Question about RCA Televison & Video
How do I replace the fuse on a colortrack 2000, RCA
  • 525 Answers
Open the back , follow the power cord and you will see the fuse around where the cable enter in , remove the fuse and replace by an other of same ratings. If you don't know anything about electronics don't do that because of some capacitors holds power even if the set is unplugged .
Do that at your own risk
Posted on Aug 05, 2010
Testimonial: "Thank you very much you may have saved my life!"
I have a Brookstone large button remote, with no instruction manual. Tring to set it to a RCA colortrack 26" TV. Is there anything i can do?
Hi
Try this:
Automatic Programming
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control (TV, VCR, SAT, DVD) until POWER INDICATOR illuminates. The remote control is in programming mode.
3. Press POWER button on remote and release . The POWER INDICATOR flashes once and stays on indicating the unit is in Power scan mode.
4. Press CHANNEL+ or CHANNEL- repeatedly until the device turns on.
5. When the device turns on, press ok to store the code.
Good luck pls rate
Dec 18, 2009 | Televison & Video
I need help finding my code for my TV. Its an RCA Colortrack
To control an RCA TV with a One for All URC-3021, follow these steps:
1) Turn on your TV.
2) On the remote, press the TV key once.
3) Press and hold SET until the LED blinks twice, then release SET.
4) Enter the first four-digit code from the following list:
0047, 1047, 1147, 1247, 1347, 1447, 1547
The LED will blink twice.
If it does not blink twice, go back to step 2 and try the same code again.
5) Aim the remote at the TV and press POWER.
The device should turn off.
If it does not turn off, repeat steps 2 through 5 with the next code in the list.
Hope that helps.
Oct 31, 2009 | One For All URC-3021 Remote Control
I replaced the fl231 fuse in my rca HD52W58 and it went back out
Had the same problem , you have to resolder the flyback before replacing the fuse.
Jun 25, 2009 | RCA HD52W58 52" TV
RCA ColorTrack 2000 - Picture getting small at bottom. Black line
Its the capacitors going bad. I believe you will see them as a pair.
Feb 24, 2009 | Panasonic TH-37PX60U 37 in. Plasma HDTV
Lost remote were to get code for 1988 colortrack
cant get input to work to play dvd menu wont come up with universal remote
Dec 23, 2008 | RCA 27V520T 27" TV
27'' RCA appears out of focus on the vertical Edges of the Screen
I've seen this on many computer CRTs as they age past 6 years. I would imagine that the gun alignment is out. Are all the colors (RGB) fuzzy, or is it hard to tell?
1. Sometimes, extreme settings of contrast or color (usually to offset low output from aging CRT) can appear to unfocus your screen. Adjust color/contrast down if they are maxed out or close to highest setting/pot level.
2. A very likely culprit is unshielded speakers are too close to the screen. If this is the cause, the speakers' magnets distort the part of the screen closest to them (sides), and it will get better/worse as you move the speakers away/closer to the TV. If there are not magnets near the TV, and degauss function does not fix problem ('89 TVs have degauss?), see #3.
3. The focus can be set by adjusting the flyback transformer. As an experienced electrician, you should know about the dangers of messing with the insides of the unit.
If this fails, you might have other bigger issues. I'd suggest a nice trip to lead reclaimer if so. I'd say 19 years is quite a life for a CRT.
Nov 12, 2008 | RCA F27440 27" TV
No sound
If you are using a cable box try patching the audio from the box to your stereo system. If that does not apply to you, then getting the set fixed or replacement is in order. A colortrack 2000 is like 20+ years old. They don't make them like that anymore., Too bad.
Mar 24, 2008 | Televison & Video
Rca colortrack 2000 26"
They were noted for a bad relay. I doubt if you'll find one.
Feb 18, 2008 | Televison & Video
Televison & Video Logo
190 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
