Question about Acomdata 1TB Puredrive USB Esata 1 TB Hard Drive
I have had a acomdata pureDrive Model 761 external drive for sometime and it's been wonderful. About two days ago it fell on it's side and I didn't think much of it. In fact, I've used a game that I can only use when it's plugged in and working; and in fact, just last night I checked to make sure I had access to all of the files I have stored on it, and last night it was working no problem. Then later in the night I didn't seem to have access. I thought it just might be hot so I shut everything down and tried it again today. My laptop recognizes it with the same sound when I turn it on; and lists it as a mass USB storage device when I choose the 'safely remove' option on my windows task bar. However, it's not listed as a drive when I browse to get access, or on my computer -like it normally is? Then when I took a closer look, I noticed that the back black panel is loose and I can slide it out if I wanted to? It didn't fall that hard, and like I said it's been working since that happened? Do you have any suggestions? I've never had a problem with it so far...please respond, thank you..
Like said above yo should make sure all your cables are nice and tight look for signs of breakage which is rare if it just tipped over and in a enclosure but I have seen it happen. Try a Different USB port as maybe the one it is using bugged out...
These external Hard drives have Platter hard drives that use a head to read the Data, Think of a record player how it reads the data well the head is kinda like that well same idea without the pin, A little drop can mess up those reading heads or move them so when the drive is running it will scratch or mess-up your drives platter/platters which in turn can wreck your data. If it tipped over while it was on even not in use that could be a problem remember those platters spin very fast 5900 -7200 times per min so if the platter hits the head while it drops or bends it it can cause major damage, that may not show up right away but couple hours later or weeks later. Different Noises coming from the drive can also be a indicator that the drive is damaged.
Good news is if you get your data back or even if you do not you can go out and buy a new Hard drive and put it in the enclosure and reuse the enclosure, buying a hardrive online are very cheap for example a site I use, had Seagate
Posted on Sep 06, 2010
  • 47 Answers
If you can open the hard drive case, then do so and remove the hard drive from the connector and then plug it back again, give it a try
Posted on Aug 05, 2010
4 Suggested Answers
SOURCE: External Hard Drive won't respond
ok 1. you need to be sure that you can`t have acces anymore by usb to the external HD... try in another machine example a other laptop.. or you need to open the HD and connect to other way with a new conector that sell in comusa or other computer store... pls click that my solution was usefull
Posted on Dec 27, 2009
SOURCE: everytime i turn the power
One thing to note even when using a external drive to store/backup your data it is always good to burn your most important data to a DVD/CD to keep a hard copy for times like this, you can burn the DVD as a live DVD so you can rewrite over files with the same DVD or you can just Burn a new DVD each time as DVD's are very cheap these days.
If you have it fixed please let know and tell your solution or your problem for future users, please & thank you
How old is the drive? How long have you been using it? Have you dropped it or even tipped it over running/turned on or not?
It could be lots of things, Have you tried to reboot your computer unplug the external USB drive then replug it in another USB Port once windows is loaded? You can plug it in while the drive is turned on to see if that works at all. It could also be your Mass storage driver, OS uninstall that in device manager and then reinstall it by plugging in the drive. Do you have another computer home, work or friend that you could take the drive to and plug it in to test and see if it works there.
If it does its probably your machine if not its the probably the drive. If its your computer you may need to re-install the mass storage device driver or just change the usb port your using.
I do not know what Operation System you are using so I can only throw out some ideas to try.
If it is under warranty you can take it back to the store see if you can get a exchange if not, try a RMA with the manufacture you will lose all your data if you have to do this. So below are some instructions if you know basics to do, please use caution)
The hard drive itself may be corrupt, burned or bugged out or it could be the actual enclosure I have seen this lots of times. If it is still under warranty and make sure it will not void the warranty to open the enclosure most have pieces of tape stickers over parts so they know if it was opened it will be wripped, open it up and make sure all your plugs/wires are plugged in nice and tight, or look for any sign of wires being exposed or broken, if there are any wires.
When the drive is turned on can you hear and funny noises coming from it? Was the drive tipped over or dropped any distance?
Last resort if you tried everything else and may think its upir hard drive.
Next area is for anybody who may be having this problem with any external drive and has basic knowledge of hooking up a hard drive very simple for some.
Please read through it first or print it out then look up anything you do not understand on Google before starting.
This part is getting into testing and trouble shooting the actual hard Drive that was in your enclosure drive, the fastest and easiest way if you know the basics of what to do I will give instructions.
Unplug the computer and wait a few mins for power to drain from the motherboard. Make sure you always ground your self by touching the steal part of the case and try not to touch any parts, but if you are touching a steel part of the case you should be grounded and static electricity should not hurt anything, very rare but can happen you have been warned... lol
If you have the knowledge take the hard drive out of the external enclosure (usually a couple screws) and hook it up directly inside your computer via a SATA cable or if you know somebody that does and will do it for free? If not skip this part...
If you do not have any extra cables you can even just unplug the computers main Hard Drive SATA cable and power wire and plug it into this drive no need to take anything out of the case, or screw the drive in the case just set it beside the case with the side panel off.(when your done you can just plug it back into your main hard drive you pulled the wires from in the first place.)
Once you have the drive plugged in you can plug the computer back in and turn it on. Press the button to go into the bios and look and see if the hard drive shows up in the bios or you can watch the bootup screen and see if you see the drive show up. If the drive shows up you just unplug it plug your main computers hard drive in with the wires you were using from it, boot up the machine to windows or your OS (This can be done before you even put the drive in the first time to skip some steps plus this CD is always good to have anyway.) then open your web browser and go to www.google.com and search for a Linux live cd. Download it & burn it then, put the CD/DVD in the cdrom drive and boot your machine when it asks hit any key to boot from CD do so and it will boot into Linux live to make sure you did it right it is very simple you are just burning a image to a cd most CD burning programs can do this easily if you do not have one a program called "ImgBurn" is free and easy to use you can download it just put name in google and search downloa and install, great for burning any image files or files in general to CD or DVD.
Complete the first steps above to put the other hard drive(one you are testing) back in the computer, boot up into the linux live cd you burned and once in check and see if you can access the drive.(to boot into the Linux live CD you may need to go into your Bios when the computer first starts and change the boot order so the CD-Rom boots first so CD-Rom then Hard drive and put floppy disk last as they are pretty useless in today world where cd's & Jumpdrives can be used for everything.
OR another way Below
Hookup the drive directly to your computer using a SATA wire, plug in the power cord, (that is if your computer is not old enough that the power supply does not have any SATA power connectors if not you will have to buy a 4 prong to Sata power cable),( very cheap on eBay or a Computer store around your house.)
Keep in mind the actual brand of the Hardrive inside the enclosure because it will not be a "Acomdata" as that is only the company brand name that made the enclosure and put it all together very simple task.
Turn on the computer and watch if it shows up in the list of drives(could be a good sign) or you can go into the bios and take a look at the list of drives connected to the computer and see if it is in the list.
After the computer boots up take a look in "My Computer" for the drive, if it shows up click on it to see if you can access it, if not (This part on is for Windows Vista or WIndows 7 users if not go to end and read end part)
then go into "Control Panel\All Control Panel Items\Administrative Tools" then double click computer management, when it opens on the left side click on storage then disk Management.
Find the drive in your list depending on how many hard drives you have most will only have one, unless you added others.
Now find the drive you just installed, usually you can find it easiest by either its brand name or the drives size. Look in my Computer at drive C and how big it is and compare with the drives in the list, or you can look at the drives, drive letters like C: D: E: and so on. C: should be your main hard drive, D: is usually your DVD/CD rom...
Under health look and see what the smart is saying about the drive, it should say healthy if the drive is good. Click on the drive in that Windows and initialize it if needed (initialize does not mean "Mark Partition as active" when you right click on that drive)
Now if the drive does not show up at all or will not work or is not in a healthy state in the computer managment area we were just in the Drive is probably bad and should/needs to be replaced or its gonna fail soon, if everything works while it is connected directly to the computer it is the enclosure or your computers mass storage driver as explained above.
bronk50
  • 27725 Answers
SOURCE: Will an Acomdata external hard drive (Model # HD25OUHES5-72, Serial # C1005093) work with Windows 7
Windows 7 is a pain with large external hard drives you might get messages saying the hard drive needs to be checked or formatted do you want to check the disk now or do you want to format it now.
When there is nothing wrong with it at all.
External hard drives can be used on most computers and operating systems with minimal or no requirements other than leads and drivers.
Try it and good luck.
Hope this helps
Posted on Dec 11, 2012
How do i locate the drive for external hard drive e5 (acomdata) 500gb in my computer
right clicking on "MY COMPUTER" and selecting "MANAGE"
In the left hand panel your'll find "DISK MANAGMENT"
See if you can see the drive there, if you can you may need to assign it a drive letter.
Mar 23, 2011 | Acomdata 1TB Puredrive USB Esata 1 TB Hard...
My external hard drive fell off my desk and since it has been beeping and not operating correctly
You broke it. Does the Acomdata warranty cover self-inflicted damage?
Did you buy it with a credit-card that adds "all-perils" insurance?
All you can do is to disassemble the enclosure, remove the disk-drive,
buy a similar, compatible, disk-drive, install it into the enclosure,
and thus "revive" your external storage device.
Nov 02, 2010 | Acomdata 1TB Puredrive USB Esata 1 TB Hard...
External hardrive not recognized
Try a different cable between the computer and the drive.
Disassemble the casing, and remove the "internal" disk-drive.
If the USB-to-disk-drive adapter has "died", it's possible that the
disk-drive itself is intact, and your data will be intact.
Connect the "internal" disk-drive as a "slave" drive in a desktop computer, and see if it can be detected.
If it's dead, and it's still under warranty, then exercise the warranty.
Jan 04, 2010 | Acomdata 1TB Puredrive USB Esata 1 TB Hard...
Acomdata 1TB external drive
I have the same exact drive (I'm assuming as it's the same make/size since I don't have a model number) and what you need to do is turn the drive off and let it cool down. The drive is not well vented and it tends to over heat. I would get in the habit of turning the drive off whenever you're not using it because of this problem.
Sep 25, 2009 | Acomdata 1TB Puredrive USB Esata 1 TB Hard...
Not enough disk space to copy
Scan the drive due to possibly virus managing your disk drive. Virus can easily access through USB hard drives. If not solve the problem, so its better to format.
Mar 12, 2009 | Acomdata 500GB PureDrive USB eSATA 500 GB...
The red light is staying on on my Acomdata 1TB Puredrive USB Esata 1 TB Hard Drive and the computer will not recognize it.
I would say take the drive out and if you have SATA connectors on your motherboard, connect it directly to you computer and see if the computer will recognize it.  If it does, your enclosure is bad.
Mar 04, 2009 | Acomdata 1TB Puredrive USB Esata 1 TB Hard...
File transfer
Try turning everything off and then replugging the drive in.  Then start your computer back up/turn drive back on (if you have to).
Jan 31, 2009 | Acomdata 500GB PureDrive USB eSATA 500 GB...
I need to download driver for Windows XP Professional for Acomdata PureDrive Model 761 (external hard drive). Please help!
That drive should not need a driver for XP. The driver is for 98se only. XP will automatically install a generic driver and allow access to the drive.
Should the drive not come up automatically in XP, check to see if you have a bad usb port (by plugging in to another) and if this fails check with the vendor, as you may have a defective unit.
Jul 11, 2008 | Computers & Internet
Acomdata 1TB Puredrive USB Esata 1 TB Hard Drive Logo
118 people viewed this question
Top Acomdata Computers & Internet Experts
Donna Sander
Tom
Are you an Acomdata Computer and Internet Expert? Answer questions, earn points and help others
