Question about Thermax AF1 Canister Vacuum
Is there a repair location for Thermax in or around Jackson Ms There was one in Jackson,Byrum Ms are but I see it has closed
Need to locate fein carbon brush 31332843000 for a turbo ii 9.20.25? Suggestions even for generics?
carbon brushes for electric motors come in all shapes sizes and lengths as the motor manufacturer uses generic units in the manufacturer
go to an appliance repair shop or a motor repair shop and brushes that have the same connection ( pig tail braid , solder on etc) and are close to the dimensions can be filed down to dimensions to suit
Oct 31, 2017 | Fein Vacuums
Where is the nearest store to me. 70131
You can locate your nearest dealer using the Oreck locator tiil found at the link below.
Hope this helps
-Steve
Oreck Store Locator
Mar 03, 2015 | Oreck Vacuums
Would you know if i can purchase a new Suspension Kit, if so from who?
If the local distributors / repair shop can't get parts from the manufacturer - your only hope is to locate new stock sitting on someone else's shelf. That means calling around until you find it - or tire of looking. Good luck!
Dec 02, 2014 | Vacuums
No electrical continuity within the hose of my Hoover S3670 Vacuum Cleaner. How do I disassemble bothe wnds that house the actual connections?
Those hoses are pretty close to being a sealed unit, and was meant to be replaced and not repaired. That being said, some people do fix the problem IF they can locate the problem close to either end. Most people won't mess with an open in the middle of the hose.
Unfortunately, since they are designed to be a replaced item and not a repairable item, there is no written instruction on disassembly. So it is one of those to times when you study your hose and figure out when the break is and then decide on if it is worth attempting a repair.
Aug 10, 2011 | Hoover S3670 Bagged Canister Vacuum
I need the manual for thermax AFvacuum
Please go to this web site to request an owners manual.
http://www.thermaxaf.com/
Apr 14, 2010 | Thermax AF1 Canister Vacuum
Looking for a manual Thermax AF
You can call for a replacement manual toll free at 877-248-9191
Sep 11, 2009 | Thermax AF2 Canister Steam Vacuum
I rented a thermax steam cleaner it didnt come with instructions, where is the solution tank
The most logical answer to your question is to phone or stop in at the place you rented the steam cleaner from. They would have the knowledge / responsibility to help you with this...
May 07, 2009 | Vacuums
I would like to know the name and address of Bissell Dealer in the Salisbury MD area? I need to buy cleaning products. Ben J. Ames
Generic problem for all Vacuums
You can buy Bissell products @ your local vacuum cleaner dealer in your area in the yellow pages, or you can check the Bissell factory service number listed below or the Bissell website. Sometimes you can use other products (low sudsing) from other machines such as the Rug Doctor, Thermax, Hoover, Eureka etc.,
http://www.bissell.com/ By Phone Customer Service:
(800) 237-7691 Hours:
M-F 8:00 a.m. - 10:00 p.m. ET
Saturday 9:00 a.m. - 8:00 p.m. ET
Don - The Vac Man
Apr 22, 2008 | Vacuums
Trouble with vacuum suction
Check and see if there is a blockage.
Jan 19, 2008 | Vacuums
Thermax AF1 Canister Vacuum Logo
60 people viewed this question
Top Thermax Vacuums Experts
Marvin
Marvin
Are you a Thermax Vacuum Expert? Answer questions, earn points and help others
