Question about Jenn-Air JED8430 Electric Cooktop
What is the wiring order - Jenn-Air JED8430 Electric Cooktop
  • edwin1557 Aug 05, 2010
    Will you answer me tonight?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. If you want a wiring diagram for your Jenn Air JED8430 then please check this link however, if you are looking for something else please post back for further assistance.
Thanks
Rylee
Posted on Aug 05, 2010
  • 3 more comments
  • Rylee Smith
    Rylee Smith Aug 05, 2010
    This was the answer that was posted earlier:
    Hi
    Thanks
    Rylee
    Your answer is incomplete and your reply took an extraordinary amount of time. Please issue credit to my Visa for unresolved solution.
    Thanks,
    Edwin
  • Rylee Smith
    Please post a comment if you want more assistance.
    Rylee,
    Did you read my comment sent 2 hours ago?
    Edwin
  • Rylee Smith
    I did read your comment Edwin however, you did not mention anywhere on what exactly you require. By reading your question wiring order no one can understand what is the exact issue, please elaborate.
Bosch five ring hob ignition
It can be for another model if this is the ignition unit. Please confirm with your supplier before it can be tired as they might allow you to exchange if this order was misplaced. Please quote the part number or model of the oven.
Nov 11, 2011 | Cooktops
Was using 4 burners and they all stopped working- electric burn smell in kitchen. External house breaker is not tripped
When you used all elements the power supply wire have been
gone to the maximum current absorbed so to the maximum heat. When the cook top
is new it can withstand this heat but due to long time used now you have burned
out wires and probably to junction point. So now the power supply wire is
burned and is open circuit thus not any power to the heater. The wires have
just open circuit and they don't touch each other or the metal body of the cook
top that is why you don't have the circuit breaker fuse to trip off. So now you
need to disassemble the cook top and you will very easily find the burn point
which should be melded and burned black and replace all parts that they have
been burned with new one.
Here is the link where you find the parts layout, the wiring
diagram and also order any parts you might need.
Also just for safety, avoid to use all four heater at the
same time in the future.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5170741&diagram_id=28477270#d28477270
Dec 18, 2010 | Maytag MEC5430BDS Electric Cooktop
I just bought a jp328sfss and need to know how to wire it to the breaker panel the way it is wired now it only heats water to 120 degrees F the handyman that hooked it up said there was no way to wire it...
It sounds like you better be careful for starters. I also suggest your handyman sticks to painting. In older homes a 208/240 circuit onlt had three wires. New construction and remodeling requires a four wire system. Per code, a black wire is 120VAC, and a red wire is 120VAC. In a 240VAC circuit they would be called L-1 and L-2 respectively. In order to provide 240VAC they must be on seperate phases. The bare wire in your bundle is the ground wire and is at the same potential as neutral, or the white wire in current four wire systems. If you know how to use an electrical test meter, you should show 120VAC from black to bare copper, 120VAC from red to bare copper, and 240VAC from black to red. If this is not the case, I strongly suggest you have an electrician come in and take care of it in your breaker panel. *****Electricity is nothing to fool around with if you are not absolutely sure you know what you are doing. A loose connection, a wrong connection can result in fire, serious injury or death. It's worth a service call to a licensed electrician or qualified appliance service technician to give you peace of mind, and years of safe use of your new cooktop.
Nov 18, 2010 | GE 30 in. JP328SFSS Electric Cooktop
How to replace a cooktop drip pan
It's really simple. Remove the burner grates, removed the old drip pans, then drop in the new drip pans. You can order a new drip pan from partselect.com if you don't have one yet. Let me know how this works out and if you need any further help.
Benjamin
Nov 04, 2010 | GE Profile JGP636 Gas Cooktop
I ordered a replacement switch for the JED8430ADW. The previous switch was 7403P406-60. The replacement switch is 12002125. I have no clue how to re-connect the wiring. it looks nothing like the old...
There was a design change related to this switch. I had the same problem earlier today and figured it out by getting the schematics from searspartsdirect.com. There are two different schematics there (in English). The old schematic is labeled "DIAGRAM NO. 8104P688-60". The new one has five notes in the lower left (that don't help). The key is to split out the red wire coming back from the double burner element. The old way had it connected to "N" along with the RED source power. The new way has it connected to terminal "2" all by itself with the RED source power now connected to terminal "P2". But in addition, you have to add an extra jumper wire that should have come with your new switch that goes from "P1" to "S1". The other connections simply move from the old switch to the new where the locations can be seen on the schematics by referencing the wire colors (example: TAN wire moves from the old "3" to the new "4", etc.). If you are not 100% sure of what you are doing - you shouldn't try this. A wrong wire in the wrong place can short out 240V when you throw the breaker (boom!). Good luck. -- Mark.
Sep 10, 2010 | Jenn-Air JED8430 Electric Cooktop
The cooktop is stuck trying to lite.
There is a temprature probe that looks like a wire that should be in the flame when lit. this tells the circuitry that there is a flame there - so stop trying to light it.
If this sensor fails, it will continue to ignite, and may turn off the Gas.
Order a replacement flame sensor from your supplier or high street outlet.
Feb 08, 2010 | Whirlpool Cooktops
The igniter on the right front burner of my GE Gas cooktop does not work....I must use a lighter or match to ignite....What can I do? There is no clicking sound when I turn on the burner?
the very first thing i would do here is to check the ignitor itself
under the head cap you should see two screws, once those are out you will be able to lift the burner plate, lift the burner plate, you will see, or should see the ignitor, and the wire.
i check this for voltage by unplugging the ignitor and olding the wire close to a ground, the metal body is good. Turn on the ignitor, becareful it is live. yhou shgould see a spark comming from the wire
if not check to make sure that wire is in position and on the spark module
if you do see a spark this way, just order the replacement ignitor
and install it when it arrives
part number AP3191250
Oct 17, 2009 | GE 30 in. JGP328 Gas Cooktop
Jenn Air Cooktop wiring issue.
Thank you for your enqiry!!
Mar 21, 2009 | Cooktops
COOKTOP
its been my experience that the dual burner switch is far more likely the culprit, unless you can physiclaly see the outer ring is broken( visual inspection works wonders. as far as trying to ohm out i generally look at theelemnet itself (4 wires lead to the elemnt you can trace 1 to the outer portion of element, and 1 to the inner portion.WITH POWER OFF Iswithc those 2 wires and the restore power try element ad watch for outer ring to work inner ring no good. now i know its the switch not sending power. reset wires and order new switch
Mar 08, 2008 | Cooktops
Jenn-Air JED8430 Electric Cooktop Logo
78 people viewed this question
Top Jenn-Air Cooktops Experts
Marvin
Marvin
Paul Carew
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
