Question about Coleman Powermate Powermate 5000W Generator
Need manual for coleman powermate generator model #pm054305.03 bought several years ago - it is powerbase of 5000 watts and 6250 surge has a briggs and stratton engine model #19G412 type 1100-e2.code 0003221 B
5 Suggested Answers
CarlGehrke
  • 169 Answers
SOURCE: Hello I have a coleman
I can't get a wiring diagram or a manual without the model. type, and code off the engine.
What I can do is describe the usual wiring and see of that helps.
The ones I've worked on have a very simple wiring harness,
a black wire runs down into the front of the engine, this is the kill wire that attaches to the ignition module (coil), the other end of the kill wire connects to the center terminal of the on/off switch.
A white wire runs from the switch to the oil shutdown module, at the switch it's connected to the terminal that's closed when in the run position. The other switch terminal connects to a wire that runs to the frame ground. The gray wire from the oil sensor module connects to the oil sensor on the side of the engine.
That's pretty much all of the wiring there is for an engine that doesn't have electric start.
Rate me please,
Carl
Posted on Dec 03, 2008
  • 10 Answers
SOURCE: misplaced User Manual for Coleman Powermate 6250
I would run a search on line for your model number. I will look and let you know.
Posted on Feb 03, 2009
SOURCE: Need to know about this
To find a manual for this generator go to powermate.com and search your model and serial number. Good luck!
Posted on Mar 16, 2009
  • 197 Answers
SOURCE: I'm looking for the 2 cycle oil to gas dilution
20:1 that's 1/4 pint to a full tank of fuel.
Posted on Jan 17, 2010
I cannot locate the owners manual for my Coleman PowerMate 6250 generator 10 hp? Any place I can find this online quickly thank you
Most PowerMate manuals are available here: http://www.powermate.com/productmanuals.php?cat_id=3 . However, describing it as the PowerMate 6250 10 HP generator is insufficient to find the correct manual. The Coleman PowerMate line has several models with 10 HP engines and a 6250 Starting Watt (5000 W running) capacity.
These include the Powermate PM0435005; the direct link for this manual is http://www.powermate.com/pdfs/2011/12/29/pm0435005.02.pdf .
Please add a comment with the actual model number of your generator if you need further assistance with finding the correct manual for your generator.
I hope this helps.
Sep 05, 2017 | Coleman Electrical Supplies
Power cord does not retract immediately
Coleman Powermate Generator 5000 Watts / 6250 Watts ...
? 3:27
https://www.youtube.com/watch?v=IROa5QfPqkU
Nov 8, 2012 - Uploaded by Carlos Roman
This 5000 watt generator is great for backup power at home or forpower ... Coleman Powermate Generator 5000 Watts / 6250 Watts ... This feature is not available right now. ... folding handle, 1 quart, of oil, and 25ft generator convenience cord. ... How to convert a generator recoil starter to an electric starter!
pull cord won t retract Power Generators Questions ... - Fixya
www.fixya.com > Forum > Tags > pull cord won t retract
Power Generators pull cord won t retract questions and answers. Ask your pull cordwon t ... Question about Powermate Powermate 5000W Generator. 2 Answers · I was running my coleman powermate 6250 gen power ... cord 6250 trips out ... The pullcord does not rewind onto the pulley when pulled. At first I thought it was ...
Best Portable Generator Reviews
Feb 03, 2016 | Coleman Powermate Powermate 5000W...
What weight oil do I use for a 5000 watt Coleman generator
Depends on the temperature where yuo will operate it, but a good multi-viscosity oil like 10W-30 should work. 5W-30 for cold climates.
Sep 07, 2014 | Coleman Powermate 5000 Portable Generator...
Can I install a avr (automatic voltage regulator) on my coleman 6250 (5000 watt continuous) gen set with a subaru engine. I know that some of the models come with the avr and some do not. mine did not have...
This is really not something you can do. There is a fair bit of engineering that would have to be done and then there is wiring and mounting, etc.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Sep 10, 2009 | Coleman Powermate Powermate 5000W...
Misplaced User Manual for Coleman Powermate 6250
Feb 02, 2009 | Coleman Powermate Premium Plus 6250W...
How many gal tank is the Powermate 6250 10 KW
Nearly all of the Powermates have the same 5 gallon fuel tank.
I'm a little confused, the Powermate 6250s are all 5Kw generators with 6250 watt surge ratings. Is yours really a 10Kw or did I misunderstand which generator you have?
Carl
Dec 12, 2008 | Coleman Powermate Premium Plus 6250W...
Need to know about this generator. Coleman Powermate 6250 Gen power 305 5000 running watts Model PM0545008 Serial # E06601199B
Dec 05, 2008 | Coleman Powermate Premium Plus 6250W...
Coleman Powermate Powermate 5000W Generator Logo
193 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
