Question about Canon EOS Digital Rebel XS / 1000D IS Digital Camera
My 1000 d does not work in AF mode. The flash fires several times a word appears busy. Siapa poer not to take the pictures
  • 94 Answers
Its main board problem eighter you can solve with special tool with latest service firmware update
or you can replace new main pcb,
Posted on Aug 08, 2010
I just put new batteries in my N65. I haven't used it in a while but it appeears to be working proper, ie the lcd comes on and indicates full battery and the view finder symbols are nice and bright green...
What I'm thinking is the shutter and or the aperture ring is lazy. Move the aperture ring up and down several time see if the little ring next to the the camera body is responding quickly to the change.
Do this without film in the camera.
What I'd suggest is setting the camera in "M" mode aperture at F8 manual set the ISO at 100 and the shutter speed at 1/60 shift the camera into manual focus. The shutter can be in AF-S (single frame with each depress of the shutter). Trip the shutter and listen to it work do that a few times (maybe three) then set the speed at 1/125 do the same test listen the shutter should sound faster. Repeat the test at 250 then 500 then 1000. Then start backing down to 1/60th again, listen to the response. In all manual mode the shutter has to fire it it isn't or the speed doesn't increase and then decrease then the shutter needs service.
Jan 14, 2011 | Nikon N65 35mm SLR Camera
Hi I bought my canon 1000d on september 2009 and a year later the autofocus doesnt want to work. In the viewfinder on the far right a number 9 has a green dot flashing next to it. Please help!! Ruthven...
The 9 you see is the maximum "burst" which is (pictures made in rapid succession) and is not an issue with your problem at this time the flashing green dot is the in focus confirmation light and it's good that you are seeing this as we will use it to remedy the problem.
Diagram
Manual focus switch
Diagram here
What I want you to do is put the AF-MF switch in the manual mode if it's already in manual mode then that was your problem switch to AF and go take some pictures. If it's in AF mode switch to MF make sure teh camera is on and look through the viewfinder at a subject say 15 feet (4.5 meters) away something that has contrast then turn the manual focus ring on the camera slowly until it appears to your ey that it's coming into focus when it's in focus the green light will come on solid, now you know what you are looking for focus an several different objects at different distances and focus manually. Now switch the lens over to AF (auto focus) and focus on the same thing but let the camera do the focusing What auto focus will not focus on in something with little or no contrast like water clear blue sky a painted wall mirror chrome glass and a few other things.
Here is another diagram to check make sure you are in the correct mode.
Diagram
Now for the focus point in the viewfinder make sure it's in the center position.
To adjust the focus point do this
Once you have the camera set to the center focus point and the correct AF mode (one shot) auto focus should return to your camera. Have fun Robert from London Ontario Canada
Jan 10, 2011 | Canon EOS Digital Rebel XS / 1000D IS...
The flash is not very brightthe test button fire the flash just fine..but when i fire it when i take a picture the light is very weak
Are your pictures properly exposed?
Does this flash have power settings on the back? If so, move it back to full power.
If your pictures are properly exposed then its doing what its supposed to.
If no power setting on the back, check what ASA you have it set for. 800 or 1000 speed film requires much less light than 200 speed film. Adjust ASA based on your film.
Sep 19, 2009 | Sunpak 355-AF for Minolta Flash
I have three new Metz 58 AF-1N's, and a Nikon
take a silver paper and put in front of the slave censer when you take the photo flash on camera as master should go on silver paper OR used slaveunit
Jun 30, 2009 | Metz 58 AF-1 FLASH f/NIKON TTL Flash
How to retrieve current radio code for my 2004 chevy aveo?
Here's an easier way. Purchase a 9 volt battery powered radio / computer MEMORY RETAINER. Plug into your cigarette lighter/power socket SECURELY. AFTER replaceing the battery, remove 9 volt poer feed, and BINGO. Radio stations memory, clock will all RETAIN. their memory. Hope this helps
Apr 19, 2009 | 2006 Chevrolet Aveo
Nikon D90 Self-Timer does not work when flash is engaged.
The answer to your question can be found at...
This website
All but the very best flashes can not recycle atthat flash rate. For burst mode, you probably want to use focus modeAF-C or AF-A.
Morris
Page 73 in the manual; If the flash fires in L or H mode (pg. 65), only one picture will be taken each time the
shutter-release button is pressed. The shutterrelease may be briefly disabled to protect the flash after it has beenused for several consecutive shots. The flash can be used again after ashort pause.
The flash can take several seconds to recharge andduring that time the shutter is disabled. NR will also reduce thenumber of frames per second that you can take, and of course yourshutter speed has to be fast enough to allow for 4.5 fps.
In AF-S the shutter won’t fire unless the camera has achieved an in-focus state and the focus is locked.
In AF-C the camera continually focuses, but that isnot the same thing as being in focus. As you move the camera or yoursubject moves, the in focus state will come and go, but the camera willattempt to continuously re-focus. BUT, the shutter will fire even ifwhen the AF system has lost the in-focus state and the picture is outof focus.
In the D90 manual it indicates that the AF-A modewill only fire when the green in-focus light is on, just like in AF-S.The problem is that you probably won’t get 4.5 fps unless both thecamera and the subject are stationary and no time is lost between shotswhile the camera re-focuses.
Brooks
http://bmiddleton.smugmug.com/
Mar 06, 2009 | Nikon D90 Digital Camera with 18-105mm...
Canon 40D LCD Wont come on buSY flashes in view finder
Okay, this is simple. Your camera can take several pictures at one time in a burst. However when you release the shutter button your processor takes a second to actually SAVE the pictures to the card in the camera. One thing than has helped me in my wedding photography business is to buy the fastest speed cards I can find. It significantly reduced my "busy" time.
Nov 30, 2008 | Canon EOS 40D Digital Camera
AF area mode problem
To answer your flash question...the Nikon flash system fires the flash when the camera thinks the picture will be too contrasty without the flash. You can Google for "fill flash" to learn more. This is usually beneficial; if not, holding the flash button and turning the main dial will cycle through flash options on the top screen.
Jul 17, 2007 | Nikon D50 Digital Camera
Flash out of sync
I just had mine fixed by nikon and it seems as though the problem would come back every now and then. my current solution is to switch over to Manual mode and turn AF assist, AF illumination, and ISO control to "ON" and then then shoot a few shots. Then switch metering to centerweight. take a few shots, it should work correctly, then switch back to AUTO. after that, the flash should fire as normal. I just received my body back about 2 weeks ago, so i hope my "bad batch" flash unit was replaced with a known good one. if not, i don't know what to do.
Sep 18, 2006 | Nikon D50 Digital Camera
Canon EOS Digital Rebel XS / 1000D IS Digital Camera Logo
103 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
