Kodak all in on printer esp-3 code flashes on lcd E3102
  • 240 Answers
SOURCE: kodak printer esp 3 black ink not printing good
try lexmark printers because it easy to fix it, encase there's a trouble ..
Posted on May 19, 2009
j0llyc
  • 8 Answers
SOURCE: Solid black line when scanning or copying from KODAK ESP-3
Get a damp soft cloth and clean the scanner glass. If that doesn't resolve the issue there is a chance the scanning unit itself is damaged.
Let me know.
Cheers, Chris
Posted on Jun 21, 2009
  • 60 Answers
SOURCE: having trouble installing a Kodak ESP.3 printer,
is there any error while trying to install the software? post the error if there is any. Try to uninstall the software completely using www.kodak.com/go/clear and then try and install from www.kodak.com/go/esp3downloads.
Posted on Jun 27, 2009
  • 295 Answers
SOURCE: Kodak ESP 3 printer does not print YELLOW
no,kodak replace printheads free of cost, and if they send a printhead and that doesnt solve issue and in next 30 days,u have same issue,then kodak sends a replacement printer. and esp-3 printers are considered o be in warranty tilll now even if they are 24 months old. kodak is the best.. ur issue will be resolved.dont worry
Posted on Jul 27, 2009
  • 164 Answers
SOURCE: kodak esp-3 printer will not print black
Routine maintenance and keeping full ink tanks will prevent this problem, however if you have the problem you can resolve it by doing the following:
1. Clean your print head using denatured alcohol solvent which can be purchased from most hardware stores. If unavailable, use 91% Alcohol (isopropyl alcohol (first aid antiseptic) which is available for less than a dollar at most Walmart pharmacy departments.
*Warning: You may want to use a pair of latex exam gloves as this is a messy process and can stain your fingers.
Time necessary 45-50 minutes
Supplies needed:
Isopropyl Alcohol or denatured alcohol
paper towels
latex gloves
sink, bowls and or basin
can of compressed air
very small screw driver
tablespoon or baby bulb type syringe
warm water
PROCEDURE:
1. Lift print head from printer. It pulls out easily because it is held in with the same down lever that holds the cartridge in place.
2. Put two layers of paper towels in the bottom of a dish to protect sensitive sprayer heads.
3.Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
4. Take the two small screws out that hold the white ceramic piece
5. Gently, pry the ceramic piece back and away , to reveal the underside (No need to pull away the glued points on the sides.)
6. Gently, move head up and down to slosh solvent around it the best as you can. Use a table spoon or syringe to pour solvent over all orifices in the print head, turning it upside down and then back a few times.
7. Use canned air with a plastic straw to blow into and through all orifices, alternately sloshing/swishing and pouring solvent over head (be careful not to touch any of the holes, screens, or sprayer heads with anything)
8. Empty dirty solvent from bowl and replace with paper towels and clean solvent. Soak for approx 10 minutes. Rinse again with clean solvent poured directly on all parts, letting solvent overrun and fall into dish or basin.
9. Gently shake the solvent off the head, take it outside and spray with compressed air into all orifices to clear out and help evaporate any remaining solvent. Let sit on a clean paper towel for approx 20 minutes. (There may be a little ink bleeding out of the head, but once it dries completely it does not present any problems.
10. Reinstall head, cartridges and it will print like a new printer.
SUGGESTION: For many years of problem free printing, keep a double set of ink cartridges, one set full at all times. Whenever a cartridge runs out of ink, replace it IMMEDIATELY, with a new one or a refilled one. This gives the print head no chance to dry out and create clogged heads. Routine maintenance of cleaning the heads every 24 months does wonders for keeping your printer in new condition.
Hope this helps. .
Posted on Feb 07, 2010
This hasn't helped
need more info, like what error code display on your printer.what color the flashing light.
Dec 06, 2013 | Kodak ESP 3 Multifunction Printer/ Copier/...
Window on ESP 3 is flashing "E"
Go to Kodak Help Center
,if you need more help, post back or thumbs back.
Oct 31, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
My kodak esp 3 printer has a red flashing light on both inks and a flashing E. I've changed both cartidges and still have the same problem.
The printer contacts do not connect with the printhead contacts. The contacts may be dirty; the best way to clean the contacts is by reseating the printhead multiple times. . If that's doesn't work you will need to contact Kodak for a new printhead. Log onto www.kodak.com and find the relevant support team. Give them a call. The warranty on your AiO is 15 months so be sure to make your printer in warranty ;-). (By the way, most of the agents are happy if you tell a little white lie about your printers warranty coz it gives them less work. Also remember begore calling, ITS NOT THE AGENTS FAULT THAT YOUR PRINTER BROKE!!!
May 13, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
E code is flashing on my printer, how do I fix
May 06, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
I got a kodak esp-3aio.what thus it mean when the colored ink indicator keep flashing and the printer totally do not work.
printer will not work if there is red flashing light on it.
Both the cartridges should be filled in order to print or scan
Feb 06, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak ESP3:paper light flashes red,can't print-is totally useless
kodak has certain problems with esp-3 printers. it cannot give u a cash refund call kodak @ 1800 421 6699 . they will upgrade ur printer and give u a kodak esp-5. they have been giving esp-5 lately in return for esp-3
Jul 23, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak esp 7 paper jam
you will get a new only if the printer is within 30 days from the date of purchase so it is ok to have refurbished printer,,,,,,,just give them a headache when you have problem with this..........
Jun 05, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Code errors on kodak easyshare esp 3
error code 3501 means the front access door is open on the printer. Error code 3502 means the paper tray is empty. The error code 3602 means the print job did not finish printing.
for more hrlp visit CBR Tech Solutions
Apr 10, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Scanner problem
printer wil not only had it about month brand new.
Mar 31, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
79 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
