Question about Fujitsu LifeBook E8110 Notebook
How much hardisk and memory - Fujitsu LifeBook E8110 Notebook
  • 92 Answers
It only has 512mb of ram
and 80gb harddrive
Posted on Aug 05, 2010
Have a compact persiro f700 and am getting a message that states that SMART disk failure and windows will not load and cannot boot computer into safe mode Please Advise on what to do next?????
You could open the bios set up to check the hardisk and memory card, see if it is being read by the board.
Try to set your boot sequence to "default option" and save the changes. reboot again afterwards.
If there is a rebooting, but still can not read the hardisk, it means, that is a hardware breakdown, mainly the hardisk itself. Try to replace the HD( hardisk) if you have any spare ones, just to check the system.
Your local computer shop can assess it and tell you what causes the problem. we are just advising you if you could repair it by yourself and my pointers to what you are going to repair in your laptop.
Hope that helps you out.
Thanks for using FixYa!
Jun 30, 2011 | HP Compaq Presario F500 F700 and G6000...
When my cpu starts the beeper beeps continue sly while the yellow led blinks and windows will not runs and show select correct boot device
Check the following, the hardisk and the memory card!
If you have a spare hardisk, try to replace it and see if the HD can be read in the bios setting.
You also have to try the memory card, the beeping sound is a memory deficiency!
Check that and tell us what happened!
Jun 22, 2011 | ASUS P5KPL-AM - Motherboard - micro ATX -...
Need to replace hardisk but i could not open the hardisk
http://www.youtube.com/results?search_query=ASUS+Eee+PC+4G+PC+Notebook+how+to+open&aq=f
this is the link to know how to open this
thanks sir
May 09, 2010 | ASUS Eee 4G Notebook
Board comes on but it don't boot yet everything else seems to be working fine, why won't it boot?
Ensure you have hardisk and OS installed, take off any CD on CD Drive. If still won't work, try to re-seating the memory card and graphic card (if you use one in slot).
Check the Power and Data cable connection onto hardisk.
Apr 12, 2010 | ASUS P5WD2 Premium Motherboard
My Dell Desktop cannot start in Safe Mode
hi there,
you mention you have change your hardisk,you have to check if your hardisk was configure in cmos and bios set up, first whaen you start your computer press F2 then bios set up appear,check your device if
was connected on your system.on main menu check your ram if it was connectd,then press arrow right to advanced menu check your hardisk from IDE configuration if both hardisk and memory was installed or cofigured by your system.go to boot menu to set your device, on boot menu,scroll it from boot device priority
if you assure there is windows installed already on your hardisk,priority your hardisk,second your cd room,third floopy etc.press F10 to save and restart your computer,If no sytem was appears you must reinstalled your windows but you should change again
the boot set by priority the cd room instead of hardisk in order to put windows on your computer.press F10 again to save and restart your computer
to install your windows
insert windows cd on cd room
wait to configure your computer by the cd windows
then ff the windows installation procedure
until windows installation was finish.have a nice day don't forget to rate me please.thank you
Feb 21, 2010 | Dell Dimension 3100 PC Desktop
I have a problem in canon ir 8500 it gives eror code 602-0001,the manual says it's a hardisk we need to replace it,but i dont know the exact place of hardisk drive,i check the back side of the machine,and...
The Hard Disk is in the system box assembly where you are looking but behind it the board. It is definetly there, you need to remove the board to reveal it.
Dec 30, 2009 | Canon imageRUNNER 8500 Copier
There is a blue screen then it shuts down
i have this problem before, actually there are many causing blue screen. it might be the memory, hardisk, and the corruption of windows files etc. for you check first your hardisk if detected in your bios setup. if hardisk detected run safemode. then repair your windows.
Jun 25, 2009 | Toshiba Satellite A10-S100 Notebook
LOST PICTURE ON FLAT SCREEN
If you buy new PCI video card there is alway CD software attached on this,you should claim for this because it was the driver for your new video card ,without it your PC will have an abrormal operation .Are you sure it was your video card?you can consider also your memory card,Wiht out hardisk,CD room,floopy your computer will run it can open your monitor configuring the cmos and bios.Try on this one disconnect hardisk,cd room,floopy then detouched your memory card clean using pencil eraser the sloted terminal of your memory card,also your video card try to clean terminal by pencil eraser.Then put back memory and video card again if the monitor work.If ok put back again the cdroom,hardisk, and floopy.If not ok Isolate checking the memory and video card also the processor.
Mar 14, 2009 | Dell Dimension 2400 PC Desktop
Windows XP won't boot
sorry for my bad english
the problem may be your hardisk data cable.change your hardisk data cable.and also try this, remove ram memory and clean it and restore.
Dec 16, 2008 | Dell Dimension 3100 PC Desktop
I cant make a curent system buck-up disk becasue it says my HDD memory is -1
Try using Scandisk or CheckDisk on your Hardisk or any software that will surface scan your hardisk, maybe you got BadSector on your Drive.
Jun 11, 2008 | Acer Computers & Internet
Fujitsu LifeBook E8110 Notebook Logo
145 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
