Question about Whirlpool 20 cu. ft. / 566 liter Upright Freezer EV201MWH
Drain stopped up on freezer model evl201nxrq - Whirlpool 20 cu. ft. / 566 liter Upright Freezer EV201MWH
  • Whirlpool Master
  • 43,501 Answers
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
Water Running in Refrigerator from Freezerdrain stopped up on freezer model evl201nxrq - 2_bing.gif
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Posted on Aug 05, 2010
Model # FUF17DACWH Freezer is leaking water
After the defrost mode, the water from the melted frost or ice should go down the drain at the bottom back of the freezer compartment. That drain is probably plugged with some gooey gunk. If its an upright freezer, there will be a hose clamped to the back that comes out of a plastic fitting.. detach it there and 'fish' into the plastic fitting with a short piece of wire then blow into it to dislodge whatever may be there. Blow downward on the hose as it too could (probably not) be plugged between there and the drain pan under the bottom of the refrigerator.
Severe cases require that the freezer back be removed and the drain thoroughly cleaned. That gets real tricky, but its doable. Ice makers in the way complicate the process too.
Jun 14, 2014 | GE 16.7 cu. ft. / 473 liter Upright...
The drain keeps stopping up
Since there is no description of what type of freezer, I will talk generic. Most freezers have some sort of drain heater. Commercial walk-ins use them. 2 types: an insertion type that go inside the drain and another type that is wrapped around the outside of the drain and then wrapped with a foam type insulation call armaflex. hope this helps some.
Jul 28, 2017 | Freezers
Whirlpool 20 cu ft upright frostless freezer model EVL201NXRQ. About 2 weeks ago i could hear what is sounded like the fan was making a steady loud running noise. Now the freezer has completely quit. Is...
Difficult call there as whirlpool has a strange manor especially with the larger units. I had a callout on a double door whirlpool unit once and the compressor wouldn't come on but i couldn't find anything wrong. Anyway, i decided to leave the fridge untl the next day giving it a chance to possibly come on. About 5 hours later the customer called and said unit running very well and no more problems. Basically leave on for a few hours and see. If no output then call a tech .The testing procedures need equipment and electrical info..
Feb 18, 2011 | Whirlpool 19.6 cu. ft. Upright Freezer...
Freezer model EV171NYMS04 we have ice build up on
There is a drain the back of the freezer that is frozen. Your trickle of water comes from the ice that melts off of the refrigeration coils during the defrost cycle. You need to turn off the freezer, then remove the rear cover from the back wall to expose the coils. With a hair dryer, melt all of the ice. You will find a drain under the coils. Melts all of the ice in this drain so water can get out of the freezer. When this drain is clear, you can put everything back together, and your freezer should work normally.
Mar 12, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
Constant Defrost causing water accumulation problems
Yes! look under you fridge for the consendate drain hose *(usually dangling right over the catch tray) and using a long piece of slightly heavy guage wire snake up the drain hose and see if it's blocked.
If it isn't blocked you might have a crack somewhere in the fridges interior near the fridge/freezer interface. That might be a bit harder to spot since it would most likely be under cover.
Good luck and be careful.
Dec 29, 2009 | Whirlpool Freezers
I have 16.7 upright Frigidaire Ultrafreeze freezer, Model AFFU1766DW3 & SERIAL #WB51720061, manufactured 04/05 that I purchased new 11/05. Water was on the floor next the the freezer but the light on...
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Oct 24, 2009 | Frigidaire Freezer 16.7 Upright Freezer,...
Ge feezer model fuf14dtarwh upright. i am getting water on the bottom of the freezer which is frozen. what is causing the problem? of course the warranty is over by 9 months and the ge people won't help.
Sep 23, 2009 | GE 13.7 cu. ft. / 388 liter Upright...
Water leaking onto the floor from freezer drain...
Sep 20, 2009 | Freezers
I have a Kenmore upright freezer-model LFFH2067DW2 -the red light has been on for at least 12 hours and the freezer is defrosting-water is leaking on the floor-there is a vent insidethe freezer and the...
I was made aware of your concern and would like to offer a few ideas you may want to consider. Water dripping down is not a leak during defrost condition as this would be the ice melting. Normally, there would be a drain hose specifically to channel the melted ice/water to a drainage system. The amount of water would then be proportional to the amount of ice melting as with the length of time to completely melt, drain away.
Perhaps you could check the filter/drain screen as well as the drain opening for any blockage/clogging. You could also try checking the same on the drain hose as well as for possible kinks. Additionally, there would be a sensor behind a boxy cover that triggers the system back into operation. If there is still melted ice/water inside the freezer, then the sensor would prevent the unit from turning on completely. You may want to check this sensor and verify that it is dry.
An exploded parts diagram would help you identify/locate the above mentioned parts.
Good luck and thank you for using FixYa.
Feb 07, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezers Logo
300 people viewed this question
Top Whirlpool Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Justin Duby
Justin Duby
Are you a Whirlpool Freezer Expert? Answer questions, earn points and help others
