Question about Sony (XL-2400) Projector Lamp for KDF-E42A10, KDF-E50A10
Lamp projector tv off and on model KFD-42E2000
  • 525 Answers
Remove the lamp and order an other one!!! you can use Google to find replacement lamp
Posted on Aug 05, 2010
How do I change my projector lamp?
Instructions
  1. Front Projector
    • 1 Disconnect the power cable from your projector. Allow it to cool for 30 to 60 minutes. Lay the projector upside down on a table.
    • 2 Remove the lamp cover, typically located on one of the rear corners of the projector's underside. Depending on your projector, you will either have to loosen a few Phillips screws or press on one or two plastic release tabs to remove the lamp cover.
    • 3 Loosen the screws holding the lamp assembly in place. Grab the assembly by the handle and slide it out of the projector.
    • 4 Slide a new lamp assembly into the projector. Don't touch the glass on the bulb because it will damage the bulb. Tighten the retaining screws on the lamp assembly and replace the lamp cover.
    • 5 Turn the projector right side up and reconnect the power cable. Power on your projector.
    Rear Projector
    • 6 Unplug the TV from the outlet. Let it cool for 30 to 60 minutes.
    • 7 Remove the lamp cover. On most rear projection TVs, the lamp cover is located on the right or left side of the TV's rear panel. Remove the cover by loosening the screws and pulling the cover away from the TV. Certain manufacturers, like Mitsubishi, have the lamp cover in the front of the TV, near the left speaker. To get to the cover, you must first use your fingers to pry off the front panel below the screen, revealing the speakers and lamp cover. Loosen the screws on the cover and pull it away from the TV.
    • 8 Remove the lamp assembly. Loosen its screws, grab the handle and slide it out of the TV. If you have a newer Sony model, there are no screws. Instead, press the release tab to unlock the lamp assembly and slide it out of the TV.
    • 9 Slide a new lamp assembly into the TV. Don't touch the glass on the assembly, as the oils in your fingers will damage the bulb. Tighten the screws or pop the retaining tab into place.
    • 10
      Replace the lamp cover and front panel, if necessary. Plug your TV back into the electrical outlet and power it on.
Tips & Warnings
  • Touching the lamp assembly before it has cooled can cause a nasty burn.
Read more: How to Change a Projector Lamp ' eHow.com http://www.ehow.com/how_7307928_change-projector-lamp.html#ixzz1rpURlpva
Apr 11, 2012 | Office Equipment & Supplies
I have a Sony TV - KDF-42E2000 and the lamp went out. Replacing the lamp looks to cost around $80 but replacing the lamp with all the housing for it is around $250. Do I really need to replace the...
I have a sony KDF-42E2000 and our lamp went out a yr after we purchased it. I found the lamp with out the housing on eBay and there was a video on how to take the old lamp out of the housing and replacing it with the new lamp. Now I am a female with NO experience with doing that type of thing, but I was able to do it with ease. So you can swap just the bulb. Also we just had to replace the lamp again and this time on eBay there was the lamp with the housing for 91.00. Easy as pie... But now the problem is that there is a red band across the top of the screen. Just got off the phone with Sony and they said that to fix it, it was going to be around 1K but they will let me choose between 2 different TV's at a reduced price. Apparently there has been a lot of issues with the TV's to the point where this is what the specify in the email: In consideration for Sony making and you accepting this offer, you agree to release and hold harmless Sony Electronics Inc., and its affiliates, officers and directors from any and all claims for damages, loss, cost, expense or liability both known and unknown, which you may have incurred in connection with your television.
So no matter what you decide as far as lamp vs lamp and housing, be aware you might end up contacting sony at 800-200-SONY to get an offer of a discounted tv.... Good luck!
May 20, 2011 | Sony KDF42E2000 42" HDTV
I just put a new lamp in my projection tv.....it is a kdf-42e2000....now there is a pink line on the top of the screen and a blue line on the bottom of the screen......the lamp i installed was a XL2000...
HI ,
I Advise to fixed that Lamp again ( sometime you fixed but one of any wire miss connectivity ).
Or Remove and fixed again all related Jack's you removed lat time.
If everything's OK , then Change lamp. try other one.
Shahzad - IT
DUBAI - U.A.E
Mar 12, 2011 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony kdf-42e2000, lost picture and the 3 red lights started blinking. I did all the troubleshooting that have worked in the past, but no luck. Any ideas???
Maybe it's time to replace the lamp, have you ever changed the lamp on the TV before? If not, I recommend you do it, because it might be the main issue. Another thing can be the inverter board but you'll never know until you put another lamp in the TV and see for how ling it works, If it lasts less than 4 months, it will definitely be that board.
Dec 06, 2009 | Sony KDF46E2000 46" Projection HDTV
Sony kdf-42e2000 tv red light blinks 3 times
3 blink error shows that lamp cover is not fixed properly after lamp replacement.
Please check Lamp Cover and put it back properly.
Nov 14, 2009 | Sony Televison & Video
I need to replace my 42 in Sony WEGA HDTV Projection lamp KDF-42E2000
Lamp code XL-2400 is Sony part number F93087500 and it is available on http://www.partstore.com/. You may also decide to purchase the less expensive Philips Lighting lamp part number F93087500RL. Either will work for your television set.
Jul 19, 2009 | Sony Office Equipment & Supplies
Set timer
You did not post model number of TV so try below method to reset lamp timer.
Turn TV ON, Press and hold Volume minus button on TV and press Split/ Play button on remote for 6 seconds, lamp reset message will appear on TV screen.
Jul 02, 2009 | Panasonic TY-LA1000 Projector Lamp for...
Continuity test for a projector lamp?
2. Projector lamps CANNOT be tested with an AMP or OHM meter. Projector lamps function by igniting ultra-high pressurized mercury vapor accross an ARC tube. At the point where the mercury vapor resides there is no conductive electrical material and therefore testing a projector lamp with an AMP or OHM will not work.
Jul 21, 2008 | Samsung - Projection TV replacement lamp...
Sony (XL-2400) Projector Lamp for KDF-E42A10, KDF-E50A10 Logo
110 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
