Hello there:
LF
Long Fill
If the water
fill time exceeds ten minutes, the water valves are turned
off and LF is flashed.
Press STOP/CANCEL to clear the display. furthermore please check the following that may apply
It's slow to fill
Check
to see if there's good water volume coming through the hoses attached
to the washing machine. If there is, check to see if the screens inside
the water-inlet valve are clean. (The water-inlet valve is the device on
the washing machine that the fill hoses are attached to.) If they're
clean, you probably have a defective water-inlet valve. If so, you
should completely replace the valve.
There's no water at all
If there's no water at all, make these checks:
Is there water getting to the machine?
Is the water-volume selector switch set properly and are the control panel buttons pressed in all the way?
Is
there a faint buzzing or humming noise coming from the water-inlet
valve? (The water-inlet valve is the device on the washing machine that
the fill hoses are attached to.) If you can't hear anything, the
water-inlet valve may not be getting any power. If you can hear some
noise and there's water present, you may need to completely replace the
water-inlet
