Question about Sunpentown 9000 BTU Portable Air WA-9010E Air Conditioner
Water Full indicator is blinking and unable to cool properly
2000 Gallant. Installed new radiator, thermostat, and water pump. Why does temp gauge read hot when it's not?
Disconnect the temperature sending unit wire connector for the gague ( not the one for the computer ) with the key on. The temp hand should stay on cold mark. Next, ground the wire and the temp hand should go to full hot indicating the gague and wiring to it are ok. If ok suspect a faulty temp sending sensor if the cooling system is full and properly bled
Jun 28, 2015 | Mitsubishi Cars & Trucks
Tip
PRIMO BOTTOM LOAD WATER DISPENSER, BLINKING LIGHT
We started getting a blinking light... indicating the jug needed replacement... after installing a full jug. The unit would cycle, then the red blinking light would come back on. Upon careful inspection of the feed tube and lines, it was realized that the plastic line on the intake of the pump body had been inadvertently pulled out just slightly (presumably from jostling the jug around during replacement). I believe that this breaks the seal the unit requires for suction, and caused the fault. I simply pushed the (white) plastic line back into pump body and heard an audible 'click'. Unit works fine now. I hope this helps, as these units are not exactly cheap.
on Oct 30, 2013 | Primo Grills And Smokers Primo Bottom Load...
My Sharp CV10NH, turns off and water full about every 30min...is there a solution to this problem?
If you are operating in a humid environment and are running in Dehumidifier mode, you might be filling your tank very quickly. Run it in Cool mode and you might last longer than 30 mins. Also, if you can isolate the room you are cooling from other parts of the house, that will help.
Aug 04, 2012 | Sharp CV10NH Air Conditioner
I have a slow blinking red light - not working
Normally, the slow blinking red light, indicates that the water collection tank/bucket is full and needs to be emptied. If the bucket is NOT full, it indicates that the tank/bucket was not installed or reinstalled properly, because it did not make secure contact with the bucket removal safety switch. Removing the bucket and reinstalling it properly will normally resolve the problem. Make sure the bucket fits squarely into it's holder from top to bottom.
In case you have misplaced your Owner's Manual, I have included a link to it, that you can download and print for future reference. http://www.appliancefactoryparts.com/content/pdfs/117029-1.pdf
I hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 13, 2011 | Comfort-Aire BHD-301 Dehumidifier
Replace the 2 bulbs. Unit powered up correctly and turned on like normal. Then Lamp1 and Lamp 2 indicator lights blinked (Indicating Start UP). After some period of time, it switched to Red 6 times blink...
1 red blink every 2.5 seconds indicates a cover error-- for this check the lamp cover
2 times red blinks very 2 seconds indicates temperature error. for this let the projector cool off check filters and fans that there is no blockage of air for proper cool down
3 red blinks every every 2 seconds Power error. incorrect voltage input or internal malfunction.
4 red blinks every 2 seconds indicates Fan Error check the fans make sure they are working and not blocked or need replacing.
i have nothing on 6 ligths go ahead reconect and check for proper count. hope this information helps.
Best of Luck.
Ray.
Jun 05, 2011 | Sanyo PDG-DXT10L Projector
We have a White-Rodgers 90 series thermostat that started beeping last night. We have had it for about 4 years. Does it have a battery? I couldn't find anything about that in the manual.
Susan, the "90" series of thermostats covers a couple of different thermostats made by White-Rodgers. Here's how to find your model number. With that info, I can check the manual specific to your thermostat.
In the mean time, check the display for the word BATTERY or BAT. (Flashing) on the display. Battery flashing or blinking on the digital display indicates low batteries. If the batteries have recently been changed and the thermostat continues to indicate low batteries, use a pencil eraser to polish each of the battery contacts inside the back of the thermostat. Do not bend them up and down when polishing or you might break them. When complete, they should all be as shiny as a mirror. This will assure proper battery back-up, allow the backlight to work correctly and remove the flashing battery symbol from the screen. Battery (Solid) on Display The battery symbol (not blinking) indicates a loss of power (24 volts) from the heating and cooling equipment to the thermostat. Normally the heating and cooling do not operate when the battery indicator is on. If the battery indicator is on, check the fuses or breakers, make sure the furnace is switched on, and verify the blower compartment door is closed properly. The battery display is designed to indicate the thermostat is running on batteries, so replacing batteries has no effect on the indicator. See No Heat/No Cool for more information. Note: Some heat only systems (zoned systems) disconnect power from the thermostat during a normal heating cycle and display the battery symbol. Millivolt heating systems always indicate battery because they do not supply 24 volts to the thermostat.
A beep often is provided as audible feedback when keys are depressed on many thermostats. You should check to make sure that no key is stuck in the "in" position or is otherwise activated.
Jan 10, 2011 | White Rodgers Water Heaters
What is the P2 code on an everstar mpk 10cr1
<b>Unit Displays P1</b><br /> P1 error indicates that:<br /> <ol type="A"> <li>The water tank on the side of the unit is full. <li>The water tank in not properly seated in the housing. <li>The switch at the back of the water tank housing is not engaged or is loose </li></ol> <br /> <i>Solution</i>:<br /> <ol type="A"> <li>Empty the water tank. <li>Make sure the water tank is properly secured in the housing <li>Remove the water tank for the housing and gently tilt the switch at the upper left hand corner of the housing towards you. This should allow the tab on the water tank cover to engage the switch. </li></ol> <br /> <b>Unit Displays P2</b><br /> P2 error indicates that the spill reservoir in the base of the unit is full.<br /> <i>Solution</i>:<br />Move the unit to a location that is suitable for draining water from the unit.<br />Remove the plug in the lower center of the back of the unit and allow the water to completely drain <br />(Remember to replace plug.)<br /> <hr color="#cccccc" size="1" /> <b>Unit Does Not Cool/The Green Light is not on. </b><br /> Is the unit in the Cooling mode?<br /> <i>Solution</i>:<br />Press the mode button until cooling mode is selected. <br />Lower the temperature setting on the unit to the minimum setting. <br />(The temperature setting of the unit has to be lower that that of the room)<br />Wait 3 to five minutes for the compressor to start running.
Jul 06, 2010 | Danby DPAC8020 Air Conditioner
Honeywell compact refrigerator model # 88031not cooling.
Honeywell compact refrigerator model # 88031 making a clicking noise, not cooling, interior light blinks, and the fans in back are not working properly....seems as if it's not getting full power. worked fine for about a year and justed stopped.
Mar 18, 2010 | Refrigerators
Water full light blinking, cannot reset
I don't know what kind of unit this is but usually unplugging the unit for at least 10 seconds will reset it. If there is a controller, take those batteries out for 10 seconds or more too.
Lastly if you can safely see or reach the float that is in the reservoir, check to see if it is just stuck. Good luck.
Jul 02, 2008 | Heating & Cooling
Sunpentown 9000 BTU Portable Air WA-9010E Air Conditioner Logo
47 people viewed this question
Top Sunpentown Heating & Cooling Experts
Dan Webster
Dan Webster
Steve F
Pete Norton
Are you a Sunpentown Heating and Cooling Expert? Answer questions, earn points and help others
