Question about Husqvarna Chain Saw 20" Bar
I have a husqvarna 575xp which i bought used.It was running great for 3 weeks when the motor started to race, the stop switch didn't seem to work in this state so i had to use the choke to shut it down. I thought it might had been the air filter so i blew it out and started it with the same problem. Could someone point me in the right direction.
  • nedkelly900
    nedkelly900 Aug 05, 2010
    Have you tried turning the idle screw? The stop switch not working, should have nothing to do with your fast idle problem.
  • inshaper Aug 08, 2010
    No I havent tried the idle screw cause i never adjusted it in the first place but I will turn it in and then slowly turn it out in quater turn incredments. As for the stop switch it was working fine before i had this racing problem.
    Brigadier General:
  • 4,088 Answers
You need to inspect the throttle mechanism at the carburetor. When you pull the throttle trigger, it should move the throttle arm to it's 'full on' stop, and when it is released, the arm should come back to the idle stop screw. If the action seems to be indefinite, take the throttle trigger mechanism apart (make notes of part placement as you go), and clean it of sawdust and dirt. Don't run the engine until the throttle is working correctly. The 'stop' switch may also be full of sawdust, or the connecting wire may be damaged. Make sure the carburetor fasteners are tight as an air leak behind the carburetor can cause engine racing. Hope this helps!
Posted on Aug 05, 2010
Will not start. with starter fluid catches but only runs a few seconds. seems to not get gas. gas fresh.
Check the fuel line. The ethanol gas may have dried out the fuel line enough to have it crack. Many times the gas line brakes at the very end where it connects to the in-tank filter
Feb 22, 2016 | Husqvarna Garden
Husqvarna YTH20K46 no power. HELP!
Not turning off sounds like an ignition switch problem. Not starting - then I think you should check the Low Tension side of the solenoid again to make sure there is current from the switch. If the solenoid's OK, the battery's fully charged with all the connections clean and tight, then it has to be the starter motor or engine. Check you can turn the engine by hand, if so then I would guess, it's probably the starter motor.
Good Luck
Apr 21, 2013 | Husqvarna Garden
I have a husqvarna 36 chainsaw that starts and runs just fine. However, the stop switch doesnt seem to work. I push the switch to stop and the saw continues to run. The only way to kill it is to use the...
Hi
Yeah,your switch has gone bad,and using the choke isn't how you want to kill it for too long.Fouled Plugs.Here's a link to the service manual pdf if you want to do it yourself. Shouldn't be too hard.
Please rate my post?
Bob
http://www.airtimeproducts.com.au/assets/docs/Husqvarna%20service%20Manual.pdf
Aug 13, 2010 | Husqvarna Garden
Tuning of 575xp
The H jet needle controls full speed operation and L controls idle operation. Turn both screws CW to stops (lightly), then back out each CCW 1-1/2 turns. This should allow the engine to start and run. Make sure the fuel filter, air cleaner, and muffler are not plugged. Check the fuel lines for decay or damage. Make sure the carburetor fasteners are tight including the hardware that holds the carburetor to the cylinder. Start the engine and allow to warm up, then pull the throttle full on. Turn H needle CW until the engine starts to speed up--proper setting is when the engine 4-strokes unloaded, but immediately 2-strokes when cutting. Allow the engine to idle and adjust L CW so that the engine runs fairly well, but allows the engine to 'follow the throttle'. Adjust idle speed screw so that the chain stops turning, but the engine continues to run. Hope this helps!
Jun 21, 2010 | Husqvarna Chain Saw 20" Bar
HUSKY WONT RUN?
you are wanting a wiring harness
your best bet aside from ordering one is to buy a service manual from www.ferracci.com or local husqvarna dealer and use the wiring schematic to build your own race harness........don't forget the kill switch.
Oct 05, 2009 | 2006 Husqvarna TE 610
Husqvarna Chain Saw 20" Bar Logo
357 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Tim Whalen
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
