Question about Jenn-Air JWC2450ARS Stainless Steel Wine Cooler
My under the counter refrigerator does not drop the temperture below 41 degrees, Is that the lowest that it drops?
  • Jenn-Air Master
  • 43,501 Answers
It is quite possible that the thermostat is et for that temp... see if it is adjustable...but that should be very good for wine... it does not need to be colder then that...
heatman101
Posted on Aug 05, 2010
Can any make of freezer be used in garage. Told only Beco
Refrigerators are designed to be used inside at typical to normal household temperatures. The problem with refrigerators are if the ambient temperatures drop down below 55 Degrees F Food in freezer will begin to defrost when the temperature in the garage goes below 55 degrees Fahrenheit. The fresh food section may begin to freeze food slightly below this temperature. If you live in an area where the outside ambient temperature does not get below 70 degrees F or 20 degrees C then the refrigerator will work fine but to have it located in an area where temperatures drop well below this you could lose some food. There are heaters that can be adapted to the compressor if used in an unheated area. Hope this helps, Sea Breeze
Jul 05, 2012 | Whirlpool Freezers No Refrigerator Model...
My newly installed Broan-NuTone attic fan worked fine for two days. Now it wont turn off, even though the temperature has dropped well (40 degrees)below the setting(100 degrees).
Hi. The most likly cause of this type problem is the thermostat. Check the thermostat housing is it hot to the touch, is it close to a heat soarse, suchas, a motor or flu pipe for a water heater. If the thermostat has a adjustable heat range setting try setting it to the lowest setting if this shuts the unit off the calibration of the unit may not be set right. If the unit is new this should be covered under warranty.
Jun 12, 2011 | Broan-NuTone ATTIC FAN THERMOSTAT CONTROL
I have a GE Monogram ZDB24A under-counter drink refrigerator. Recently, it started freezing all the drinks we keep in it. Even on lowest setting (1), the compressor will continue running and cool the...
Hi Rich
Sounds like it needs a new thermostat.
If you are competent with electrics its a fairly easy repair, only 2 wires and the ground.
See your local fridge wholesaler and ask for a thermostat for a bottle cooler. They should be able tpo supply one.
Switch off and unplug before starting work
Knob generally pulls off or may have a small screw under the knob cap, then find how the casing is fixed, remove the casing the thermostat is fixed either with 2 screws or 1 center knut, be careful when removing the capilliary (looks like a thick silver wire) don't damage it you really will not like the smell.
Replace exactly as removed, takes lots of care and patience, use your cellphone to take images for reference if your not certain.
Hope this helps
Gordon
Apr 20, 2011 | GE ZDB24A Wine Cooler
How to set a temperture
By keep your refrigerator or freezer too cold, it unnecessarily wastes electricity. The recommended temperature is 37 to 40 degrees for the fresh food compartment of the refrigerator. The recommended temperature for the freezer compartment is 5 degrees. If you have a separate freezer for long-term food storage, it should kept at 0 to -5 degrees.
The following steps below is how to set the temperature of your refrigerator.
The first thing you must know is that your refrigerator should be set at 37-38 degrees. Anything at 40 or higher and you are risking food born illness (food poisoning) or spoiling your food.
Step 2
Place your magnetic thermometer in the refrigerator.
Step 3
Set your dial on your refrigerator to the second lowest setting. (If your refrigerator is already equipped with a digital thermostat, simply set it for 37 or 38 degrees and do not move on to the next step)
Step 4
After 2 hours, check your thermometer reading. If your reading is 38 degrees, there is no need to go higher and you are ready to put your groceries in. Be sure not to open and close your refrigerator during these two hours or your temperature reading will be incorrect.
If your reading is higher than 38 degrees, move your dial up to the next coldest setting and repeat the steps every two hours until you reach the correct temperature for your refrigerator.
Step 5
Once you have reached the correct refrigeration temperature for your refrigerator, place the magnetic thermometer in the refrigerator permanently and watch for changes.
Typically, your refrigerator temperature will need to be adjusted with the seasons, a higher setting in the summer and a lower setting in the winter.
Hope this helpout and take care.
Aug 12, 2010 | Refrigerators
Refridgerator not staying cool
Is the cooling fan in the back working? Does the center of fridge where your doors meet feel really hot?
Mar 28, 2017 | Refrigerators
Light and temperture control indicators don't work
The refrigerator was moved to a new location.  The temperature setting was on 41 degrees.  After the move the temperature indicator does not indicate any temp.  How do I reset the temp.  and turn on the indicator?
Oct 22, 2008 | Refrigerators
Best temperture to keep up right freezer and a different refrigerator
Freezer temperature for storage depends on the type of product you are putting into it. Ice Cream as an example must be kept below zero °F as also with bread dough type products. Refrigerator temperatures are best kept below 41°F.
Jun 30, 2008 | Refrigerators
Stove won't go below 170
The lowest temperture that the oven will control is 170 degrees. You would have to place a suitable thermometer in the oven and manually control the temperature if you want a lower temperature.
May 29, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Washer time-down problem
Check to see if your machine is connected to cold water, it should be. The problem could be the electronic thinks the machine is always connected to cold water at about 20 degree c. if connected to hot, the time drop if the it would take to heat the water to the incomming temperture Good luck
Aug 14, 2007 | Miele Touchtronic W1213 Front Load Washer
Jenn-Air JWC2450ARS Stainless Steel Wine Cooler Logo
106 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Jose Pino
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
