Question about Samsung TX-P3075WH 30" TV
Samsung TX-P3071WH unexpectly turns off by it self. Some times I can turn it back on right away, other times I have a hard time getting it to turn back on. I have searched the internet for a Service Manual to purchase, but no one seems to have a Manual for this model.
  • 525 Answers
Check for the bad connection. if you have some soldering experience , you can do that.
Posted on Aug 05, 2010
Tv goes off by it self but i can turnit back on
Short circuited component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Mar 26, 2014 | Proscan 26LB30QD 26 in. LCD HDTV
Cant get drum back on how do I adjust the brake pads
The brake shoes can be adjusted inward by the self-adjusting mechanism at the bottom of the shoes. Turn the adjuster wheel so the shoes will just fit inside the drum. After you get the drum on, use a screwdriver through the slot on back of brake plate to turn the adjuster wheel enough clicks outward to where the shoes are just away from the drum. Turn the drum by hand. When shoes are out enough without stopping the drum, you have it right. When all done and testing out, the self-adjusters will set adjustment by backing in reverse and hitting the brakes. Do this two or three times-you may hear the self-adjusting wheel click with each time- it is adjusting the shoes to the proper distance from the drum.
Oct 13, 2013 | 1997 Plymouth Grand Voyager
Hoover bagged wind tunnel 2 vacuum turns its self off after about 10 min. of normal vacuuming I can press the power button right away and the vacuum will turn back on and vacuum for sometime as long as 5...
There is a thermal sensor in the motor which shuts power off if it gets too hot but usually it won't turn back on until it cools down. It seems you might have a defective switch
Oct 06, 2013 | Hoover U6437-900 / U6439-900 Windtunnel...
My tv has a problem staying on and sometimes it turns it self off and turns it self back on and has become more frequent with turning it self off
Check the electrical outlet which the tv is plugged into. Make sure nothing is loose at the outlet as well as on the back of the tv where the power cable plugs in.
Another thing to try is plug a different device into that same electrical outlet and see if it turns on/off as well. If that device also turns on/off by itself, it could be a faulty outlet.
Mar 09, 2011 | Samsung SlimFit TX-S3082WH 30" TV
My phone keeps turning its self off, any one else had this problem??
If the Samsung phone fairly often turns off unexpectedly, check to see how much energy the battery has. If the battery is depleted, recharge it and pay attention to how long the phone works before it needs to be charged again. If the battery is depleted before more than an hour of talk time is used, you may need to purchase a new battery
Dec 01, 2009 | Samsung S8300 Ultra Touch platinium-red...
Samsung TX R3079WH
Be certain it is not a joker with another remote.
big deal now days.
Next connect the panel to another ac power or directly to wall. wiggle the cord too.
Does the turnoff happen when loud sounds are present in movie?
if so see this link.
http://geekswithblogs.net/gaijin42/archive/2006/08/17/samsung_slimfit_hdtv_geometry_power_turn_off_service_manual_TX_R3079WH_best_buy.aspx
and when it turns its self off can you turn it back on immediately or do you have to wait.
does the sound go out at the same time.
lastly try blowing a fan on the back of it to see if it is overheating.
Jan 27, 2008 | Televison & Video
Green Screen
This might be a proble with athe green electron gun having a short between the cathode and the grid. This problem require the use of a device called a picture tube rejuvenator. to test and if need be clear the short.
Sep 11, 2007 | Samsung DynaFlat TX-P3071WH 30" TV
Interesting problem
It sounds as if you have a cold solder joint. I would check for bad solder joint(s) around the flyback transformer as this can be a common problem in some televisons.
Jun 04, 2007 | Samsung DynaFlat TX-P3071WH 30" TV
Samsung TX-P3271H Noise on cold start
greetings from belize that noise is normal it is just the boost up voltage that the set is hauling to operate.nothing to worry about.good luck.
Dec 21, 2006 | Samsung DynaFlat TX-P3071WH 30" TV
Samsung TX-P3075WH 30" TV Logo
108 people viewed this question
Jerry Greenberg
Jerry Greenberg
