Question about Epson Stylus C42+ InkJet Printer
Epson Printer Utility
I sought and paid for an answer to the question below. There were three solutions proposed. I tried the first one listed, but this did not work. Meanwhile the other two disappeared from the screen before I could try them. Though I paid, I still have not solved the problem. So, first, I want credit.
My computer is a desk top Mac OX 10.2.8; my printer is an Epson Stylus 88+, serial number JKDY 122875. The problem is that I b cannot access the the Epson Printer Utility and because of this determine which it the ink cartridges need to be replaced. Since I cannot replace the ink cartridges, the printer will not print.
I have tried several times to reinstall the Epson Printer Utility using the software titled ":Epson Stylus C 42 Series. When I do the printer Stylus 88 is listed in the Print Center, but the Epson Printer Utility con does not appear on my desktop ans I still cannot access it. Can you help?
    Genius:
  • 3,587 Answers
Sure...let's check for o/x compatibility first..I'll check the epson site.
as to the credit, I believe there are options for that in the sign up screen if I am not mistaken
Posted on Apr 26, 2008
  • Patrick Michaels
    Patrick Michaels Apr 26, 2008
    click here for those..make note, please, that there are some exceptions for latest Mac software..which MAY have an influence on what works or doesn't with Epson s/w
Epson Printer says it needs a service
Suggest you start here:
Epson R340 Support
Click on the Troubleshooting Guide and answer the questions.
This should lead you to a possible solution or they may recommend replacement if not under warranty.
Thanks for using Fixya.
Nov 23, 2009 | Epson Stylus Photo R340 InkJet Printer
Epson cx3600 has ended its service life
Try updating your drivers, go to Driver Detective,
May 20, 2009 | Epson Stylus C88 InkJet Photo Printer
Incompatible cartridges
cartridges maybe bad. Take the cartridges out then put them back into the printer. Turn the printer on and off. you can also get the ink pad reset utility from epson.com if that does not work.
May 02, 2009 | Epson Stylus Multifunction Inkjet Printer/...
EPSON TM-T88iii printer 'Not Available'
I've had this issue many times. The only resolution is to completely uninstall the printer using the epson utility then re-install. This solution is only temporary as it will go to unavailable within 2 or 3 days.
Apr 09, 2009 | Epson TM-T88III Thermal Printer
Language
Hi-
Try uninstalling and reinstalling the driver and that should default it back to english. keep me posted for any progress and pls rate solution if it helps. Thanks!
Jul 16, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Epson1400
ssc i maen service utility for epson1400
Jun 13, 2008 | Epson Stylus 1400 InkJet Photo Printer
Epson stylus dx7450
Windows uses a foreign language information file when installing a printer driver via USB. This then installs the associated foreign printer driver and utility files.
This can be corrected with a full uninstall of the printer driver. The standard uninstall will not remove the original foreign language files. Please follow the steps below to install the English version of the printer driver:
Step One:
Switch off and disconnect the printer. Go to Add/Remove Programs in Control Panel, and remove EPSON PRINTER SOFTWARE (this may be named in a foreign language like 'EPSON DRUCKER SOFTWARE' - when you are at this stage and have selected to 'change/remove' this item, a window will appear titled 'EPSON Printer Utility' - above the icons of each of your EPSON printers will be a 'Printer Model' tab and 'Utility' tab (Note, if there is no Utility Tab then just continue). Please click on one of the printers so it is highlighted, then select 'Utility' - please tick every box listed in the 'Utility' section and select 'OK'. Answer positively to all questions and once the uninstall is complete, you will need to follow the same procedure to remove the other EPSON printer drivers by clicking on 'EPSON PRINTER SOFTWARE' again and 'CHANGE/REMOVE'.
Step Two:
Open up Windows Explorer or My Computer, and navigate to the drive (usually C) where windows is installed. Browse to the folders called windows/inf on XP, or winnt/inf on 2000. If you can not locate the INF folder please go into the START MENU and select RUN. If there is any text within this box please remove and type C:\windows\inf and press enter. Please be advised that 'C' represents the hard drive on your PC. If your hard drive is a different letter please amend as necessary.
Find the files labelled OEMxx.inf or OEMxx, where xx is a number from 00, 01, 02 etc upwards. You will need to double click on each INF file in turn, and if it says “SEIKO EPSON” or “EPSON” within the first few lines, then you need to close the file, and then delete it. Please also can you delete the corresponding PNF. Repeat this until all EPSON INF files are removed.
Note: You cannot open a PNF file.
Step Three:
Staying in Explorer or My Computer, stay within the windows folder (winnt folder on 2000) and navigate to system32/spool/drivers, and go into the folder named "w32x86". Delete any folders that begin with "epson", and then restart. Once rebooted, empty the recycle bin, and attempt reinstallation of printer, using the instructions below.
Step Four:
MAKE SURE YOUR PRINTER IS STILL SWITCHED OFF AND DISCONNECTED AT THIS POINT. Insert your driver CD. Double Left Click on My Computer and select your CD drive by right clicking on the CD icon and select open. When you first open/browse the CD-Rom then you should see various folders. Please browse to the Common Folder. Within here select the Printer Driver Folder then choose the WinVISTA/XP_2k folder. Run the Setup.exe file and complete the installation as normal making sure you only connect the printer when requested to do so.
Step Five:
Once this has completed installing, please remove the CD from the CD drive and reboot the PC. The foreign language tabs will now appear in English.
Mar 16, 2008 | Office Equipment & Supplies
Epson Stylus CX6400- Error
This worked me:
Manual reset for Epson CX6400
  1. Turn off the printer.
  2. Press and hold B/W+COLOR+STOP button.
  3. Press and release the power button.
  4. Release the B/W+COLOR+STOP buttons. (My screen said "Init EEPROM")
  5. Press COLOR button to clear protection counter.
  6. Turn off the printer by pressing power button.
Found this solution here: http://tricks-collections.com/resetter-epson-stylus-cx6500/
Jan 01, 2008 | Epson Stylus CX6400 All-In-One InkJet...
Epson stylus photo R360
I had the same problem and so contacted Epson support. This was the reply, it worked for me.
Step One:
Switch off and disconnect the printer. Go to Add/Remove Programs in Control Panel, and remove EPSON PRINTER SOFTWARE (this may be named in a foreign language like 'EPSON DRUCKER SOFTWARE' - when you are at this stage and have selected to 'change/remove' this item, a window will appear titled 'EPSON Printer Utility' - above the icons of each of your EPSON printers will be a 'Printer Model' tab and 'Utility' tab. Please click on one of the printers so it is highlighted, then select 'Utility' - please tick every box listed in the 'Utility' section and select 'OK'. Answer positively to all questions and once the uninstall is complete, you will need to follow the same procedure to remove the other EPSON printer drivers by clicking on 'EPSON PRINTER SOFTWARE' again and 'CHANGE/REMOVE'.
Step Two:
Find the files labelled OEMxx.inf, where xx is a number from 00, 01, 02 etc upwards. You will need to double click on each INF file in turn, and if it says "SEIKO EPSON" or "EPSON" within the first few lines, then you need to close the file, and then delete it. Repeat this until all EPSON INF files are removed.
Step Three:
Step Four:
MAKE SURE YOUR PRINTER IS STILL SWITCHED OFF AND DISCONNECTED AT THIS POINT. Insert your driver CD. Double Left Click on My Computer and select your CD drive by right clicking on the CD icon and select open. When you first open/browse the CD-Rom then you should see various folders. Please browse to the Common Folder. Within here select the Printer Driver Folder then choose the WinXP_2k folder. Run the Setup.exe file and complete the installation as normal making sure you only connect the printer when requested to do so.
Step Five:
Oct 08, 2007 | Epson Stylus R265 InkJet Photo Printer
Epson Stylus C42+ InkJet Printer Logo
76 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
