Question about Whirlpool Kitchen Ranges
I am trying to clean my oven and an error message keeps saying e1 f-5
  • Anonymous Nov 24, 2008
    I am trying to auto clean my oven - getting message e1 - f5. Can you help?
  • hyphen1 Mar 04, 2009
    I have a Whirlpool range and I am trying to use the self clean feature however I receive the error message E-1 F-5 and am unable to proceed with cleaning.
    Can anyone help?
I turned off the braker, counted to 20 then flipped it back on worked great for a Whirlpool electirc range
Posted on Mar 04, 2009
Used self cleaning process on my oven yesterday and today the oven will not turn on, we keep getting message to unlock the oven door even though it is. What can we do?
The oven gets extremely hot during the self-cleaning mode... the door switch might have got stuck in locked position, or broken in locked position (to be replaced), let's hope it's just stuck...which you'll need to work the mechanical lock-unlock latching back and forth to hopefully unstick....and if that doesn't work just re-run self-cleaning process but this time let the oven cool completely before unlocking the door. Hope this helps.
May 11, 2014 | GE Ovens
Keep getting a message that says 'remove probe' but we don't have a probe in. Hit 'cancel' and tried reducing the temp on the oven when this message came up ('remove probe'). I hit 'bake' and tried to...
You might want to try and use a q-tip and some rubbing alchohol and try to clean the inside of the probe connector in the oven. Some liquids or something might be in it causing the control board to think the probe is connected. Make sure to do this procedure with the range unplugged. Then wait about 20 minutes before plugging the range back in. Hopefully that will stop the issue. If not could be a control board problem.
Nov 26, 2009 | Ovens
F8 error message on Dacor gas range
Look for the error code in the troubleshooting section of the owner's manual. Otherwise, search for:
Make Model error code F8
Sep 29, 2017 | Kitchen Ranges
My oven is giving me an F 3 error
an F-3 error message usually indicates a problem in
: the oven temperature sensor or its wiring circuit.
Jan 19, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Tried to selfclean my NEW oven but get error message F5E1
Reading all the questions and responses - I had the same problem (would press "self clean", it would run for less then a minute then give the error message), so once I saw the code was E5F1 and what it meant (thanks for whoever posted that), I just pressed on the door for the first minute of the cycle, and self-cleaning then worked. Go figure :)
Jan 06, 2009 | Whirlpool RF378 Electric Kitchen Range
E4 message and what to do to clear it
That may be it. In some cases you can clean them, but if it has become brittle, it may snap. But it's worth a try.
First of all, I'd try a cold reset by unplugging the oven for afew minutes then trying again. If that doesn't clear the error, it's probably the thermistor.
The oven would have to be removed from the wall so the outer wrapper can be removed, then you can remove the sensor and attempt to clean it.A gentle scraping with the toothpick might work, or gently soaking it in hot water. Just be sure it's dry when reinstalled.
If needed, you should be able to order a new thermistor here:
http://www.samsungparts.com/search/search.asp
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 14, 2008 | Samsung SMH7178STD Microwave Oven
Canon i320
Try unticking ENABLE BIDIRECTIONAL SUPPORT on the Ports Tab under Printer Properties accessed through control panel / Printers and Faxes. Try to print - get error message Enable Bidirectional Support. Reverse back into Ports Tab and re-enable Bidirectional Support and try printing again.
Jan 13, 2008 | Canon BubbleJet i320 Printer
Kitchenaid glass top electric range
I have the same problem...stuck key err F2E0
Can any one please tell me where is the sensor? I mean which part of the oven have sensor, is it inside or under the button control panel?
May 27, 2007 | KitchenAid KESC307 Electric Kitchen Range
Kitchen Ranges Logo
57 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
