Question about Toshiba Satellite M55-S141 Notebook
My computer have a problem in your audio.What drive audio i can install
  • 92 Answers
Download here http://www.driverfiles.net/Notebooks/Toshiba/Satellite-M55-S141/download/page,sh,31189,221,19,.html
Posted on Aug 05, 2010
    Master:
  • 344 Answers
I believe what you seek is here...
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1204306&rpn=PSM53U&modelFilter=M55-S141&selCategory=2756709&selFamily=1073768663#
if you have a problem with accessing that link go here
support.toshiba.com
then click Download, select the proper info for your laptop and it will offer a handy listing of all drivers for the system. :)
NO SOUND DRIVE IN MY MOTHER BOARD REV 1.3
first right click my computer in the desktop then properties then hardware then device manager then expand the audio,vedio and game controller see wether the driver is installed properly if not installed it will show yellow question mark the reload the correct drives from the cd which you recived with your computer install the audio software and restart the system then in the taskbar you will see the speaker icon right click them click adjust audio properties in volume move the slisders to full on uncheck the mute then restart your computer
Jan 29, 2011 | Computers & Internet
No sound in it
Jan 26, 2011 | Compaq Audio card Sound Card
I can not hear any sounds or audio in my computer
Jan 15, 2011 | Computers & Internet
There is no audio driver
You can download the audio drivers for your computer from the manufacturer's WEB site.
I cannot give you the link to the manufacturer's WEB site because you have not provided the make and model of your computer.
Dec 30, 2010 | Computers & Internet
Had a new Hard drive installed in my laptop, since then the volume does not work. I hear beeps when battery is low, or notifications, but thats all. I cant watch the news or a video? whats the solution?
Recent changes of hardware component such as the hard drive will affect your system since the previous drivers and configurations for other components were installed in your previous hard drive, thus likely your audio is not working. It is like introducing your new hard drive to the system by installing the audio drivers and/or other drivers that is needed to make them collaborate and work. So try to download and install the audio drivers which you can download from this link. Click here: and follow these steps.
• select your region and language
• once directed to the next page enter your laptop serial number (check underneath the computer for S/N:) and click search
• it should display the drivers available for your computer
• scroll down and see the "Audio" section
• select the driver which is compatible with your system
• after downloading, the drivers run it and it will be installed into your system
This should fix the problem for your audio issues, hope this works.
May 05, 2010 | IBM ThinkPad Soundcard
No audio outout device is installed
Did your vista install correctly? Is your computer got a 32 bit hard drive? This can happen if your computer worked fine before you changed to vista. or if it did not install properly or you put in a 32 bit for a 64 bit or vise versa. Check these out first. If computer worked before update this is most likely the problem or you may not have enough ram or hard drive memory for vista. Let me know i'll try to help you thru this.
Jul 02, 2009 | Dell Inspiron 1525 Notebook
My computer has no audio drive and i need to install realteck high defintion audio drive in my computer
Click here to download your driver and don't forget to restart your pc if then also having any prob with audio then run the free scan available on that site. http://www.softwarepatch.com/utilities/ac97.html
Jun 14, 2009 | Computers & Internet
How to install a second dvd player in my compaq
The computer needs to be opened up to properly install the CD or DVD drive into the computer. The method for opening the case will vary depending upon the case. Most new systems will use a panel or door on the side of the system while older systems may require the whole cover be removed. Remove and set aside and screws fastening the cover or panel to the computer case and then remove the cover.
Computer cases can generally hold a number of external drives but only a few are generally used. Any unsed drive slot has a cover that prevents dust from entering the computer and makes the case look better. To install the drive, it will be necessary to remove a 5.25" drive slot cover from the case. Removal of these generally is done by pushing some tabs either on the inside or outside of the case. Some may be screwed into the case.
The majority of all CD and DVD drives for computer systems use the IDE interface. This interface can have two devices on a single cable. Each device on the cable must be placed into the appropriate mode for the cable. One drive is listed as the master and the other secondary drive is listed as a slave. This setting is generally handled by one or more jumpers on the back of the drive. Consult the documentation or diagrams on the drive for the location and settings for the drive. If the CD/DVD drive is going to be installed on an existing cable, the drive needs to be set into the Slave mode. If the drive is going to reside on its own IDE cable alone, the drive should be set to the Master mode.
At this point, the CD/DVD drive needs to be placed into the computer. The method for installing the drive will vary depending on the case. The two most common methods for installing a drive into a case is either through drive rails or directly into the drive cage. Rails: Place the drive rails onto the side of the drive and fasten it with screws. Once the drive rails have been placed on both sides of the drive, slide the drive and rails into the appropriate slot in the case. Make sure to affix the drive rails so that the drive is flush with the case when it is fully inserted into the case. Drive Cage: Slide the drive into the slot in the case so that the drive bezel is flush with the computer case. When this is done, fasten the drive to the computer case by placing screws into the appropriate slots or holes in the case.
Many people use the CD/DVD drive inside of their computer to listen to audio CDs. In order for this to work, the audio signal from the CD needs to be routed from the drive to the computer audio solution. This is typically handled by a small two wire cable with a standard connector. Plug this cable into the back of the CD/DVD drive. The other end of the cable will plug either into a PC audio card or motherboard depending upon which the computer uses for audio. Plug the cable into the connector labeled as CD Audio.
At this point, the CD/DVD drive needs to be attached to the computer through an IDE cable. For most users, the drive will reside as a secondary drive to the hard drive. If this is the case, locate the free connector on the IDE ribbon cable between the computer and the hard drive and plug it into the drive. If the drive is going to be on its own cable, plug the IDE cable into the motherboard and one of the other connectors of the cable into the CD/DVD drive.
The only internal item left to do for installing the drive is to plug it into the power supply. This is done by locating one of the 4-pin Molex connectors from the power supply and inserting it into the power connector on the CD/DVD drive.
At this point the drive is fully installed into the computer case so it can be closed up. Replace the panel or cover to the computer case. Be sure to fasten the cover or panel back to the case using the screws that were set aside when the cover was removed.
All of the installation steps for the CD or DVD drive are now completed. The only thing left to do is return power to the computer. Plug the AC cord back into the power supply and be sure to flip the switch to the on position.
Regards..
Apr 09, 2009 | Compaq Computers & Internet
My computer dont have sound.For a m747 bx-pro
please install the sound drives in my computer
we have no sound drives in my coumpetr
i want sound drives with installing with my computer
Apr 06, 2009 | Computers & Internet
Sound problem
I recently made formate to my PC when it got virus the DRIVER CD the mother board box in not responding for the audio drive
installation
Jun 26, 2008 | Edirol UA-4FX External Sound System
Toshiba Satellite M55-S141 Notebook Logo
81 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
