Question about Frigidaire FRS26ZSG
The dispenser auger turns but is not dispensing any ice. The auger turns freely and sends ice toward the front of the bin but nothing comes out. What can be done to fix it? Does the blade toward the front of the auger need replaced? It seems to rotate easily on the auger and I'm wondering if that is the problem. If so, where can they be ordered and how does one find the part #?
  • Frigidaire Master
  • 43,501 Answers
You have a cube of ice jammed between the rings of the auger...this stops anymore ice from moving out of the auger...
remove ALL of the ice from the tray and the auger and then let it refill... then it will work again...
heatman101
Posted on Aug 05, 2010
Howtofixicemaker
First, is the auger drive operating when you press the dispenser lever? Is the ice frozen into a clump in the bin and isn't breaking loose into smaller pieces capable of dispensing? Is there frost around the ice dispensing chute (just above your glass) or inside the ice bin (near the very front) indicating an air leak? Is the bin installed properly so the bin auger drive is connecting to the bin auger?
Knowing these answers will point you in the right direction to solve the problem.
Sep 13, 2014 | Amana Refrigerators
The ice maker will not dispense any ice. When the dispenser lever on front panel is pushed the dispenser door opens but the auger motor does not operate. If I thaw the freezer the auger motor will...
It sounds like your auger motor has an issue in my opinion. How i check them is: remove ice bin, open freezer door, hold door switch down, depress the freezer ice dispenser button on the door and see if the auger motor has the torque when it turns, if the motor has power and turns but cant turn w/ torque or has power and dosen't turn. you need a new auger motor. lmk if u need more help!
Aug 04, 2013 | Frigidaire FPUS2686LF Professional 26 Cu....
I have a GE Profile Artica. Dispenser is not dispensing ice even though ice bin is full. When i press the for ice to dispense , the light dims and the compressor stops.
Try taking out the ice bin press the door light switch and dispense ice button at the same time and see if the motor bracket turns without the ice bin in place. It is possible you have ice in the bottom of the bin that is frozen and jamming the movement of the auger. If not the problem may be a defective auger motor=> WR60X10259 Auger-Motor
I will be here should you have questions, Sea Breeze
Mar 01, 2013 | GE Refrigerators
Whirlpool ed5gvexvdoo side by side When using the ice dispenser (cubed or crushed) it will not dispense. I have pulled the ice tray and the motor for running the dispenser arm runs. I have emptied the tray...
this maybe a problem with you auger motor may be stripped.open the door remove the ice bin.then hold the metal u shape auger arm and try to turn it by hand or have some one try to dispence ice if the u shape braket turn easy ny hand or if it stops turning when being held replace the auger motor.i hope this is some help,good luck you may also have to replaced the ice bin.
Jan 22, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool side by side GD27DQXFW01; ice cubes are not dispensing
We will need to check the voltage at the auger motor while depressing the dispense switch. If all the other features work on the dispenser panel while I would consider checking the voltage going to the motor. Some auger motors are in areas where water causes the voltage to be shorted by constant moisture. We will need to remove the panel and simulate what you have done on the outside but this time we need to see if the voltage has been altered or if the auger motor itself is defective. Sea Breeze
Oct 10, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Matag fridge msd2351hew icemaker ice and water work and cubes come of crushed ice dispencer. There is a capacitor connected to auger motor.Is this the problem? There are no other electrical parts.
If you remove the bin and look on the bottom of it you will see a rod running from front to back,this opens and closes the crusher see if it moves freely, if not dump the ice and rinse the bin out with hot water till it moves freely,if so,with the door open set the dispenser to cubes leave the bin out push the light switch in and hit the  dispenser button you should hear a loud pop and see the actuator by the auger motor move up,and drop down when you release it.
Aug 22, 2009 | Maytag Refrigerators
Ice dispenser not working
Pull out auger & try With Out auger in place with door open and see if auger motor will spin with out auger and tray IN.. you with have to push door switch in to get auger to work .. with door open
Sep 12, 2007 | KitchenAid Architect ® Series II KSRX25FT
FRIGIDAIRE SIDE BY SIDE ICE DISPENSER
Have same or similar problem. MY problem turns out to be that the Auger turns fine, but there is a little metal blade that attaches to the end of the auger and transfers the spin action into this auger "hopper" (for lack of a better term) which actually accepts the ice that has been moved from the back of the ice bucket by the metal auger and then dispenses the ice into the hopper which falls into the glass. the issue is one of crappy design. It turns out that this little blade has a rectangular opening in the middle that the rectangular end of the auger fits into. If this rectangle opening gets stripped (as mine has done, and ALL are likely to do) then the auger spins, the ice is moved forward but none are picked up by the hopper, and none (or very few) fall into the glass.
Everyone should check to see if this is the case. If so you may need to order a new blade, or a new auger, or a new refrigerator.
Good Luck!
Aug 10, 2007 | Frigidaire FSC23F7D Side by Side...
Scorpio, remove the ice bin itself, dump the ice and see if you can move the bin auger by hand by turning the actuator in the rear. If the bin is ok, with the door open and the door switch held in see if the auger motor is turning when pressing the ice lever. If it's not turning the next logical step is to see whether the auger motor is getting voltage when calling for ice. Make sure the door switch is closed. The part number for the auger motor on the posted model is wr60x0202. Hope this gets you going..Catriver.
Jul 23, 2006 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerators Logo
270 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
