Question about Samsung PN50A550 50 in. Plasma TV
What is the Direct tv remote control code for my samsung plasma tv?
4 Suggested Answers
SOURCE: cant control tv with direct tv remote
I don't know what size TV you have but just installed Direct TV for parents and none of the codes worked after a LONG time my husband tried the Sears codes and got the last one he tried to work. He used 10056. It is a 47 inch LCD Proscan TV. If that doesn't work, you might want to try all of the Sears codes to see if one will work for you. Good Luck
Posted on Mar 17, 2009
SOURCE: virgin media remote control TV Control Codes Samsung LE37A558
just tried 0079 from another forum and it's worked for me!
Posted on Mar 30, 2010
SOURCE: samsung 50" plasma tv with no picture but has sound.
I just had a similar issue with my 46" Samsung LCD and fixed it myself for $5.11! I realize we have different tvs, but I bet it is the same issue ... crapped out capacitors.
I researched the problem online and most places, like samsung's site, referred me to call a repairman and called for the whole control panel or power supply to be replaced for anywhere between $400-$1000. I was like ... "screw that" ... I refuse to put in a fautly part in the place of a faulty part. So I continued to research.
That's when I stumbled on youtube. There are many how to videos on how to tackle this daunting task. I read that the issue was more than likely faulty capacitors and there is a very easy way to tell if it is in fact the capacitors that are blown. instead of having a flat top, faulty capacitors are crowned or even ruptured! When I opened up my TV I saw 3 blown capacitors!
So I bought 3 new capacitors all with the same uf and higher volts ... I think all three of my capacitors were 1000 uf and 25 volts. I kept the uf the same (recommended) and raised the voltage to 35 volts. It doesn't mean more volts, it just means it COULD handle more volts if it had to (which was the problem those cheap Samsung bastards screwed up on). This is a very common problem with Samsung TVs.
Anyway, I have never soldered before, but I did it. I warmed up the solder on the bad capacitors and removed them them slid thenew ones in and soldered them in and popped everything back together ... and PRESTO .... the damn thing works better than ever!
3 capacitors= $5.11
1 solder gun and solder= about $18
fixing an incredibly intimidating TV by yourself= PRICELESS!
Seriously ... don't be afraid to F up ... check it out on youtube and other place and save yourself a bundle. Source(s): I just fixed my TV!!!!!!!!
Posted on Mar 17, 2011
I have a Samsung TV iamuseing a ermsom remote need codes for this remote
Search Results
    Remote Control Codes
    support-us.samsung.com/.../pop_troubleshooting_fr...
    Samsung ElectronicsAug 11, 2011 - ... all televisions. If you encounter problems, use the television's ownremote control. ... While the television is on, press and hold the TV Power button and enter the corresponding two-digit code. ... SAMSUNG ... EMERSON. 64.
    Remote Control Code List
    www.jumboremotecontrol.com/remote_control_code_list.html
    ... codes for the remote. If you do not see your device listed, you can use the codesearch feature to program the device into the remote. TV Codes TV Code List ...EMERSON ... SAMSUNG, 004,005,009,015,104,105,106,109,172. SAMSUX ...‎Guide to Programming the ... - ‎Download the Manual - ‎8 Device Learning Jumbo ...
    Remotes - Device Codes - HiFi Remote
    www.hifi-remote.com/codes-tv.shtml
    TYPE, BRAND, CODES ... TV, Emerson, 0463, 0236, 0019, 0180, 0280, 0179, 0154, 0177, 0178, 0038, ... TV, Samsung, 0019, 0060, 0030, 0056, 0178, 0032.
Feb 05, 2016 | Samsung 50 in. Plasma TV
I have direct tv and want the remote to work
0568,0193,0182,0162,0155 are the codes to check. If you wish to get more setup codes, check this link. Setup code list to DirectTV remote control are given. Pull up older posts.
Mar 04, 2013 | Samsung AH5900092W Remote Control
Virgin remote control code for volume on my 50" samsung plasma tv
To set up the volume control on your Telewest remote control, to be able to change the TV volume, please follow the instructions below.
1. Using the table below find your make of TV and the code which matches it.
2. Press and hold down Volume + and mute on your remote control at the same time for at least three seconds, until the green light in the top right-hand corner of your remote control flashes twice.
3. Release the buttons and enter the first four digit code from the table below. (You must do this within ten seconds).
4. As you enter the first three digits the green light on your remote control will give a short blink.
5. As you enter the fourth digit, the green light will flash twice to confirm that the volume is set.
If setting the volume is not successful, please repeat the above steps with the second or third codes from the table below.
Samsung 0065, 0584, 0037
Nov 18, 2011 | Samsung 50 in. Plasma TV
Need code for sky remote control for samsung model ps51d450 51inch plasma tv
Hello
Sky remote codes for Samsung TV are:
065 584 615 037 245 476 516 292 318 236 398 244 100 118 060 088
646
672
642
Follow the steps below
1. Select any channel on the TV.
2. Point your Sky+ remote control away from the TV and press the tv button.
3. Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4. Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5. Point the Sky+ remote control at the TV and try the volume button.
If this works try the other TV functions.
If these work then the correct code has been selected.
It's important to note that not all TV functions will be supported by the Sky+ remote control e.g. Picture in Picture.
If all functions do not work correctly, then repeat steps 1 - 3 and work through all the relevant 3 digit numbers from the Sky+ remote control codes, until you find the code which supports all or as many of the TV functions as possible.
Please note: In order to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button.
OK.
Aug 30, 2011 | Samsung Televison & Video
I need the remotev codes for samsung
i need your remote control model number.  or you can get your original remote control part from www.replacementremotes.com
Apr 17, 2009 | Samsung TV Remote Control
Want to program motorola remote to samsung tv
Samsung TV Codes: 10060, 10812, 10702, 10178, 10030, 10766, 10814, 11060, 11903.
Hope that helps!
Apr 10, 2009 | Motorola Mobility DRC800 Universal Remote...
Side by side Samsung TV's need remote control solution
If possible turn one off and tune the other. Then turn the other off and tune it. Then turn on the other. That is your only option at this point.
Feb 16, 2009 | Samsung PN50A650 49.96 in. Plasma HDTV
Samsung (RS105N) Remote Control
Found the user manual here
http://www.directv.com/learn/pdf/System_Manuals/Samsung/Samsung_SIR300-310W.PDF
Dec 26, 2008 | Samsung RS105N Remote Control
Universal remote
Akai are notorious about remote incompatibility
Aug 07, 2008 | Akai PDP4225M 42 in. Plasma Television
Samsung PN50A550 50 in. Plasma TV Logo
275 people viewed this question
Jerry Greenberg
Jerry Greenberg
