Question about Dryers
I would like to know the age of my GE Profile Dryer, #DPSR405EA 1WW ser: VA756518 A thank you, Peter Lucas
5 Suggested Answers
  • 3422 Answers
SOURCE: diagram
ok i got it.
Please CLICK HERE and just browse the sub components and you'll get the wiring diagram..I have already selected your model in that
Posted on Jun 16, 2008
localwonder
  • 6784 Answers
SOURCE: I have a GE Profile dryer. The dryer is squeekly
Check the following areas thoroughly to address this issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Concerning the squeaking sounds. this can be caused by a bad drum belt or a leveling issue as well. more issues will be bad drum support rollers or, a failing bearing assembly in the idler pulley. the blower, baffles and guides will deteriorate as well, causing noise overtime. These are most of the uncommon issue that will cause this issue, but the most common issue will be failed idler pulley bearings. The pulley will tend to squeak very loudly if the bearings are worn.
Access to the idler pulley varies by model, if your dryer has a lower front panel (kick plate) start there. It should lift up and off or it may be held in place with a few screws or snaps; it may also have a catch at the edges or center gap between the kick panel and main panel. To release the catch, push a putty knife, wrapped with masking tape, into the gap and push back the catch. The next easiest access point is the rear panel. The rear access panel is held in place with several screws along the outer edges. The last resort method of access is the removal of the entire front panel. The front panel supports the front of the drum and so removal is more difficult. Front panel removal varies. In general, access is gained by lifting the top (remove the lint trap screws first), removing the screws that secure the front panel, and detaching the panel from the drum.
When reaching into the dryer be careful of sharp edges on the cabinet and interior supports. Reach in to the belt and give it tug. It should be taught and have only a little give. The belt should go under the idler pulley and over the motor pulley. Lift the idler pulley toward the motor to relieve tension on the belt and remove it from the motor pulley.
Turn the idler pulley wheel, it should turn smoothly, quietly and without any wobble. Inspect it for cracks or uneven wear. If the idler pulley does not maintain proper tension or is damaged it should be replaced. Depending upon your model, the entire assembly or just the wheel or bearing may be replaced.
Posted on Jul 30, 2009
ginko
  • 19396 Answers
SOURCE: Ge Profile Electric dryer model DPSE810EG5WT The
Hi.
If the fan does not work at all,then the fan motor must be replaced. The fan is tested jumping its contacts to energize it directly.
More commonly the problem is clogged air ducts. Check lint filter and check ducts for blockage. Ensure that the air duct is well in place.
Posted on Jul 11, 2010
Jahn27
  • 1554 Answers
SOURCE: I need to know how
Your GE DCSR483E1WW electric dryer has only one heating element which is part number WE11M23. You can also find the parts you need here.
GE DCSR483E1WW Electric Dryer Parts
Posted on Sep 30, 2010
Elignitor le pongo corriente directa y si funciona pero conectado a la secadora no le llega corriente, si prende el motor que puede ser
It appears that one or more safety limits have failed. You will need an OHM meter to determine which one has failed.
Jan 21, 2013 | GE Profile Harmony DPGT750GC Gas Dryer
Unit won't start when you push start on keypad. It does make a buzzing sound. Top of dryer is hot. GE Profile model dpsq475et6ww ser at724827a
Can you turn the dryer easy? Try holding in the door button and starting the machine while giving it a boost by hand. That might free up whatever has it binding.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 09, 2010 | GE Dryers
Would like to replace need to know size of unit and age.
this unit is a 3 1/2 unit...the 42 the model number...possible its a 89 or 97 model...this is a 42,000 btus unit...hope this helps...michael 843-384-8474..
Mar 27, 2010 | Heating & Cooling
My GE dryer DHDSR46EG 1WW less than 2 year-old dryer flips the breaker after about 10 minutes of drying
If the dryer appears to be running OK before the breaker trips, I might consider checking the breaker. Over time they can get weak and not hold the current rating.
If the dryer is smelling "hot" then we can look a little further.
Let me know.
Regards,
Aug 15, 2009 | GE Dryers
Ge profile harmony electric dryer doesn't always heat.
Remove back of dryer and take out the elament shield and replace element don't over strech it start at one side and work it around thank you for useing fixya rate me
Jul 16, 2009 | GE Profile Harmony DPGT750EC Electric...
GE profile dryer is making squeaking noise.
please replace felt around drum thank you for useing fixya RATE ME
May 17, 2009 | GE Profile Harmony DPGT750EC Electric...
Diagram
ok i got it.
Jun 16, 2008 | Dryers
I want to know the age of my dryer model #de485rw ser #7339818
I want to know my dryers age model #fer341ac0
Apr 21, 2008 | Dryers
Dryers Logo
69 people viewed this question
Top Dryers Experts
Marvin
Marvin
