Question about Kenmore Sewing Machines
I have a Kenmore sewing machine. Model number 12742. I had to take the bottom part apart because of a thread tangling. How do I put it back together? The manual doesn't cover this.
  • 27 Answers
SOURCE: Brother Sewing Machine model:CS8150 bobbin thread problems
The top of the machine is not threaded correctly. First raise the presserfot then rethread the machine. Bottom looping is usually caused by a lack of top tension. There could allso be a bur on the hook.
Posted on Feb 23, 2008
  • 319 Answers
SOURCE: tangled thread inside takeup lever in pfaff 1475cd sewing machine
Call tech support! That's why these people get paid. Sites like this wouldn't need to exist if they did their jobs correctly!
Posted on Mar 11, 2008
  • 323 Answers
SOURCE: Thread breaking.
Rethread the machine following these directions:
all machines thread the same. TTN tension, take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
Remove the bobbin case and bobbin. Pull on the bobbin thread to make sure it doesn't pull too hard. It should have some tension on it but not a lot. Insert the bobbin and bobbin case into the hook assembly and pull on the bobbin thread again.The tension should still be about the same. If it is tight, you need to look at the bottom of the pin that the bobbin case sits on and see if there are any threads looped around it. If there are , you need to remove them.
Hold the top thread , turn the hand wheel and see if the thread is catching someplace around the hook assembly. If it pulls the thread up easily, put some fabric in it and see how it works.
Make sure the thread is through the take up lever.
sewman7
Sewman7
Posted on Jul 10, 2008
maklean
  • 1665 Answers
SOURCE: help!
Have a look at link it may helps
http://www.repairsewingmachine.com/
Posted on Aug 09, 2008
bargainbox
  • 1388 Answers
SOURCE: bobbin thread tangles and needle jams
Please TRY the solution BEFORE giving your considered rating.
Specific detail on bobbin case adjustment (with picture) near halfway down reply, the remainder will help you achieve a balance of top and bottom tensions.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks
bargainbox.com.au
Posted on Sep 04, 2009
How do u thread a babylock sewing machine .....bobbin not working threads get tangled
Search the internet for a manual for your machine.
Make + Model + the word "Manual" or "threading instructions"
Sep 30, 2016 | Sewing Machines
Took my machine apart to clean & oil. Now having concern about how to put hook assembly back together. I have a manual but photo doesn't show enough detail!
This video is about removing the items in the bobbin area to clear thread tangles, but the instructions may help you figure out how to put them back together.
30 Removing Tangled Thread from the Hook Race FREE
Jan 26, 2016 | Sewing Machines
Took machine apart to get tangled thread out of take up lever . Put machine back together and all I get when I try to sew is error1
I usually have left the presser foot up when it does that to me HOWEVER, I have never opened my machine!! If you found out what happened we would love to know.
https://www.facebook.com/groups/cs6000i/
Feb 05, 2014 | Brother CS6000i Computerized Sewing...
My white sewing machine bunches thread on bottom of material and the machine won't sew
Go to singerco.com and put your model number in and download a free manual. You are probably not threading it right on the top thread or your thread is tangled, you could also have a bent needle or one with a burr on it. Change needle.
Sep 08, 2010 | Sewing Machines
Thread tangled in the bobine
I had this same problem yesterday. I took apart the needle tension casing and now it doesn't get tangled or stop. The only thing is the bobbin is not sewing...it looks fine on the top, but the bottom is just loose loops.
Jan 17, 2010 | Singer 3116 Simple
Top stitch looks good but bottom is all tangled up.
9 times out of 10 this problem leads to that the person threading it is not threading the the machine correctly. If you know you are then tightned the bottom very small screw on the bobbin case ONR QUARTER turn clockwise. Then make sure that you are putting the bottom thread through the small **** on the bobbin case. Ths should fix your problem
Nov 09, 2009 | Kenmore 19233 Computerized Sewing Machine
I can seem to get the bottom thread up
Try replacing the needle. sometimes a bent needle causes this.
It sounds like your timing may have been altered when your bobbin housing fell apart. This is difficult to repair without specialized tools and knowledge, so best get it to a repair shop.
If the machine is a common brand like Singer or Kenmore, go online and search for a manual. Many are available for under $10 or are free to download.
Nov 02, 2009 | Sewing Machines
I took apart my bobbin case, plate andbobbin holder. I can
I had the same problem and can't find my Owner's Manual. I found the answer on-line. Hopefully, you have the same type of bobbin casing. To get the answer, go to www.startsewing.co.uk and choose "How to thread a Sewing Machine". If you have the same type of bobbin casing, you should be able to figure out the proper placement of the parts by looking at the one in the demonstration. I am thrilled (!) and hope this works for you, too.
Jan 18, 2009 | Kenmore 15516 Mechanical Sewing Machine
Bobbin tangle
can not thread bobbin...bobbin on top
Jan 16, 2008 | Kenmore 19233 Computerized Sewing Machine
Janome 7000
there is a little switch at the back behind the needle. I had the same problem and after i wiggled this switch it s now working. Hurrah!
Jan 10, 2008 | Janome Memory Craft 5700
Sewing Machines Logo
64 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
