Full of water at end of cycle. Maybe the pump has gone....what can I do?
  • natsat Apr 27, 2008
    I ended up tilting the machine and squeezed the "bag" that connects the pump to the outpipe a few times. It worked. Maybe an air lock.
    Thanks anyway
    Genius:
  • 1,073 Answers
Check the pump for obstruction if no obstruction and if it is an electric pump check for voltage to the pump
Posted on Apr 26, 2008
Trouble shooting why the washer is at the end of cycle but when you open the lid the washer is still full of water
the selector switch damaged / faulty not activating the spin rinse cycle which pump activates and pumps out water -----pump faulty --pump clogged ---drain hose clogged
Jul 06, 2016 | Washing Machines
I have a Scotsman CME 506 ice maker. After running a cleaning cycle it won't run. After resetting the freeze light blinks and nothing happens. The water inlet valve never opens (the sump is current
CM3 Operational Sequence.
From Off, push and release the freeze button.
1. If sump is full,water pump starts.If sump is not full,water valve opens to fill it.
2. Compressor starts when sump is full.Air cooled fan motor starts too.
3. water pump stops early in freeze cycle for 30 seconds.
4. Sump refills after pump starts.
5. In low ambient condition,fan motor may begin to cycle on and off.
6. Freeze continues until water level in sump drops to preset point. Exceptions: SCE275 must fill sump two more times.
7. Fan may shut off before the end of freeze.
8. Harvest begins. Hot gas valve opens,pump stops.
9. Pump restarts, inlet water valve opens to fill and overflow the reservoir.
10. Harvest continues for preset first cycle harvest time.
11. If bin is not full, cycle repeats ( compressor stays on). If bin is full, unit shuts off at the end of harvest.
OK with that out of the way unless you unplugged any wires cleaning the machine should not have caused any problems. First cut off water and pull water supply line from water inlet valve look in the end of valve there is a screen in there it could be stopped up. If the valve screen is not stopped up then put supply water line back on and turn water back on. power the CM3 controller off. push freeze button. now with a voltage meter check at the water inlet valve to make sure you are getting power to the valve.If you are then either valve is stopped up or valve is bad. If you are not getting power to valve then replace the CM3 controller now make sure the bin full light is not on because if it is this will not let controller go back to a freeze cycle.
Oct 28, 2014 | Kitchen Appliances - Others
My system keeps flashing the 90 code indicating low water flow. My pool is full. What's wrong and how do I get the system to run normal? I just set the pool up and it has flash this cood from the...
Most low flow alarms are caused by the pump stopping before the chlorinator cycle ends. You must set the chlorinator hrs between the pump cycle. Start and set your pump cycle, wait at least15 to 30 minutes and then set you chlorinator hrs and make sure to it completes it's cycle at least 15 to 30 minutes before the pump cycle ends, If your pump turns off before the chlorinator cycle ends, you will get a low flow alarm......
Hope this helps, if it does, please rate...
Jul 25, 2011 | Intex Automatic Salt Water System for ...
Hello I have a Maytag Washer Model A512 The machine goes through a regular cycle OK - However, it DOES drains the water out during the rinse cycle, but does NOT drain the water out during the spin...
The timer will always advance to the next program if the machine does not fully drain. There is ALWAYS a spin when draining the water out, there is only one pump and one motor. The waterlogged laundry maybe telling the timer that there is still water in the tub. Put the machine on "Spin" and cheat the lid switch into thinking that the lid is closed. Use a clothes peg or wide ended screwdriver and see if there really is a spin....
Apr 07, 2017 | Maytag Neptune MAH5500B Front Load Washer
My concept 2 dishwasher doesn't drain, I can hear clunking sounds at the end of the wash cycle but the water doesn't drain. Gerard gone on vacation and hope to repair when I return.
Sounds like there's something caught in the water pump of dish washer. I hope it's on the intake side of the pump. You maybe able to pull the debris out with little bother. Good Luck.
Aug 16, 2010 | Dishwashers
I have replaced the rad cap, water pump, thermostat and water pump heater on my 2000 Chevy Venture. The rad and heater core are good. The water pump heater was in for 2 days working great and now I'm...
first of all the water pump doesn't have a heater, all the water pump does is cycle water (coolant) throughout the cooling system, the heater is up inside the dash behind the glove box.
I would feel the two 3/4" heater hoses that run from the engine into the heater core, if both of them are hot (providing the engine is at full temp) it one is hot and the other is cold maybe the heater core is plugged.
Jan 10, 2010 | 2000 Chevrolet Venture
Leaking water at the end of cycle
Watch your drain line in the wall when the final pump out begins.
May be a sewer problem.
Start a cycle. After the fill, advance to final spin and watch drain in the wall.
Feb 25, 2009 | Whirlpool Washing Machines
Won't pump out water at the end of wash or rinse cycle.
I don't know this model at all, but hada similar set of syptoms on an electrolux .....
Just a thought, but have you checked the pump chanber is not impeded by a stray hairgrip, or bit of wire?
The fact it doesn't pump when it should, but allows water to pass when the centrifugal force of a spin cycle builds up, would indicate that maybe its the pump that either has a jammed impeller, or a blown motor (or fuse).
Feb 15, 2009 | Kenmore 23822 Top Load Washer
Nautilis ge dishwasher does not pump all water out aT THE END.
the fill valve may be contaminated with debris that makes it heavier so it floats lower in the water and tells the unit the water is gone when it's not.
Nov 25, 2007 | GE Nautilus 24" Built-in Dishwasher
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
