Question about Kohler Santa Rosa K-3323-0 White Compact Elongated Toilet with Toilet Seat
Just bought and just had installed a Santa Rosa toilet that will not shut off when filling. Found flush valve filling chamber to have a triangular hole close to base of cylinder. when you cover this triangle **** with your finger the water then stops during fill. is this hole a defect?
  • Michael Donovan
    Michael Donovan Aug 05, 2010
    Is there a float on the valve?
  • Kohler Master
  • 43,501 Answers
I would say yes....here is the .pdf for your toilet and it has nothing like that in it...your toilet should be a simple fill device and flush mechanisim...
I would return it for a new one...
http://www.us.kohler.com/onlinecatalog/pdf/1066506_2.pdf
heatman101
Posted on Aug 05, 2010
What is a flush cylinder
It is really the valve that opens up to let water flow through the bowl when activated by the flush lever, to flush the toilet. it should prohibit water from flowing after the toilet flushes.
Aug 03, 2014 | Kohler - Toilet - One-piece - Santa Rosa -...
Whine or squealing from tank when Kohler Santa Rosa toilet is flushed.
Sounds like an air lock is making the water fill in squeeze thru the piping. C if u can undo the piping from the tap below the tank and take out tank and try flushing the unit thru from the out side fill pipe. U may hv something stuck in the pipe line. cheers
Aug 25, 2012 | Kohler Santa Rosa K-3323-55 Innocent Blush...
Kohler santa rosa fills, shuts off, a little water leaks from tank, toilet refills and repeats the leakage into the drain.
There is a rubber seal at the bottom of the flush valve that covers the openning at the bottom of the tank. If this rubber seal has perished slightly then it will leak water into the toilet bowl. This rubber seal need to be replaced to form a proper seal to prevent water leak.
Dec 27, 2011 | Kohler - Toilet - One-piece - Santa Rosa -...
I need to change the gasket 83996 on my kohler santa rosa toilet,but cant get the part that says waterline off.how do i get it off?
You have to twist the whole thing. There is no nut or threaded portion under the gasket like you'd find on most (two-piece toilets). The hole under the gasket seal is a triangle-shaped and the bottom of the flush valve (the part that says waterline) has three prongs that lock the unit down against the gasket.
I don't remember which direction worked, but I put the grip/handle of a channel lock pliers down into the flush valve and that gave me the leverage to remove the whole part with gasket.
Nov 01, 2010 | Kohler - Toilet - One-piece - Santa Rosa -...
I have to replace the gasket which the flush valve sits on. How do I remove the flush valve. The toilet is Kohler 1 piece model K-3323
The top of the pipe above the flush valve is threaded if you unscrew this you will be able to remove the flush valve and replace the gasket. I am assuming we are talking about the same here is a link that has all the parts:
http://www.plumbingsupply.com/kohlertoiletparts-santarosa.html
Oct 24, 2010 | Kohler - Toilet - One-piece - Santa Rosa -...
Water spits out of toilet bowl when toilet is flushed
If your referring to the tank, take the lid off and make sure the small tube is connected from the filler valve to the top of the overflow tube. If that's connected properly, flush the toilet with the tank top off and locate the source of the spray. A small crack in the fill valve can cause a significant spray.
Jul 09, 2010 | Kohler - Toilet - One-piece - Santa Rosa -...
One piece toilet needs a new gasket. How do I replace it?
The top of the pipe above the flush valve is threaded. Unscrew it, and you will be able to remove the flush valve and replace the gasket.
May 30, 2010 | Kohler - Toilet - One-piece - Santa Rosa -...
How install Kohler part no. 87988 in Santa Rosa
look under the tank, their should be a nut holding on the old one. by removing that nut the part should free itself.
Feb 27, 2010 | Kohler Santa Rosa K-3323-0 White Compact...
Howto install an auto detergent dispenser onto existing toilet ci
"Fluidmaster" makes a device that clips onto the tank and dispenses a solution into the bowl at each fill after a flush.
It goes inline with the tube runing from the fill valve, and dumps into the flush valve which goes into the bowl when filling.
Most LOWES carries them.
These are better than the ones that release the chemical into the tank because the chemical never has a chance of causing corrosion and failure of the tank to bowl seals.
Nov 18, 2008 | Kohler Santa Rosa K-3323-0 White Compact...
Kohler Santa Rosa K-3323-0 White Compact Elongated Toilet with Toilet Seat Logo
273 people viewed this question
Top Kohler Home Experts
john h
Tim Whalen
Mike
Are you a Kohler Home Expert? Answer questions, earn points and help others
