Question about Olevia LT32HVM 32 in. LCD Television
Cannot adjust the color, brightness, contrast etc, using my olevia remote
I was trying to adjust the color in my television using the original olevia remote and nothing happens. Has something locked up on the set itself that is preventing me to use the controls?
  • Anonymous Dec 20, 2008
    I am a little confused on how you fixed your problem. What do you mean that it is set on high definition?
    Mine stopped being able to adjust the brightness after a power outage. What did you change to fix yours?
    Thank you for your help!
How to set TV from High Def to Standard Def TV .. olevia
Posted on Mar 16, 2010
Well....uh....duh....I'm sort of embarassed to say I had the TV set on High Def TV. (LOL) Once I put it back to Standard Def TV, I was able to adjust the color and so forth. Oh well, you never know, someone might need this solution. TA DA!
Posted on Apr 27, 2008
The color on my sharp flatscreen is messed up and i can't get it to adjust
Go to menu and select factory default settings from the remote control. Then adjust brightness, contrast, sharpness, color etc. to your likings.
Jul 16, 2012 | Sharp Aquos LC-45GD4U 45 in. LCD HDTV
I have a olevia tv and the color of the tv is green how can i fix the color ,after comcast fix something in the signal the tv color is green
I have a 532-b12 so it may be the same - but not sure. Push the small round "menu" button on the remote. A pinwheel should show up in the upper left corner. Use the up/down and left/right arrows to go to picture. From there, you can change, saturation, color, contrast, etc.
Jan 22, 2011 | Syntax Olevia LT32HV 32 in. HD-Ready LCD...
The remote does not work and the tv will not accept an universal remote.How can I adjust the color, brightness, contrast, and etc. with out a remote. The screen is dark and can not be adjusted without a...
Tries press the tv menu button on the tv front frame bazel to select color,brightness,contract so on...Adjust ur setting.Try website like remotes.com to buy an a exact to the original remote.
Oct 20, 2010 | Panasonic PV-20DF63 20 in. TV/DVD Combo
Colors are off on the TV. When I try to adjust the contrast and brightness, etc from the menu, either everything is orange or green or yellow.
Contrast and brightness won't fix it.You are on the right path though.You need to search around for a color adjustment.You should have numbered scales for all 3 primary colors to adjust.It should also be somewhere under the picture option.Let me know if you need better instructions.Good luck!
Aug 05, 2010 | Toshiba 42AV500U 42 in. LCD HDTV
Just bought one of these used and need to adjust the color brightness contrast etc. I assume I do this thru the "menu" option. I don't have the original remote with the unit and I can't get any universal...
Try website like Remotes.com to buy the original remote it ur best bet.Tries the manual control on the tv.Push the Menu button use the channel + - and the volume + - on the manual buttons to adjust colors,contrast,brightness.
Jul 04, 2010 | GE 13TVR62 Combo
Can't adjust color, brightness, etc. w/universal remote
Use the MENU on the front panel display of the
TV
Jan 06, 2010 | Televison & Video
Adjusting color/ user mode??
The TV will not let you set brightness, contrast, color or tint in the preset modes like Vivid, Movie, Standard etc. Look for a mode that says custom, user etc..
Nov 11, 2009 | Olevia LT42HVi 42 in. LCD Television
Color Adjustments....
well it all depends on where the tv is located to, if it is in a room with little or no light( windows, lamps) you will want you brightness to be a lil lighter hince not makin the picture as dark, and vise versa for light rooms, u'll wanna turn the brightness down a lil bit to accomidate this room, as for the others i'd say a lil over 50% on them, thats how my office tv is set up, hope this helps, jason
Dec 28, 2007 | Zenith B25A02Z TV
No contrast
first turn your color all way off or down.try turning your contrast way down as far as it will go you should see a darker picture. now bring up the brightness to a point half way. bring the contrast up to see grays and whites and blacks...adjust brightness more if need be. now you should see a nice black and white picture. no bring your color up last ...not saturate but to your liking. if you stilll got problems i bet your video out transistor is shorted....meaning shop work.
Aug 31, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Olevia LT32HVM 32 in. LCD Television Logo
1,252 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
