I have a Vizio VX32L HDMI. I tried to plug my computer into the tv while the tv and computer were on. I was trying different outlets in the back of the tv. When i tried the cable in one of the outlets the tv shut off. I cant turn it on. Did it blow a fuse? Please help
    Master:
  • 344 Answers
Try unplugging the TV and then press the power button. This will discharge the system. Then plug it back in and try to power it on again. Make note if there is ANY action from the TV. If it comes on then YAY! if not let us know. Also, what were you trying to plug in where? Was it a standard VGA plug? DVI? HDMI?
Posted on Aug 05, 2010
My vizio is blinking back and forth from the blue no signal screen to the actual hdmi input screen which is connected to a cable box. What is going on?
Have you tried a different HDMI input? (If available.) You may be able to test the cable box of PS4 using component cables to confirm that all but the HDMI is not working. You may try pushing or holding the HDMI cables to see if you can make the problem better or worse to identify a possible flakey HDMI socket.
Jan 03, 2015 | Vizio 26 Class Edge Lit Razor LED LCD HDTV...
The orange light isnt on
Make sure the power plug is secure both to the TV and the wall. Also make sure the outlet is not on a switch. Try and unplug and plug the TV back in. Try a different power outlet. Make sure you are pressing power on the TV itself as the remote may not be working. Otherwise TV may need service, and for this unit I would recommend just replacing it to save cost and frustration.
Apr 09, 2014 | Vizio VX32L Television
Vizio VX32L TV will not power up?
Assuming the outlet is good, first place to check will be the pwoer supply module, chheck the main AC fuse, connections, etc.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Please post back what you find.
Oct 25, 2010 | Vizio VX32L Television
My Vizio VX32L LCD TV will power on but no picture or sound
I had the same problem after having a Vizio for 2 and a half years. I left the room for a minute, i came back and the screen went black. There was still power to the unit and you could see that the back light was working, just no picture, no sound, and you couldn't use any of the buttons. The only way to turn it off was to unplug it. It would then start up, with the Vizio logo going from orange to white, and then do the same thing all over, no pic or sound.
HOW I FIXED MINE: I ordered a new "main PCB" from tigerdirectparts.com (you can also use searspartsdirect.com). This is the circuit board with all of the inputs on it (hdmi, cable, etc.) I opened it up, disconnected the old one, put in a new one and now it works fine. I used both serial numbers on the board to search for it online. It cost me $144 to do it, but that's better than $450 for a new TV. My tv is the vx32l hdtv10a. I hope that helps.
For me the part number was either (depending on the vendor) : 0171 2272 2174 or it was 3632 0212 0150. Check your circuit and see if any of those numbers match up.
Nov 23, 2009 | Vizio VX32L Television
My Vizio vx32L isnt getting power. the orange light comes on when plugged in but when you power it up the white light comes on but no picture. and it wont turn off unless you unplug it. please help me
HOW I FIXED MINE:Look through the back vents for a white light to make sure the backlight still works. I ordered a new "main PCB" from tigerdirectparts.com (you can also use searspartsdirect.com). This is the circuit board with all of the inputs on it (hdmi, cable, etc.) I opened it up, disconnected the old one, put in a new one and now it works fine. I used both serial numbers on the board to search for it online. It cost me $144 to do it, but that's better than $450 for a new TV. My tv is the vx32l hdtv10a. I hope that helps.
Nov 12, 2009 | Vizio VX32L Television
Vizio model VX32L TV has no picture
80% of TVs are having this same problem in different brands.
I'm sure Carlos meant well. If you took it to someone to have it fixed, then yes, it would be cheaper to by a new TV. ( Labor + Part )
But, if you can repair your TV yourself for less than a $100 vs buying a new TV for over $450, would it be worth it? ( Part alone )
If you or someone you know can replace a whole ciruit board, then it can be fixed.
Here's a web site to get the replacement board:
http://www.shopjimmy.com/catalogsearch/result/?q=vx32l+back+light
You'll just need to find the right one by looking at yours. Your backlight board will have letters & numbers on it for a board model#. It should be easy to find one and replace it.
May 13, 2009 | Vizio VX32L Television
Orange screen
Try a different cable other than HDMI, another HDMI cable, or another DVD player to narrow it down.
Feb 15, 2009 | Vizio VX32L Television
No Power to a Vizio VX32L
My best guess is to check for blown fuses or the power board when bad inside the TV.
If that doesn't work, looks like you'll have to pay a repair shop to find out what's really going on.
Sorry I can't help you further.
Feb 03, 2009 | Vizio L32 32 in. LCD HDTV
Televison & Video Logo
96 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
