Question about GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Microwave - Model JVM231BL001 (1994)... The light bulb sockets underneath do not have power (I checked w/ voltmeter) and the wires that connect to them don't have power either... I removed the keypad but couldn't locate a fuse... Is there a fuse that I can change? If so, what does it look like? Also, where can I find new bulb sockets for this model? Thanks, DE
  • daveeverhart Aug 05, 2010
    I found a 20AMP fuse behind the top louvers but it seems to have continuity... any other ideas on why I'm not getting power to the bulb sockets on this model?
  • GE Master
  • 12,061 Answers
There is NO Fuse, per sa, and one MUST be VERY CAREFUL working on MW's, you see they have a very large Capacitor, inside, that can and will KILL YOU if touched. Whenever one works on a MW one MUST use a "Shorting bar" and discharge the potential to earth, this Charge can stay in this capacitor for a VERY long time... and MUST be discharged after every power on/off/on cycle Usually these faults are with the actual power Supply, and.or Magnetron/Power Diode.
http://www.retrevo.com/support/GE-JVM1640SJ-Microwaves-manual/id/1080ci954/t/2/
www.specsserver.com/CACHE/FRKXKVRNRJDC.PDF
Below is a link, for spare parts straight from manufacturer. Above are your manuals.
https://www.geapplianceparts.com/GEApplianceParts/Dispatcher
Posted on Aug 05, 2010
    My actual model # is JVM231BL001 (1994)... not sure how the above got listed on my original question. I couldn't find this model # on GE's website or the actual model. The MW works fine but is annoying that the under cabinet lights don't work when cooking at the stove.
    Genius:
  • 1,340 Answers
Here is what I have so far.Not related but BS about how they don't want do it yourself done.
http://www.geappliances.com/search/fast/infobase/10000260.htm
I am going to keep looking anyway,hang on please.Since yours is so old it may or may not have this surge protector which,if bad,obviously would not give power.
http://www.geappliances.com/search/fast/infobase/10000724.htm
Here is the only fuse reference I could find in 15 pages so far.
http://www.geappliances.com/search/fast/infobase/10001087.htm
However I did find a sneaky loophole which should help.You obviously know electricity/electronics so here it is.Wiring diagram location! :()
http://www.geappliances.com/search/fast/infobase/10001188.htm
Good luck.Depending on what you may find,you may want to consider a newer one too and if you end up finding what part you need,obviously weigh out the difference of repair/replace.
  • 1 more comment
  • Greg McCarthy Aug 05, 2010
    How did you measure continuity?Do you have a multimeter or just a voltmeter?
    If you checked it with a voltmeter,0 means it's good,anything other than 0 means it's blown.Sorry,just trying to figure out your knowledge.
    ...probe on each end of the fuse while it's on.
Why if you put in a new light bulb the light bulb does not go on
It is because the light bulb may not be the problem to begin with. You should check the light bulb socket and related wiring and connectors for any cold solder joints.
If you have a multimeter you can check to see if there is any AC voltage going to the socket. If you don't know whast your doing then I would suggest you get someone that does. Remember your dealing with 120 volts.
good luck
Apr 07, 2014 | GE Profile Spacemaker 1.8 Cu. Ft....
JVM1340WW 003 heard pop now bottom lights do not work.
MAKE this test and fix it. God bless you
  1. Light bulbIf your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  2. Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction.
Nov 01, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave heats, but the turntable and lights don't work
see the chart for light 1)
  • Light bulbIf your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  • Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction
  • 2) the carousel inside your microwave won't turn when you run it, the small motor that operates it may be broken.
    God bless you
    Sep 30, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
    GE Spacemaker Microwave lights flicker on then off
    There must be a short in the wiring between the bulb sockets and the power supply or control board. Otherwise the short may be in the bulb sockets themselves.
    I would test the connections to make sure the wires aren't loose and all solder joints are tight. If all wires look good, and bulb sockets are tight, then the problem may be faulty capacitor
    Jul 09, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
    Need new light bulb socket for GE spacemaker mircrowave
    The bulbs are glued in at the factory. Unplug the microwave and see if you can remove the base of the bulb from the socket with needle nose pliers. You may have to twist the heck out of the bulb base but it should come out. If you do need a new socket it is available at www.geappliances.com under parts and accessories. Or call 1-800-626-2002 for GE factory parts
    Dec 20, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
    Ge profile spacemaker XL 1800 undercabnet microwave
    Remove the light cover /filter opening.Its very easy to remove.The filter will be removed by hand and may give you the best reach.
    Please rate this !!
    Sep 10, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
    Need GE Spacemaker parts..
    SEE http://tinyurl.com/gv383
    We're happy to help and we appreciate your thoughtful rating of our answer.
    Jun 20, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
    GE Spacemaker XL1400 - lights underneith don't work.
    Check power outlet and breaker , recock breaker .
    Open oven fuse test both end , test power cord both, if those testing point okey , try plug power and test it .
    Jan 17, 2008 | Samsung MW1030WA Microwave Oven
    GE Spacemaker JVM1640SJ Microwave Oven Logo
    490 people viewed this question
    Top GE Microwave Ovens Experts
    William Miller
    William Miller
    Devabhakthuni...
    Devabhakthuni...
    vince
    Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
