Question about Frigidaire Dishwashers
My dishwasher is cleaning but all plastic comes out with a cloudy film. I know dishes feel like they have the same film but i can't see it. It just started doing this. I currently use Cascade powder detergent and a rinse aid.
  • Frigidaire Master
  • 43,501 Answers
Check your heating element..
DishwasherMy dishwasher is cleaning but - 2_bing.gif Problems The Heating Element not Working
http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not
Dishwasher2_bing.gif Maintenance
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Asker's Testimonial " expanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Posted on Aug 05, 2010
Cloudy film left on all dishes and glasses. How do I remove the film?
Buy a gallon of white vinegar and rewash your dishes this time add 1/4 of a gallon of vinegar in the water with no soap just vinegar and water.... Also check and see if the dishwasher is completely draining you may have another problem that the dishwasher is not completely draining and you are washing with dirty water...... check the screen in the bottom of the dishwasher and the spray arm to see if they are clean and open...... I have used vinegar in my dishwasher and it has taken the cloudy film off... You may have to add it a couple of more times if you have a real bad build up......
I also use cascade complete dishwashing soap and has helped the problem with the cloudy film.
Mar 28, 2011 | KitchenAid Dishwashers
Frigidaire dishwasher FDB1500LFCO is not cleaning dishes properly. Glasses have a cloudy apprearance, other dishes are not clean, silveware is a mess. Have hard water so am using LemonShine for hard...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Dec 28, 2010 | Frigidaire FDB1502RG Built-in Dishwasher
I get a film on the inside of dishwasher as well as dishes at the end of a cycle. You can really see the cloudy film on glasses. Dishwasher is only 18 months old.
Cloudy film is usually from hard water. Or it means the dishes arn't drying properly. you wanna make sure your using jet dry and that your not using liquid soap. Liquid soap is a killer of dishwashers and creates mineral deposits. If you have hard water getting a water softener helps too. Theres a cleaning agent called dishwasher magic that works to clean the dishwasher . You wanna make sure your heater is coming on too.
Jun 15, 2010 | Kenmore Dishwashers
Film on dishes
the film on your elemend and dishes is more then likely soap residue.try useing less soap. if this is a new dishwasher it probably uses less water then your older one did so you will need to modify your soap usage. if you have had the dishwasher for a while then your valve is clogged or not opening all the way. check the brass elbow for mineral deposits and replace it and valve if buildup is seen
Apr 24, 2010 | Tappan 18 in. MDR251RE Built-in Dishwasher
Cloudy dishes
The problem is hard water. Go to www.dishwasherfilter.com. They have a new product out that solves this problem once and for all. It filters the water entering your dishwasher and removes the hard minerals that cause these spots. Very affordable and guaranteed to leave your dishes looking amazing every time.
Sep 22, 2009 | Maytag MDB9100A Dishwasher
JDB6510 dishes have a cloudy film
check your screen or strainer in the bottom of the unit it is what filters the water to the pump if it has some trash in it or is plugged it will reuse the old water to rinse the dishes
Aug 22, 2009 | Dishwashers
Not cleaning dishes, leave a cloudy film on silverware
the problem is hard water. you need a dishwasher filter and your problems will be solved. you can get one at www.dishwasherfilter.com and it is guaranteed or your money back. you will love the way your dishes come out.
May 31, 2009 | GE Dishwashers
Rinsing agent not dispensing
the problem is hard water. go to www.dishwasherfilter.com. they have a filter designed specifically for this problem. it filters the water going into your dishwasher leaving your dishes crystal clean with every load. it is very affordable and guaranteed to work.
Mar 18, 2009 | Dishwashers
My dishes are coming out with a thick cloudy film
Most dishwasher detergents now have some sort of rinse agent already in them. If this is the case don't add it to your dispenser once it runs out. Too much rinse agent can cause clouding.
Feb 18, 2009 | Kenmore 24 in. 16283 Built-in Dishwasher
Not coming clean
Hi, Are you using Jet Dry Rinse Agent? It is very important to keep the washer supplied with this stuff. Otherwise, glassware will come out with a cloudy film and water spots. If you are using it, perhaps it is not being dispensed by the machine. I am having this trouble now, but my machine is about 10 years old, and has always turned out beautiful glassware unless it ran out of Jet Dry. Now, there seems to be a problem in my machine not dispensing it, and I was searching for a solution when I came across your posting. Baxterdog
Dec 30, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
83 people viewed this question
Top Frigidaire Dishwashers Experts
Carmen Mikulic
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
