back up the device to your computer directly from Blackberry right here.
Hope this Tip helps. If so please do leave a vote for the solution.
Thanks.
Take care.
My BB pearl won`t turn on, first the screen went white
You can re-charge your battery fully by the provide electrical charger for 6 hr , then you can try and send me status.
Jul 22, 2010 | RIM BlackBerry Pearl 8100
App Error 523 Blackberry Pearl 8100
you need to wipe the device with JL commander and reload the software using desktop manager
Jul 19, 2010 | RIM BlackBerry Curve 8300 Smartphone
I cant turn on my blackberry pearl 8110. Red light just flashes
A hard reset involves physically removing the battery from the smartphone and then reinserting it. To perform a hard reset, complete the following steps:
1) Remove the battery cover from the back of the BlackBerry smartphone.
2) Remove the battery, and then reinsert it after a few seconds.
3) Replace the battery cover.
Still if it is not working kindly remove the Battery of the Handheld and try in some other Handheld.
If the Battery is working fine in the other Handheld then there might be some problem with your Handheld, you need to walk into the service center.
If the Battery is not working in the other Handheld then there might be aproblem in the USB cable for these you need to walk into the service center
Oct 14, 2009 | RIM BlackBerry Pearl 8100
Red LED light keeps flashing after I open a message
The red light is telling you that your phone is on. It will flash regaurdless if you have a text or not. When you charge it the light turns green.
Thats how they're made :)
Jul 02, 2009 | RIM BlackBerry Pearl 8100
Blackberry pearl wont turn on.
Maybe try a soft reset by pressing ALT-CAP-DEL
It might reboot for you.
Jun 05, 2009 | RIM BlackBerry Pearl 8100
Blackberry pearl won't turn on
There are no special ways of turning on the Blackberry.
Simply power on - it is fully charged - if this doesn't work, remove the battery for a couple of seconds and re-try power on.
May 30, 2009 | RIM BlackBerry Pearl 8100
Dropped phone won't work
You've ruined your blackberry to say the least. I used to have the blackberry pearl, your going to have to take it to a technician because you probably damaged some internal hardware. Your best bet is to take it to a technician to have it repaired, if they can even repair it, or buy a used blackberry from your cell phone company. Kinda sucks, but that is how they make there money- and get a touch case if you choose to get a new one. Swissgear is very very durable! Sorry your having a problem! Wish you the best of luck.
Mar 19, 2009 | RIM BlackBerry Pearl 8100
My blackberry pearl 8100 wont turn on
Try removing the Sim card and re-inserting it.
Oct 13, 2008 | RIM BlackBerry Pearl 8100
RIM BlackBerry  Pearl  8100 Logo
46 people viewed this question
Top RIM Computers & Internet Experts
ismael castillo
David
Jerry Greenberg
Jerry Greenberg
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
