Question about RCA RCU500 Remote Control
How do i program remote for a sony dvd player
  • 146 Answers
If you cannot locate the code for your device, try the code search method below:
Step 1: Turn on the device.
Step 2: Press and hold the "CODE SEARCH" button.
Step 3: Press and release the VCR, TV, Cable or Audio button. If programming for AUX, press and release AUX button first, then press the device type to be programmed.
Step 4: Release the "CODE SEARCH" button.
Step 5: Press "ON/OFF" (or "POWER" for RCU500) repeatedly until the device turns off. Note that because there are so many codes, you may have to press the "ON/OFF" button up to a hundred times (at a rate of once per second) if your code is towards the end of the preprogrammed list.
Step 6: When your device shuts off, press and release the "ENTER" button.
Step 7: With your device on, press another button like "PROGRAM UP/DOWN" OR "VOLUM UP/DOWN" to test, and if it does not function correctly repeat steps 1 through 6.
Posted on Aug 05, 2010
3 Suggested Answers
SOURCE: how to program remote model # RMT-D130A
Found the manual online, here it is:
http://akamaipix.crutchfield.com/Manuals/158/158DVPN600.PDF
Go to page 60. Basically, just hold the TV Power button down, hit your manufacturer's 2-digit code, and release power button. If the code is right, the TV will power off and then back on again. The manual only shows numbers 01-19 in use, so I guess you only have to trial-and-error a max of 19 codes (which is ultimately faster than downloading and opening the manual)! I hope this helps you out.
Posted on Sep 01, 2008
MarkAmaranto
SOURCE: Program code for Sony Blu Ray BDP-S301
1516
Posted on Feb 04, 2011
What is the code for a sony rm-y-183remote for sony dvd player dvpsr200p
The remote code for Sony DVD could be 751.
For detailed operating procedure and other codes for this remote see this webpage.
Sony eSupport RM Y183 Remote Control Codes and Programming
Hope this is what you are after.
Aug 28, 2014 | Sony Televison & Video
NEED TO EJECT MY DVD USING THE TIME WARNER UNIVERSAL CONTROL. WHICH BUTTON IS IT?
Universal Remote codes for Blu-ray Players - AVS Forum ' Home ...
www.avsforum.com/...control.../1297068-universal-remote-codes-blu-ra...
Dec 10, 2010 - 12 posts - ‎7 authors
Brand new Sony bdp-bx59 Blu ray player with a Rogers Atlas PVR remote, Model 1056B01 ... A button, my Samsung DVD/VCR remote's Power button in there on the ... it just means the machine you are trying to control either came out after .... I have the same Blu Ray and Time Warner remote as you do.
Eject key unavailable on sony blu ray bdp-s3200 - Fixya
www.fixya.com/.../t24026716-eject_key_unavailable_sony_blu_ray_bd...
Apr 6, 2014 - eject key unavailable on sony blu ray bdp-s3200 disk tray wont open -Sony BDP-S3200 ... Question about Sony BDP-S3200 blu-ray/DVD player with WiFi. 4 Answers .... How do I program a Phillips (time Warner)RC122 to run a sony BDP-S3200 dvd? ... Sony BDP-S300 tray open while updating, stuck here.
How can I fix my Sony Blu-Ray player BDP-S3200 with the ...
www.fixya.com/.../t24578583-fix_sony_blu_ray_player_bdp_s3200_eje...
Jul 27, 2010 - Question about Sony BDP-S3200 blu-ray/DVD player with WiFi. 1 Answer .... SOURCE: Sony BDP-S300 won't play any Blu Ray discs. Sounds ... How do I program a Phillips (time Warner)RC122 to run a sony BDP-S3200 dvd? Dec 28 ...My player cant eject disc; it say '' eject key is not available this time''.
Remote codes - Comcast Help and Support Forums
Nov 23, 2013 | Sony BDP-S300 Blu-Ray Disc Player
Why can I not program a universal remote(1056B01-L) to work with BDP-S470 Sony Blu-ray Disc/DVD Player?
I have an IR 20.0 remote and non of these codes work. Is the remote just too old?
Jan 21, 2012 | Televison & Video
I need the 3 digit code for ge universal remote model RC24912-A for sony dvd player
Code lists and manuals for GE remotes are available from http://www.jascoproducts.com/support/universal-remote-codes.asp . The 3-digit code list is here: http://www.jascoproducts.com/support/download-files/RemoteCode-3-Digit.pdf . The Sony DVD player codes to try are 166, 320, 321, 322, 361, 389, 399, 909 . (Sony DVD recorders may use 302, 321, 322.)
However, the codes programmed into a universal remote are limited to those for devices released 6 months or more before the remote was programmed. If your DVD player is newer than your remote, you may need a newer universal remote.
I hope this helps.
Jul 24, 2011 | Universal Remote Control GE174Universal...
I lost my remote for it. How do I program a Sony remote for it. I have a Sony AV system for my tuner.
If it has a dvd button on the remote that hasen't been programmed for another brand it should already be set to sony by default. Otherwise check the A/V manual for any required codes.
Mar 15, 2010 | Sony DVP-NC615 Multi-disc DVD Player
Lost remote for sony blue ray and need to know how to start movie with out it!!
some DVD's will let you manually start them on the Sony blu-ray and the Sharp Blu-ray players. Other DVD's require the remote control. It is probably the DVD and not the blu-ray player. Pick up a inexpensive universal remote if you cannot find the original. Sony devices are easy to program on any universal remote.
Jan 11, 2010 | One For All URC-8910 LCD Remote Control
Programming dvd player
It sounds like you may not be on the correct input selection on the tv to watch the dvd player. Ther are probably three or four inputs to choose from on your tv. whichever input you hooked the dvd player into on the tv is the same imput you have select using the tv's remote control in order to watch movies on the dvd player.
May 31, 2009 | iLO 3200 32 in. LCD Television
Codes to program a universal remote to this device
You can try the following four digit codes:
0670, 0695, 0873, or 1919.
Aug 13, 2007 | Sanyo DWM-390 DVD Player
RCA RCU500 Remote Control Logo
287 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
