Question about Car Audio & Video
Honda CRV Radio Code Error
I finally received a code to reset my anti theft code on my radio. I pulled the 10 amp fuses out of the fuse block and then re-insert them (this was suggested online here at FixYa) and the system still reads Code Error in window. What should I try next?
  • Anonymous Oct 03, 2008
    05 CRV battery went dead, replaced now radio reads error e. Used vehicle no owners manual. No code in glove box. Windows need to be reset? what else needs attention?Christine,
  • Anonymous Mar 27, 2009
    I got the error E also. i did what it says in the instruction manual to fix the problem ex. Disconnect the battery or leave the unit turned on for an hour but neither works
My car (2005 Honda CRV) was shipped overseas and the radio asked for a code. After several tries, I searched the internet for a solution. Apparently Honda now allows you to obtain the code through their provided website. You will need the VIN #, the phone number and zip code that is on file when you purchased the car. Our car was purchased used and did not come with a manual. When I went to enter the code in I had already entered too many tries, now it reads ERROR E.
However, even before having the code (as well as now that it reads ERROR E) I can get the radio working. Push in preset buttons 1 and 6 and push in the power button simultaneously. A long number appears - at that point I pushed preset button 2 and the radio operated normally. Unfortunately, I do need to do this each time I turn the radio on.
Posted on Oct 16, 2008
I had Error E code which means I put the wrong code in 10 times. Honda says 2 ways to fix this. In the fuse box under the hood, remove the "Backup" fuse for 1 minute and 10 seconds(or 2 minutes) then replace. If this doesn't work,place key in ignition and turn to the FIRST position. Allow key to remain in this position for ONE HOUR(to be safe, try 1 hour 2 minutes.)
Turn key to second position and the errors should be erased and the CODE will come up. Put your code in and the radio should work.
I still have 45 minutes!
Posted on Nov 20, 2009
I have a 2009 CR-V EX-L, the battery went dead and I got the "Code Error E" message. I did not know where the reset code was, so I went to the dealer. The guy at the desk found the code in my service book. He tried to re-set and couldn't, then he removed the "backup" fuse for 10 mins and re-installed The Code Error E was still there. I couldnt leave the car so I left. I tried removing the "Backup" fuse, while it was out I checked the radio, still had power, just the door locks didnt work. Finally I disconnected the battery for 10 mins, when I re-connected and turned on the rado, I had the option to enter the code, I did and it worked. Note that the owners manual said after an hour you would be able to re-enter the code if you got the Code Error E message, but that did not happen. Only thing that worked was disconnecting the battery.
Posted on May 24, 2010
  • 10 Answers
You need to put 4 or 5 digits number that can be found in the glove compartment do not touch anything in the radio could lock the radio for 12 to 24 hours simply enter the numbers using the radio buttons and it will be fine don't go to the dealer they will charge you over 200 for one minute fix that you can do it by yourself
Posted on Aug 16, 2010
  • makeler
    makeler Mar 25, 2013
    You're awesome! I fixed it myself...couldn't have done it without you. :-)
  • John Kirby Sep 30, 2013
    Yep, worked like champ...
If the radio is the one in the CRV when it was assembled, radio code will be on the underside of the fuse block cover under the hood.
Posted on Sep 19, 2009
  • farhaan May 21, 2013
    the number should be between 1 and 6 or it has number mixed with alphabets?
21 Aug 2010 I have an 03 Honda S2000 and after a battery changed I managed to put the radio code for my wife's Insight into the S2000 radio instead of the right one - it came up with CODE E. I turned the ignition to the 1st 'notch' and left it for 40 mins. The display then reverted to CODE and I was able to insert the correct code. Simple!
Posted on Aug 21, 2010
To get rid of code error E, disconnect battery or remove fuse for 5 to 10 mins then enter your radio code. If you disconnect for a too short period of time, it won't work.
Posted on Oct 31, 2009
    New Friend:
I followed the above and every time I put the 5th number in it went back to error. When I put the first 4 numbers in it spelled c.o.d.e
I found that it worked if I:
took out the backup fuse
Put it back in a minute or so later
Entered the first 4 numbers
Turned radio off then on again
Entered the 5th number.
Hey PRESTO!
Posted on Apr 28, 2016
  • Anonymous Sep 13, 2016
    same thing happened to me. Followed this suggestion and it worked!!
    New Friend:
The best way I've found to get a radio code for a Honda CRV (Any Honda in fact) is by using the below website. It's free and will show you how to get a radio code for your car.
Free Honda CRV Radio Code ' FreeRadioCodes
Posted on May 21, 2016
I got the codes for my radio and they didnt work. Dealer thinks someone swapped out the radio. Now I need to remove the one thats in there, find the serial and start all over
Posted on Jun 24, 2008
I changed out my battery. Now my radio is not working. Fuse is OK. Ideas?
Most newer cars have a feature that if power is interrupted to the radio (blown fuse, battery disconnect) it will cease to function without the insertion of a reset code. This code is usually on a card in the owner's information package. IT is intended as an anti-theft precaution, since without the unique code, the radio is worthless. If you don't know the code, or didn't receive it, a dealership can usually provide it if you can give them the serial number of the radio. This will, unfortunately, usually involve the removal of the radio to obtain.
Oct 02, 2015 | 2003 Porsche Boxster - All Boxter models -...
My radio isn't working we changed the battery just this morning and now the Radio doesn't turn on at all.
radios have an anti theft device in the system that cuts in when the battery or the radio is removed or disconnected
If the radio is factory fit and not very old you should be able to get the code from the dealer
if not there are free download sites that have radio codes for all makes and models
all you have to do is search your make of radio, model of car and if you have it the serial number of the radio
Jul 01, 2015 | 2003 Ford Escape
My stereo is saying err3 and i dont know the code to my 98 acura, can someone please help me?
This is due to the anti-theft in the radio. Open the fuse box under the hood, pull two fuses; radio and radio back-up, put the 2 fuses back in. Turn the radio ON, it should ask for your code. Pull out the ash tray and see if you have the 5 digit code there. Enter the code and the radio should now work.
Jun 20, 2011 | 1998 Acura CL
I don't have a cover for my fuse box and need to
Thanks for the inquiry.
Fuse Numbers and Locations:
EXPLORER FUSE PANEL Fuse Position Rating Circuit Protected 1 10 Amp Power Mirrors/Antenna 2 10 Amp Air Bag/Blower Relay 3 15 Amp Parking Lamps 4 15 Amp Left Headlamp 5 10 Amp On Board Diagnostic II System 6 15 Amp HO2S Sensors 7 10 Amp Illumination Switches 8 15 Amp Right Headlamp/Fog Lamp System 9 10 Amp EATC Mem./Seat Mem./Mess. Ctr./Cell. Phone 10 10 Amp EATC Sys./Rear Blower/Spd. Control/GEM Sys./Brake Interlock/OH Console Adapt. Susp. 11 10 Amp Warning Lamps 12 10 Amp Front and Rear Washers 13 15 Amp PCM Sys./Stoplamps/4WD/
ABS/Spd. Control/Trailer Tow 14 10 Amp Anti-Lock System 15 15 Amp Air Bag System/Alternator 16 30 Amp Front Wiper 17 30 Amp Cigar Lighter 18 15 Amp A/C System 19 25 Amp Ignition Coil/PCM System 20 10 Amp Radio/Power Ant./GEM Sys./Anti-Theft/Cell. Phone 21 15 Amp Hazard Lamps 22 15 Amp Turn Signals 23 15 Amp Rear Wiper System 24 15 Amp Starter Relay/Anti-Theft 25 10 Amp Speedometer/GEM System 26 15 Amp A4LDE Trans/DRL Sys./Backup Lamps/4WD/Rear Defroster 27 15 Amp Under Hood LP/Map Lights/Glove Box Lamp/Dome Lamp/Visor Lamps/Accessory Delay/DR Switch Illum./4x4 System 28 10 Amp Memory Seat/GEM System 29 15 Amp Audio System 30 - Not Used 31 10 Amp Aux. Blower System 32 10 Amp Heated Mirrors/Heated Backlite 33 20 Amp High Beam Lamps 34 10 Amp Audio System/Power Antenna 35 - Not Used 36 - Not Used
Hope this helps helps. Please keep us updated and remember to rate this answer.
Kind regards,
TF
Jun 05, 2011 | 1995 Chevrolet S-10 CA Edition
I can't turn on my radio the dispaly says THEFT
I'm guessing that you disconnected the battery recently! but if you contact your dealer they can pull the code for you, you may have to take it to them so they can connect the scan tool and get the code that way!
Mar 30, 2010 | 2001 Chevrolet Blazer
Check engine light comes on intermittently. Code 14, replaced air idle control valve. Ck engine light still comes on. What the problem?
If you are secure that the repair was done correctly, pull the 7.5 backup fuse (with the car turned off) in the under hood fuse box and wait 10 or 15 seconds before putting it back in. That should clear your engine light. You will have to reset your clock, and any selected radio settings.
If you do not have an anti-theft radio, you could simply disconnect the negative battery terminal for 10 or 15 seconds and that would do the same thing, but if you have an anti-theft radio that would require a code reset, meaning that you would have to have the five digit code.
If the engine light comes back on after the reset, then something has gone wrong with the repair.
Hope this helps.
Oct 26, 2009 | 1988 Honda Accord 4 Door
Me and my dad change the heater hose and now my engine light is on and my drive 4 light in the dash board is blinking what should i do
You can disconnect your negative battery terminal, wait five minutes or so, then reconnect it. This should clear the malfunction code. If, however, you have an anti-theft radio, make sure that you have the five digit code to reset it after disconnecting the battery. Disconnecting only one terminal might not effect the radio, but I wouldn't count on it.
If the malfunction code comes back after you disconnect the negative terminal, then something has gone wrong with your repairs.
Hope this helps you.
Oct 25, 2009 | 1999 Honda Accord
2007 Honda Civic Navigation Screen went black
Had same problem with 2008 Honda Civic.
Note: you will need anti-theft code so get it first!
Solution:
1. Turn ignition off.
2. Look for fuse box under steering wheel.
3. Remove fuse #35 which is for the Navi-audio unit.
4. Then re-insert the fuse. This will reset the system.
5. Turn ignition on and the Navi-audio on. Buttons WILL be working now.
6. The unit will request for the anti-theft code for Navi-audio system. Enter the 4 digit code....Yippee!
However, I lost all my radio preset stations. Thankfully my saved destinations in navigation system were intact.
Apr 02, 2009 | BoxWave Corporation 2007 Honda Civic...
2005 Malibu MAXX car stereo dead, rear radio too.
Please check your owners manual for the location of the 10 amp fuse for the radio. On some models you have to reset the security feature on the radio/CD player for it to work.
The info below has been stated to work on a no go radio. I have not confirmed this procedure.
Remove the lower fuse box cover, with the power off, removed the 10 Amp fuse for the "Radio." the fuse may be good. Fuses are diagrammed in the owner's manual. With the fuse removed, start the car, turn the car off, replace the fuse and turn the key to "ACC" to see if the radio was "Reset."
Would the alarm cause the radio to malfunction? If your Anti Theft lock was activated check your owners manual under radio and check for a 4 number password. Sometimes it is taped to the upper part of the glove box. If you do not have the CODE you will need to take the vehicle to a dealership or a repair center. They use your vehicles vin number get the code.
Jul 21, 2017 | 2005 Chevrolet Malibu
Radio fuse/cd changer
Number Fuse Amperage
Rating
Circuits Protected
7 7.5 amp Illumination switches
8 10 amp Right headlamp, fog
lamp system
9 10 amp Autolamps
10 7.5 amp Rear blower, speed
control, GEM system,
brake interlock,
overhead console
11 7.5 amp Warning lamps
12 10 amp Liftgate wiper/washer,
front washer
13 15 amp Brake on/off switch
14 10 amp Anti-lock system
15 7.5 amp Air bag system,
instrument cluster
16 30 amp Wiper run relay
17 15 amp Cigar lighter
18 15 amp A/C system
19 25 amp Ignition coil, PCM
system
20 7.5 amp Radio, power antenna,
GEM system,
anti-theft
21 15 amp Turn/hazard flasher
22 10 amp Turn signals
23 10 amp Rear wiper system
24 10 amp Anti-theft relay
25 7.5 amp Instrument cluster,
GEM system
Nov 11, 2008 | 1997 Mercury Mountaineer
Car Audio & Video Logo
39,563 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
